Diagnosing Brake Sound
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Christian Muise, Jul 22, 2026.
  1. Christian Muise
    Christian Muise New Member
    Ontario, Canada
    2020 Prius Prime
    Could use an assist on this one. It's been progressively getting worse for over a year now, and dealership maintains that everything's fine -- pads and rotors seem fine. We can book in a $300 brake inspection, but I'd like to go into it informed. I have a video of the phenomenon*, but can't post due to being a new user. If anyone has a pointer to common "does your car sound like this? here's why!" videos, I'd be very grateful! I guess I can (hopefully?) DM the video link as well.
    Some details:
    - happening almost always when coming to a stop
    - slow rolling stop makes it worse. as does stopping on an incline
    - the second set of squeaks is after putting it in park and taking the foot off the brake (no wheel motion)
    - mechanic said pads and rotors are in great condition (service 1 done today)
    - we don't drive a lot: 47k on the car at this point
    Anything else worth mentioning?
    * Why is it so hard to find example brake sounds + diagnoses online!!
  2. JC91006
    16,936
    8,647
    You might just have bad/cheap brake pads. Have you replaced them before or are they the originals?
    Toyota sells inferior brake pads now using the Toyota name. If you replaced them recently with the "cheap" variety, you would get brake noises when you brake
  3. ChapmanF
    19,027
    Please do post a recording link as soon as you've made a few more posts so you can.
  4. Christian Muise
    Ontario, Canada
    2020 Prius Prime
    Thanks! As far as we can tell, original brake pads on the car. They replaced the back ones in 2023 (I guess it was an issue that we "didn't drive enough"?), but the inspection (visual only) yesterday indicated that rotors and pads looked entirely fine.
    Sound is only on the front, and the fact that it also happens when releasing the brake while at a stop makes me think that it isn't about somthing rubbing against the wheel/rotor.
    (will find some more opportunities to post so I can get this link in!)
  5. BiomedO1
    BiomedO1 Senior Member
    4,616
    2,416
    Left Coast
    How do you KNOW it's the brakes?
    Has anyone taken a test drive with you, so you can point out the issue your having?
    Is it repeatable and consistent?
    You've told the service advisor there's a braking noise - they are only going to look at the brakes.
    IMHO; throwing a recording of a noise into the void is only going to give you a bunch of guesses. Go to a local tire and brake store for a free evaluation of your issue or pay for one. At least they can see, feel, smell, and hear the issue - rather than people giving you a wild guess online.....
    Good Luck....
  6. ChapmanF
    19,027
    There are certain brake sounds that are very distinctive, in the earlier generations at least. I might be guessing a bit for gen 4 given the changes to the brake hydraulics, or I might not, depending on the sound. What you get from a local tire and brake store could also involve guessing.
  7. Mendel Leisk
    42,352
    Maybe with a few more posts you'll get permissions. Do be aware: you can't directly upload video to this site; you'll need to upload to YouTube or similar (and create account there if needed), then provide a link here.
  8. Robert21PrimeLTD
    107
    50
    South of Nashville
    I suggest a stationary test if you can.
    Park on level ground with the everything in the vehicle off and the parking brake off. Use wheel chocks if needed to keep the vehicle from moving. (1) jack up the car so that one of the wheels is off of the ground and there is a space between the bottom of the tire and the ground. (2) move/turn the wheel jacked up with your hands to spin the wheel slowly and listen for any noises. There may be a small rubbing sound as the brake pads rub against the rotor. This is a normal sound. (3) Repeat for the other 3 wheels.
    This should give you a good idea if one of the rotors is warped or one of the calipers is creating the excess noise. FYI, a small stone or pebble can get caught between the rotor and the brake pads too and make a noise. If needed find a friend who is car-smart to listen with you, Good luck.
  9. Mendel Leisk
    42,352
    You've got to know your audience. "service 1" is a unique to Toyota Canada description. It's essentially just the tire rotation service, and if he's not rushed he might glance at the brakes. More info, and I do think Google AI is "optimistic":
    https://share.google/aimode/CAw1ejfNK1e4m4nsm
  10. BiomedO1
    4,616
    2,416
    Left Coast
    A ride along; so you can point out your specific issue; if it's consistent and repeatable.
    I agree with you; if the local shop just does a peek at the brakes without a ride along. They will more than likely come to the same conclusion as the dealership - but you can get a mechanic ride along in small shops - at least you used to. You many be able to get a ride along with a know nothing service advisor at the dealership. That's the difference; someone that just pushes paper or someone that wrenches. A halfway competent wrench will usually have a better guess than someone that just pushes paper around or keys on a keyboard.o_O:LOL::ROFLMAO::whistle:
    #10 BiomedO1, Jul 23, 2026
  11. Christian Muise
    Ontario, Canada
    2020 Prius Prime
    Thank you for the responses! Feels like I'm pulling a long bait-and-switch with this video, but after this post, I just need to wait ~24hr before the link is shareable. I do think it's distinct enough for someone in the know to say "ah, of course, that's just XYZ happening". More details...
    - doesn't happen when braking at speed (never a sound on the highway)
    - used to be sporadic, but is now fairly frequent when driving around town
    - doesn't happen much from a cold start -- almost surely happens after driving for ~5-10min and then coming home to park
    - the technician knew of the issues, looked for anything amiss during service 1 (just visual -- not a full brake inspection), listened to the video, then took another test drive and reproduced it. Still no strong hypothesis as to what it could be, but said that visually everything looked fine.
  12. Christian Muise
    Ontario, Canada
    2020 Prius Prime
  13. BiomedO1
    4,616
    2,416
    Left Coast
    A 2L jug or soda rolling around your hatch or behind your rear seat floor boards?:D:p:ROFLMAO::LOL::whistle: That would explain why they didn't see anything at your brakes.o_O:rolleyes:(n)
    It doesn't sound like brake spring pads popping; but I'm not there and the sound is muffled.
  14. Christian Muise
    Ontario, Canada
    2020 Prius Prime
    Lol, if only it were as simple as a bottle to remove ;). "Creek" is a more apt term than scrape. Reminds me of stepping on old floor boards. A better capture:
    https://photos.app.goo.gl/CM5jogaj8ZSorQ5RA
    Figured this must be familiar to someone here.
  15. steamedhams
    steamedhams New Member
    I was just about to post with this exact problem for my 2021 Prime. It has low mileage as well - 66k. The sound is exactly the same. I wasn't able to find a video with that sound until stumbling here. I'll post a video when I have enough posts.
    Maybe you can tell me if this is the same for you:
    1. Drive and reverse make the creaking but neutral doesn't
    2. I can get the creaking at standstill on flat ground without moving by releasing then pressing the brake quickly
    3. Only hear it at low speeds but I can't rule out that it's inaudible at higher speeds
  16. steamedhams
    Similar to you, it's not as loud when the car starts but gets louder after 10mins of driving. I think the sound started 2-3 months ago but it must have been quiet otherwise I would have noticed it sooner. At this point, the creaking is consistent on every slow braking.
    I'll type up some theories (in the next few days) based on the process of elimination and see if the experts here have thoughts.
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    I listened to the quoted sound byte. I hear two distinct periods of what sounds like audio static. The second sound seems to occur after the vehicle is stopped or slowly stopping. I thought it might sound like a malfunctioning electric brake booster. Prius doesn't have reliable vacuum for brake boosting, so it is electric. That should throw a code though. Can you confirm that a normal brake booster charge sound happens periodically after 2-3 brake pedal uses or immediately after unlocking and opening the driver door? Maybe it is a fracture in the frame or suspension parts, especially for aluminum parts that make a squeeking sound when stressed. You need someone to ride along with the windows down and precisely locate the sound origin as best as possible.
  18. steamedhams
    Exactly the same sound. Still a few posts away from sharing my clips.
    Not original poster, but I thought it was structural as well. However, the creak doesn't happen when hard braking while in neutral down a hill. Pushing down on the car from the outside with my weight doesn't make any creaks either. At least it's not a control arm that needs a bit of grease.
    The fact that neutral doesn't make the sound should eliminate structural (control arm, struct mounts, etc.) and the brakes (pads, rotor rust, pins), no? No creaking at all in neutral.
    In neutral, the drive wheels aren't engaged to the transmission unlike in drive or reverse. Since the creak happens only in drive and reverse, the creak is coming from the transmission and beyond. Aside from the MG2, what else moves right after braking and could make a loud enough sound as this? Does anyone know?
  19. steamedhams
    I saw a post that mentioned the MG2 doesn't apply any braking at low speeds, below 1mph for gen 4, so I wonder if it's even at play. Maybe that eliminates the MG2 since the creaking can happen even at standstill after letting off the brake for a split second.
  20. steamedhams
    I'm going to try a stationary test when I get the chance to fully eliminate the brakes. It will also help better isolate where the sound is coming from.
