High mileage 2013 Prius Spark Plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gloria&Suzanne, Jul 20, 2026 at 3:35 PM.
  1. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    70
    Sacramento, CA
    As shown in the images below, do you think these spark plugs need replacement? They were oily when I took them out, so I suspect piston ring issues. IMG_20260712_145736213.jpg IMG_20260712_145748306.jpg IMG_20260712_145755261.jpg IMG_20260712_145800068.jpg IMG_20260712_145804800.jpg
  2. BiomedO1
    4,547
    2,392
    Left Coast
    You need to examine the tips, electrodes and gap. Any damage or pitting, they should be replaced. Iridium plugs will easily go 100+K miles.
  3. Brian1954
    Brian1954 Senior Member
    2,667
    1,066
    South Central PA, USA
    How many miles have you driven the car using those spark plugs? They look like new.
    #3 Brian1954, Jul 20, 2026 at 5:43 PM
  4. Gloria&Suzanne
    70
    Sacramento, CA
    I suspect mine might have piston ring issues and I wanted to make sure there spark plugs were not fouled by oil. I'm pretty sure they look normal.
  5. bisco
    52,804
    gen three up through part of 2014 had poor pistons and rings. have you cleaned the egr circuit?
  6. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    Is it consuming much oil?
  7. Gloria&Suzanne
    70
    Sacramento, CA
    The oil turned dark after only 2k, but I changed it just to be safe. My dad said it can be one of the signs of that happening, or starting to happe. Or maybe the oil was contaminated by the carbon deposit buildup (a known third generation prius problem) that I cleaned a few months ago, a bit after the oil change at Jiffy Lube.
  8. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    Wow, that's dirty. It's not likely the oil was changed often enough, and/or it was the incorrect oil.
    You could use a quart of Marvel Mystery Oil the next time you change the oil.
    And about 3-400 miles before you change it, add 4-5 ounce of SeaFoam to the oil.
    It will help clean out the nasty stuff.
    You could also try Valvoline's Restore and Protect. It won't hurt to use it, and it "might" help
    to clean out the crap.
    Make sure you change the oil every 5000 miles also.
  9. Gloria&Suzanne
    70
    Sacramento, CA
    This was only 2k miles after it got an oil change at Jiffy Lube. The oil was dark when I drained it out so I changed the oil giving it the right amount and type of oil.
  10. Gloria&Suzanne
    70
    Sacramento, CA
  11. bisco
    52,804
    maybe never changed it, they put the jif in jiffy
    BiomedO1 likes this.
  12. BiomedO1
    4,547
    2,392
    Left Coast
    Low quality drum oil that I refuse to use on my cars.
    The truck I inherited from my dad had Jiffy Lube changes and the oil would thin out when warm causing low oil pressure when stopped and idling. It had an oil gauge so I can see it - Prius just has a dummy lamp; so unless you break the lower threshold, you'll never know. That would cause even more excessive oil burn on your car; because it's thinner than specs. with weak piston rings.
    As I stated before; I just did an oil change with quality oil and filter - problem went away - but the engine probably has excessive wear; due to the thin oil.
    YMMV
  13. ASRDogman
    8,052
    4,083
    NEVER go to ANY quick lube place! They are the worst!
    Cheapest crapiest oil and filters....
  14. Mendel Leisk
    42,297
    I often wonder if there's ANY validity to these assertations.
  15. BiomedO1
    4,547
    2,392
    Left Coast
    That's simple; why do they do oil and filter comparison tests? A lot of them can meet min. specifications out of the bottle; but will they hold up for the specified oil change interval? That's the difference and why I refuse to use certain brands; because I've been burned by them in the past.
