Breaking AC discharge line
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by 80sguy, Jul 20, 2026.
  1. 80sguy
    80sguy Junior Member
    40
    Rome NY
    I have a really unique problem. Hopefully it's not too unique. I bought my wife a used 2013 Prius V. The car has 182,000 but the motor in it only has 104,000. Replaced by deale. AC was working fine then suddenly it stopped working. I took it to a repair shop, he's the local Prius whisperer. He replaced the lower discharge line. High pressure between the compressor and condenser. It had a strange break in the aluminum portion like it was tour. We watched to see when it started if maybe a motor mount was broke and motor was jumping causing the tear but it did not happen. Four weeks later it broke again I looked it was in the same spot. He had used a used parts so I thought that was the problem so I ordered a new one from RockAuto and put it in. 3 weeks later it breaks again in the same spot. I looked up the information on the Toyota website and turns out this happened to the previous owner twice within 9 months in 2024 and 25. Anybody have any ideas why this keeps happening?
  2. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    Bad motor mount allowing too much movement, flexing the line to its failure point?
  3. rjparker
    11,053
    6,925
    Normally these lines never break or leak. A used one would be just as good.
    There is something not secured well and it's likely the motor or the condenser. I would go to the dealer and let them verify the motor mounts and the ac line connections.
    Discharge line from compressor to condenser has a flexible hose portion.
    The smaller diameter line below is the high pressure liquid line after the condenser and the larger is the suction line. Both are secured as shown within the red boxes. The green arrow is the most likely motor mount.
    #3 rjparker, Jul 20, 2026
  4. 80sguy
    40
    Rome NY
    We checked motor mounts, pretty sure it's not the problem
  5. 80sguy
    40
    Rome NY
    Those pictures look nothing like my setup. It is my understanding and also the understanding of RockAuto that this is the discharge line
  6. rjparker
    11,053
    6,925
    Your v has a discharge line muffler in the discharge hose.
    Ebay oem used part
    Pressures in this line are the highest in the system. Assuming you are not dealing with a previously replaced compressor due to a burn out, I would buy another used oem discharge line instead of a low cost aftermarket. Be sure the u bend is not being twisted or forced to install the line because of poor alignment.
    The engine is unloaded at startup. High load operation is more likely to move the engine.
    #6 rjparker, Jul 21, 2026 at 12:55 PM
  7. Air_Boss
    Air_Boss Senior Member
    4,250
    1,195
    New Yawk
    Does it appear to be a torsional flexure break or a tension/compression flexure break?
  8. BiomedO1
    4,550
    2,393
    Left Coast
    I'd be looking at the mounting brackets for the compressor, line, and condenser. There's a rubber hose section that should absorb most of the torsion; but if the hose is clamped down in the wrong place, rotated taunt - the rubber section can't do it's job. Look at the condenser too; the other end of that hose. It could be flopping around, causing tension at that stress point.
    FWIW; I've seen aftermarket parts not angled correctly, slightly too short for application - that would cause such a repeated failure. The installing technician doesn't notice and just installs the part. If the technician rotates the ends to get everything to line up - they've just stiffened the rubber section that's suppose to absorb the vibration stress during operations.
    Good Luck.....
    PS are they refilling the system by weight or pressure? I believe that's a variable speed compressor, so it should be filled by weight.
    #8 BiomedO1, Jul 21, 2026 at 2:57 PM
    Air_Boss likes this.
  9. 80sguy
    40
    Rome NY
    Sorry I stand corrected the picture with the Green arrow and the two red boxes is my setup
  10. 80sguy
    40
    Rome NY
    A torsion flex break
  11. 80sguy
    40
    Rome NY
    A torsion flex you can see the split just above the bottom bend
  12. 80sguy
    40
    Rome NY
    Was refilled by pressure. I'm going to have to look tomorrow morning and see if I can find some of the other possible loose points that you spoke of. I'm the one who put the part in. And I'm the one who failed it. It was a b**** getting that in where it hooks into the condenser
  13. 80sguy
    40
    Rome NY
    I'll have to put it in diagnostic mode and see then. And yes I had the right part. I got it from carparts.com. That's where the first one came from. I ordered a second one this one was almost twice the money so I'm assuming better quality?
  14. Air_Boss
    4,250
    1,195
    New Yawk
    I don't see it, but at least that suggests to look for what is loose and might be causing the torsion loading.
  15. 80sguy
    40
    Rome NY
    I blew it up
  16. 80sguy
    40
    Rome NY
    I blew up the pic. It's just a hairline crack however the past two times it broke it literally broke away into two separate pieces
