Replacement for non hybrid battery in the trunk?
Discussion in 'Generation 1 Prius Discussion' started by War_Destroyer, Jul 24, 2026 at 12:38 PM.
  1. War_Destroyer
    War_Destroyer Junior Member
    40
    Los Angeles
    2002 Prius
    I my battery finally going bad? Yesterday my little brother was driving my mom around when apparently the car stalled in the middle of the street. The only thing my little brother noticed besides the car being more sluggish than usual is that the center console display turned white when the car stalled. He was able to restart the car and limp it home.
    Torque Pro found codes related to the hybrid battery, which also needs work, but I noticed that the battery voltage for what I assume is the trunk battery rests a 9.6v when I turn the key to position two, but jumps to 14.1v when the car is actually running. Is this too much of a voltage swing meaning that the battery is bad? Do you guys have a recommended replacement?
  2. Trombone
    Trombone Active Member
    387
    129
    Allentown, Pennsylvania
    2002 Prius
    For the 12V, I've used Interstate. Any good case size 51R battery will do. You may have to shim the bottom about 1`". Domestic battery will need terminal adapters like these:
    For the HV, I have this one installed: https://greentecauto.com/hybrid-battery/toyota/prius-hybrid-batteries/toyota-prius-2001-2003/toyota-prius-gen-1-new-cell/
    Greentec has a facility in LA: https://greentecauto.com/locations/los-angeles/
    They also do a mobile install. I paid $75, well worth it.
    Good luck, and let us know how it turns out.
    #2 Trombone, Jul 24, 2026 at 3:18 PM
  3. Trombone
    387
    129
    2002 Prius
    As for your voltage readings on the 12V, conventional info says you need 11+ volts to boot the hybrid system (i.,e., start the car), but I've observed that lower voltage will work. If you get started with 9.6, more power to you (double meaning intended!). On my '02, the 12V readout is 13.8 volts when car is "Ready."
    Resting voltage on my 12V is 12.4. That’s with everything off, but presumably incorporating whatever parasitic drain is occurring. The 12.4 is what my ScanGauge is reading; a more accurate measurement would be directly off the battery terminals, and would probably read higher by .1 or .2 volts.
    #3 Trombone, Jul 24, 2026 at 3:30 PM
  4. ChapmanF
    19,003
    9.6V resting voltage on a 12V battery means at the very least that it is very deeply discharged.
    After a long rejuvenating spell on a good battery charger, I'd unhook it and check again. If it holds up decently after, that could have been all it needed. If it's down sub-12-volts again in short order, it's toast.
  5. Trombone
    387
    129
    2002 Prius
    d
    #5 Trombone, Jul 25, 2026 at 9:11 AM
  6. Trombone
    387
    129
    2002 Prius
    Finally figured out that this site doesn’t allow you to post links to the popular E-tail site that starts with letter “A.” So my first post (above) has a big hole where I tried to paste a link. Enter search term “SAE to JIS battery terminal adapter” and a bunch of links will come up. hope this helps
    Also, the “edit” function on this site is very screwy. Moderator(s), are you listening?
  7. Trombone
    387
    129
    2002 Prius
    If the number 190820 stamped in white on the battery case is a date code, then that D23 (55D23L) Panasonic battery was manufactured either August 20, 2019, or August 19, 2020. If either is the case, then that battery is six or seven years old and has doubtless outlived its useful life expectancy for a lead-acid battery. Time to shop around for a replacement.
  8. ChapmanF
    19,003
    Oh, it totally allows you to post those links. It sees them and immediately turns them into a big JavaScript-driven advertising-o-rama singing dancing thing in the middle of your post. People with more sensible browser security settings will then see a big hole there, instead of the ads and singing and dancing.
    If you construct a link yourself using [url=...]...[/url] (or the chain-linky icon above the edit window), you can make your own link to the product page and have it show up how you want it to, and it won't get turned into an ads-o-rama.
  9. War_Destroyer
    40
    Los Angeles
    2002 Prius
    I pulled the battery out and left it charging on some old 6 amp black+decker charger I had lying around for a whole day and this is what my cheap battery tester spit out...
    Do you think buying a better charger with a rejuvenating or "conditioning" function would help? If just to bring new life to it and repurpose it elsewhere?
    Then I'll do as you said and buy a 51R battery with terminal adapters then. Thank you guys!
  10. hill
    9,026
    Wasting time on any 12v battery ½ dozen yrs old or older simply means one is putting off the inevitable.
    Brian1954 likes this.
  11. Brian1954
    Brian1954 Senior Member
    2,670
    1,068
    South Central PA, USA
    It's time to buy a new 12v battery .
  12. Trombone
    387
    129
    2002 Prius
