Prius c 2015 c1256&c1391 code
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Kxlla Miguel, Aug 7, 2026 at 12:12 PM.
Tags:
  1. Kxlla Miguel
    Kxlla Miguel New Member
    Yesterday
    Jamaica
    2015 Prius c
    Was pulling out of car park when I noticed abs,traction control, brake light n warning light came up, it went off but came back up as I was driving that when I felt the difference in the brakes it sank more n felt like I was loosing pressure until the pedal bottom out, the brake assembly made more noise than usual, the pulse I felt when I started the vehicle from the brake pedal it not present once the lights or on but when off I feel it,note before I bought this the brake assembly was replaced with a used on could it failed already or could it be the master cylinder need changing or entire assembly again
  2. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    Check the fluid level for the brakes... Also, how often do you hear the brake pump running? What happens when you pump up the brakes?
  3. PriusCamper
    13,463
    5,431
    12v battery fully charged?
  4. Kxlla Miguel
    Yesterday
    Jamaica
    2015 Prius c
    No it’s dead had to get a jump when my brother came to assist when the brake started acting wierd drove to work today tested battery it’s dead, but prior to that my brother said he had to change the abs brake actuator pump cause he had the same issue n his mechanic told him to change it but also recommended he change the brake booster assembly but he didn’t so now with the same issue, the code that I got when i scanned suggested it was booster assembly at fault, would a dead 12v battery cause those issue?
  5. Kxlla Miguel
    Yesterday
    Jamaica
    2015 Prius c
    Fuel level is full, pumps run constant n only take a 5sec interval, if foots on pedal it constant. If the abs,traction control n brake light comes off dash regularly braking resume but as soon as light appears u feel u start to lose pressure in braking until it hits the floor n secondary braking system chips in but I have to sink pedal hard for that to happen.
  6. bisco
    52,855
    I would say it's the booster, but you need a healthy battery to make sure the codes are correct and pumps working properly
    PriusCamper likes this.
  7. Kxlla Miguel
    Yesterday
    Jamaica
    2015 Prius c
    I did put a good battery inside n issue remain pump was running constant until it stopped completely, scanned and 2 new code came up c1252 and c1253, brake died complete now no buzzing sound or anything, pedal straight at floor, did the constant running of tank burn it up or could it be a relay blown to prevent it from overheating or both system has failed now both the pump n booster assembly?
