Yesterday I bought an old Prius ('08) to have as a loaner while my son's car is down for repairs. It has 223K miles, and a number of codes/lights on the dash. I'm under no illusions about the car's longevity, but with decent service history for the last 100K miles, new tires and relatively clean body I figure it'll do for now. Biggest items that need fixing are the airbag d+squib circuit code, RF wheel speed sensor that has the ABS/TRAC/VSC lights on and I assume that's why the cruise control is inop, and the spare tire hold down bolt was frozen in place. I fixed the spare tire bolt, and aired it up. I'll need to keep an eye on the spare to see if it has a leak. The airbag light/code seems to have been fixed with a salvage yard clock spring that I installed this evening. Tomorrow I'll tackle the wheel speed sensor. The TPMS is also on the fritz (6 different codes) so I'll scan all the sensors and see what's what there. I don't count that too high on the priority list though, I know how to work a tire gauge. I'd also like to figure out why the smart key features don't work. I only got one FOB, and the battery was dead in it. I replaced that battery but it's still acting like the FOB is just dead: lock/unlock buttons don't do anything, the FOB has to be inserted into the dash to start the car. I wonder if my Techstream will allow me to see if the computers are seeing anything from the FOB? Anyhoo, thanks for reading. OH, how do I tell if mine is the 'touring' model? It has navigation, but I'm not sure if that's exclusive to the touring or not?
Quick update: the wheel speed sensor just had some shavings that were stuck to the magnet, likely from the old wheel bearing/hub. I'm guessing the mechanic that replaced the hub didn't bother cleaning the sensor. I cleaned it and took it for a drive, no more abs/vsc lights now. Yay! Also, no airbag lights, so that seems to be fixed. But the cruise control still won't set. When I push the on/off button the 'cruise' light on the dash goes on/off but pushing the lever to 'set' doesn't make any difference. Any thoughts? As for the TPMS, two sensors are flat dead, one is all but dead and one does seem to be alive. So I'll see what I can find for a compatible sensor set. While I was working on the wheel speed sensor I found out that I apparently didn't look at the CV boots, because the one on the front right outer is done. I'll see what I can find for a replacement boot and get that repaired as well.
Was the spare tire bolt stuck in place because it was rusty? This car frequently develops water leaks into the trunk area and that can cause an assortment of issues. Probably the worst is when it gets into the connector for the HV pack fan and corrodes it. You may want to look down next to (or under) the 12V battery and the similar depression on the other side to see if there is evidence of water pooling there.
I would get another new fob from a dealer asap. If yours goes bad or is lost, its an expensive repair at a dealer. A user's or most shop's Techstream, legit or not, can not fix it.
Touring models have (small - ineffective) fog lights & HID headlights. Non-touring models have no fog lights and halogen bulb headlights. Does your car have the Smart Key system (SKS)? Small black rubber "buttons" on both front door (exterior) handles. Rubber button on the exterior tailgate trim panel. 2 buttons underneath the steering column - dash area (1 - "TPMS", 1 - SKS). The Toyota logo on the fob is chrome (not black). If you do have SKS and it doesn't work then the fob could be damaged (does the small red LED flash when you push a button?), OR that's a used fob that was only programmed to work in the dash slot (that uses a passive RFID chip in the fob shell) The active SKS and remote lock functions use the battery powered circuit board. If you don't have a fully functional SKS fob, then you need a dealer or capable locksmith to program new (correct) fobs to the car. (Or search DIY methods - there's something about "seed code" generator on some website in Europe to reset the car's immobilizer ecu via a dealer level scantool). Any other scantool or (chicken dance) method requires a fully functional SKS fob. Posted via the PriusChat mobile app.
No offense meant, but in my opinion your money would have been better spent on his current car in for repairs. Good luck
