check engine light + soft whirring noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Danica, Jul 30, 2026.
  1. Danica
    Danica Junior Member
    44
    LOL... maybe I';m a little too jumpy these days after the week I've had (my phone broke the same day the check engine light came on) but the sound is definitely different than what I'm used to hearing from this car. And right now, anything different feels like a bad thing.
  2. saneesh8
    saneesh8 Member
    238
    57
    Allen, TX
    Open the hood and listen for this noise. The brake actuator sound will be coming under the windshield area. The coolant pump and all are close to the front of the car.
    Danica likes this.
  3. Dennis Brown
    Dennis Brown Junior Member
    33
    Baltimore County
    Three Touring
    If you want to determine the life/state of the hybrid battery, use the Dr. Prius software and a proper OBD II doogle interface for a reading the data by a phone. Useful for controlling the hybrid fan, as well. Then test the battery following the instructions. It will tell you what you need to know about that battery.
    As for the ABS system, if no codes, why replace it? Wait for codes to show. I assume the brakes are working fine - that is an easy test if in doubt.
    The inverter coolant pump is easy to tell if working. Remove the coolant cap (for the inverter coolant, NOT the radiator!) You should see motion of the fluid. If not, the pump isn't working.
    Definitely, if the valve was still bad, the code should quickly return.
    Danica likes this.
  4. Danica
    44
    Thank you very much for the advice. I am not very well-versed in car mechanics, so your first sentence is all Greek to me. Though it sounds like a great idea, if I can find someone with the know-how to do it.
    I've been trying to educate myself on all this, but from what I've read, if the brake actuator is going off every five seconds, that's a pretty strong sign it's going to fail in the not-too-distant future. The pump is constantly pumping to keep the brake fluid pressure up, right? I'd prefer to get this taken care of before it reaches a critical stage. And it doesn't seem clear how much more time I have before it reaches the critical stage.
    I'm pretty sure I had the inverter pump replaced last year, along with the 12-volt battery. There are so many pumps on this car it's hard to keep them straight sometimes, but I'm pretty sure it was the inverter pump.
  5. Dennis Brown
    33
    Baltimore County
    Three Touring
    The car has a ODB II port under the dash on the drivers side. It is easy to see if you look where the photo shows in your car, you'll see it.
    Danica likes this.
  6. Dennis Brown
    33
    Baltimore County
    Three Touring
    You buy the dongle that plugs in that works for Dr. Prius (their web site explains details) and it shows the hybrid batter charge and many other details on your phone. If you pay for their software upgrade (about $15) to add to their free software, you can test the hybrid battery's condition. They have examples online to watch on youtube.
    By testing the hybrid battery, you'll then know its performance/life-time and if that is an issue that will cause problems sooner rather than later.
    Danica likes this.
  7. rjparker
    11,103
    6,967
    No, the brake actuator/booster/master cylinder pump does not normally run constantly.
    When it was new and for years later, you might hear it when you approached the car or touched the door handle for the first time each day.
    When it runs every 3-5 seconds or keeps running you might be closer to a brake booster replacement. It is not cheap, maybe $2,500 installed at a dealer or a quality independent shop, primarily because there are no rebuilt or aftermarket alternatives.
    For most of the population who don't know an obd2 port from a brake booster, the best thing to do is to spend a little at the dealer or quality independent hybrid shop for a diagnosis. Without warning lights, this is for your own peace of mind.
    Then come back for recommendations for budget options before paying a dealer to repair. This step is important because a dealer may offer unnecessary "preventative" services like fuel system cleaning, alignments or early fluid changes.
    Danica likes this.
  8. bisco
    52,855
    I've always heard the brake pump as a buzzing noise
    Danica likes this.
  9. Danica
    44
    Maybe there's a fine line between buzzing and whirring. It's softer from inside the car. Believe me, I would be thrilled if the noise was being caused by something else. But I listened to several different videos of Prius engines making noises, and on the videos that sounded like my car, most people in the comments were saying that's the brake actuator.
  10. rjparker
    11,103
    6,967
    All you have to do is open the hood and see if the noise is coming from the driver's side under the windshield-wiper.
    Danica likes this.
  11. Danica
    44
    The conf
    Thanks. I'll give it a try in the morning, though the configuration of my car's engine looks a little different from yours.
  12. rjparker
    11,103
    6,967
    Here is a gen2 engine with hidden brake booster area highlighted.
    Danica and Dennis Brown like this.
  13. saneesh8
    saneesh8 Member
    238
    57
    Allen, TX
    Looks so clean.. almost brand new..
  14. Danica
    44
    Thank you very much for the additional info and picture. Sorry I took so long to respond. Last week I was stressing out over a doctor's appointment and I needed to just not think about the car issue for a few days.
    I've been trying to listen, from both inside and outside the car. I think the sound is coming from the driver's side, but it is hard to be certain. From inside the car it's quite soft, from outside the car it's quite loud, and either way it seems to reverberate all across the front of the car.
    For whatever it's worth, and I don't know if this has anything to do withh our exceptionally hot and humid weather, but I noticed a couple of new sounds after I shut off the car. If I am parked on an incline, I hear a distinct sloshing noise right after I turn the car off. And a couple of times, about a minute or so after turning off the car, I heat a brief little tooting noise, like somebody is blowing a horn.
    In any event, everyone here has been very helpful and I am grateful to all of you. I guess I'd better start making some phone calls soon, what the mechanic shops in my area have to say about this.
  15. ChapmanF
    19,025
    An auto parts store will have a thing called a mechanics' stethoscope, maybe around five dollars, with ends you put in your ears and a long rod you can touch to various things under the hood, and you'll quickly pinpoint the source of the sound.
    If there's no mechanics' stethoscope around, a long stick or screwdriver can work nearly as well, with one end touched to something you want to hear better, and the other end pressed to the bone under your ear.
    Danica likes this.
