No "how-to" head gasket posts for a Gen4?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by C Clay, Jul 26, 2026.
Tags:
  1. BiomedO1
    4,606
    2,416
    Left Coast
    That's not a definitive test; since that could simply be condensation in the exhaust system from last night. That's more like an "old wives tale test" to tell yourself your correct.
    Do whatever you want; since it's your time and money. You've been given the proper procedures to verify a head gasket problem.o_O:(:sleep:
  2. C Clay
    C Clay Member
    407
    Lexington, KY
    2019 Prius
    L Eco
    You ask a good question- does it death rattle? Nothing death rattles like the gen 3- so no. Misfires reported only scanner app- yes.
    As far as the coolant hoses that I bypassed- I have a picture up there. How else does the coolant enter the exhaust? I’m asking because I don’t know.
  3. C Clay
    C Clay Member
    407
    Lexington, KY
    2019 Prius
    L Eco
    I appreciate everyone’s perspective and help- It’s not that I’m not doing those tests to rule out that it’s a head gasket -rather I keep trying to figure out how to do the head gasket if that’s my next step.
    If the head exchanger has already been bypassed- what else could it be?
  4. Bill Norton
    Bill Norton Senior Member
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Isn't there a EGR cooler in a Gen4?
    That EHR is for quick warm ups of the coolant, no? And not related to the EGR system, no?
    Yeah, so start testing.
    What happens if you leave 15 psi on the coolant system overnight? Does it lose pressure? Does it lose coolant?
    BiomedO1 likes this.
  5. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    So you are saying it starts and sounds fine?
    You get a code for what kind of misfire? But don't notice any problems,, other than that steam cloud coming out the back?
    C Clay likes this.
  6. C Clay
    C Clay Member
    407
    Lexington, KY
    2019 Prius
    L Eco
    Hey Bill, thanks for asking. I really do appreciate the collaboration here. To me, it drives excellent. I get 53-60 miles to the gallon on a very easy 60 mph 100 mile round trip drive to work. I drove it about 1200 miles on a trip two months ago and I feel like that was when all of this started; could be wrong.
    Big difference in gen 3 is, I don't notice a "rattle". Maybe once or twice; but usually I get in it, go in reverse out my drive way and then typically take off on a 50 mile drive. I might feel some misfiring around 1100 rpm as I exit the neighborhood
    • Estimating (loses about 8 oz of coolant a day)
    • Only really notice the white smoke if I start in maintenance mode (otherwise I'm driving). Haven't really noticed it from a start at a red light, etc.
    • See a snotty, milky substance in the oil cap
    • I think I spot some carbon in the coolant reservoir. See photo. I noticed this really bad in my last gen 3.
    • Never a check engine light, I just use "Car Scanner App". I have had an occasional inactive misfire code, and an occasional P148F code.
    • I bypassed the Heat Exchanger almost as soon as bought it 15,000 miles ago. I could smell and see coolant coming out the exhaust. I bypassed it at the bottom.
    Not to act like we are solving a mystery here with abstract clues- but a little on the history of the car. Two owner car. Car fax reads that Toyota dealer did a "pre-delivery inspection" 10/2025. From 9/25 to 12/24 - it was driven 75,000 miles! Approx 270 miles per day for 279 days- wow! I believe the car was used for the dealership or some other fleet service, it was really only ever serviced at Toyota or a chain tire shop.
    One might could guess, the heat exhanger was failing- perhaps it overheated during the long days of fleet service.
    I bought this in Nashville, I live in Lexington. I did try to reach out to the dealer about the vehicle prior to buying it and emailed them the VIN,etc. All they said was "we'd love to do a prepurchase inspection with you- please bring the current owner and you to the dealership, and we will inspect it for $200 and give you a rundown of any recommended service".
  7. BiomedO1
    4,606
    2,416
    Left Coast
    A guy in the UK with a high mileage gen4, got a partially stuck open EGR valve. No coolant leaks, admitted he didn't change the coolant with more than 250K on the clock; but the ECU pointed directly to that bad valve - No CEL, just that error sitting in the buffer. He was experiencing hesitation during acceleration which makes sense; since these lean burn car's mixture is so precise and the ECU would compensate for the knock that was occurring under those circumstances.
    YMMV
  8. Mendel Leisk
    42,349
    Again, per post #4, I'd suspect previous owner ran the engine out of coolant a time or two, and head gasket has failed.
    BiomedO1 and C Clay like this.
  9. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    And yet,,dah, dah, dummy,,,, The Mystery continues...(n)
    I would try to figure out where that coolant is going. Borrow a coolant pressure test kit and let it sit for hours, or overnight.
    If it leaks some into a cylinder or two there would be noise and a misfire at start up until the coolant is passed.
    It shouldn't be getting coolant into the oil if it's not getting into a cylinder. But that stuff on your oil cap is a small clue maybe...:whistle:
    A crack in the exhaust gas-to-coolant heat exchanger is a possibility. Haven't looked at that for a Gen4 yet.
    Good luck. I'd do some testing before going for the gusto with a head gasket replacement.(y)
    C Clay likes this.
  10. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    But check it hourly at first. You don't want to send so much coolant into a cylinder that you can get hydro lock at start up.
  11. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    I watched one of those 'Pro' guys doing a head gasket on my Gen3.
    As soon as the head is off the piston height to block deck is measured to see if there is a bent rod from a hydro lock incident.
  12. C Clay
    C Clay Member
    407
    Lexington, KY
    2019 Prius
    L Eco
    Just an update on what I’m experiencing here. I took a look at the car yesterday and started pulling some things off just to see how similar it was to the GEN three. I didn’t get very far, I just got down to where I could see the throttlebody and I cleaned it.
    Put the car back together and as I was driving 50 miles to work at 90 degrees out, it got hotter than it really ever gets- like 204.3 going up a good incline (scanner app). That’s not necessarily caused for Alarm, I’ve only seen it ever get to 206 or 207 and that was in the mountains.
    I get to work and find there is no coolant loss! I’ve done nothing really except clean the throttlebody and check a few spark plugs.
    However, at 4 AM I drive home, the same drive I’ve taken for years and when I get up this afternoon, I’ve lost probably 8 to 12 ounces of coolant…. Somewhere.
    It’s definitely coming out of the weep hole at the top of the reservoir. And I feel like in the cabin, you can smell coolant a couple of minutes after you start off on your drive to work-the conditions are that maybe you get the RPMs up to 3500-4000 and that’s when it occurs I’m guessing. You can’t really duplicate that in maintenance mode, it seems to top off around 2000-2400 if I recall correctly.
    I’ll do a couple of tests that everyone is suggesting, I think the exhaust gas in coolant test- I’ve done that before I don’t have one of those kits, but I’ve also read that’s not always conclusive on the Prius for some reason or another.
    I understand what you call the “leak down” test if I am stating that right- that’s where you pressurize a cylinder to 15 psi and look for leaks/ pressure loss over time?
    The only thing I wonder here, though there was a YouTube video where someone indicated the kit that you can rent at most stores like AutoZone doesn’t actually include the correct size for the Prius, the correct cylinder adapter. Can anyone speak to this?
  13. BiomedO1
    4,606
    2,416
    Left Coast
  14. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Not exactly...(n)
    There are two different 'Leak Down Tests':
    >One for the coolant system where you use the tester cap on the reservoir and pump it up to 15 psi.
    >Another for individual cylinders where you put 80-120 psi in that spark plug hole, BUT,,, you must hold the crank at TDC for each cylinder being tested.
    I've never done this with a car engine. I've seen Dave's on YT do it a lot to listen for intake or exhaust or piston ring leakage.
    I assume they use a breaker bar on the crank nut and slowly add pressure while one guy finds the 'feel' for TDC. Don't let go..!!
    It's done routinely on airplane engines where one tech just holds the propeller at TDC. It takes no effort once you 'feel' TDC.
    This is to test leaking valves or rings in engines,,,, or in your case, leaking into the coolant system and pressurizing it.
    So you'd need to have the coolant test kit on the reservoir during the cylinder leak down testing.
    I think that while the engine is running the combustion gasses push through the head gasket into the coolant.
    Then, at shut down and cool down that 15 psi in the coolant system pushes the coolant into the leaking cylinder.
    But that typically leaves coolant on top of a piston that must be cleared at the next start up, which = clatter, knock, misfire and steam mist coming out of the exhaust.
    You say you don't have that situation. Only extended steam production,, which leads me to believe the other way this can happen is a leaky EGR cooler. The coolant gets into the cooler and slowly gets consumed post combustion.
    Good Luck (y) You got a weird one.o_O
  15. C Clay
    C Clay Member
    407
    Lexington, KY
    2019 Prius
    L Eco
    I’m referring to #1 that I want to do, and am wondering if the standard rental from AutoZone has all parts needed.
  16. C Clay
    C Clay Member
    407
    Lexington, KY
    2019 Prius
    L Eco
    My work schedule (I’m a manager at that large global company where we order things like head gaskets from lol) is a crushing four days, and then 3 days of laying around wondering about your life choices .. those three days are up- so I’m about reqdy to tackle this.
    It seems clear that the only coolant escaping are from the reservoir relief hole and burning in a cylinder, not the heat exchanger. I’ll do the tests- but all signs point to head gasket.
  17. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Walk in with your coolant cap (y)
  18. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Ha ha.,, hang in there. A Gen4 is so much nicer than a 3. It'll be worth it. (y)
    I'd check to see if Felpro makes a replacement head gasket. On the 3's they have been reliable,,, so far.
    Do you really want to use the same brand that failed on you?
    On one of my 3's HG failure it was blowing out the reservoir overflow after a fast Rockie Mnt climb.
    Do you have a borescope to look in a cylinder? Be careful not to push too much coolant into the bad cylinder.
    I still don't know why you don't get a rattley , misfire start up. ..(n)
    Give it hell !!(y)
  19. Mendel Leisk
    42,349
    A reasonable reaction, but I’m sceptical it’s a head gasket shortcoming that’s causing the failures, on third gen, suspect it’s more likely protracted, unaddressed carbon clogging of the EGR system, and engine overheating . On 4th gen, I’d suspect an engine again overheating, due to being run dry of coolant, due to neglected coolant loss at exhaust heat recovery system.
    #39 Mendel Leisk, Aug 11, 2026 at 6:29 AM
