Replace rear drums and brake pads or not?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lento47, Aug 9, 2026 at 3:10 PM.
  1. Lento47
    Lento47 New Member
    Colorado
    As mentioned in another post, just replaced front pads and rotors on my 2009 Prius.
    After test driving, braking with the brake pedal was mostly fine, except for a squeak from the back as the car came to a stop.
    So I cleaned the drum brakes. Then did another drive test. This time, there was no squeak, but I discovered that if I pulled the ebrake from just 5mph, the rear brakes squealed loudly (only when going forward, they didn’t squeal going in reverse). So I investigated further.
    With rear up on jack stands and tires off, turning the drums by hand I discovered that both have a drag/sticky point or two across the rotation when I had the ebrake clicked in 4-5 clicks (ie there were spots of resistance as I rotated them, then easy turning). When I got to 7 clicks they were solidly locked and couldn’t rotate them, which is expected.
    I sanded the pads lightly to remove any glazing, but sticking points remain when I rotate by hand. I’m guessing I have one or two ‘high’ spots in the drums themselves.
    I thought the rear drums were supposed to be good for ~ 150,000 - 200,000 miles. Is this normal to have high spots in the drums at 85,000 miles (and again, it's an 2009)? And is this ok? There were no squeals during normal braking, just when engaging the ebrake. But clearly they are not perfectly round now. Or are these sticking points and ebrake squeal a solid indicator that the drums must be replaced? (I’ve seen elsewhere that replacement is a better option than machining as it’s not that much more.)
    Thanks!
  2. BiomedO1
    4,610
    2,416
    Left Coast
    Don't take this the wrong way; but it sounds like your don't know what your doing and watching YouTube videos to figure it out.
    As a "rule of thumb", the rear needs to get done on the second set of pads placed on the front. That DOES NOT overrule what you find on an inspection, since people forget to release their parking brakes and wear them out that way. IMHO; 7 clicks is excessive - to me 4-5 clicks should be FULL lock; if those rear shoes was adjusted properly.
    Please read-up on theory of operations of a rear shoe set-up and measure to see if it needs replacement. There are OEM specification for replacement intervals for that. NO guessing involved. Squeaks are merely a symptom, NOT a root cause for replacement. Any tire & brake shop will gladly take your money for a full overhaul; when dumping out the accumulated brake dust and cleaning the mechanism will cure that symptom.
    YMMV
  3. Mendel Leisk
    42,349
    Repair Manual info:
  4. Tombukt2
    13,864
    2,519
    That's how they work they go around hit a high spot go around hit a high spot that's just normal because the pads are two pieces not a perfect circle and so on you want them adjusted tightly. The Prius likes a good drag on the rears it will finish the adjustment two minutes after you head down road. Used to be in the old days you used a fish scale to set drag . It was a thing . Look in a 83 Corolla or Celica manual
  5. BiomedO1
    4,610
    2,416
    Left Coast
    LoL; fish scales would really smell-up the shop. I just adjusted the star wheel until I could hear and feel the shoes intermittently touching. After that adjustment; a test drive would settle everything into place and the parking brakes would actually be useful.:cool:
    I've watched kids adjust parking brake cables without looking at the rear brakes FIRST. A rookie/AI move.:cry::(o_O Garbage in - Garbage out; addressing the symptom NOT the underlying problem. :whistle:
  6. Lento47
    Lento47 New Member
    Colorado
    Yes, thanks Biomed01, this is the first time I’ve worked on drums (no offence taken)! Unfortunately the mechanic I used to use and trust has retired, so was attempting this myself. Was trying to avoid being taken by, as you say, a complete overhaul when all it needed was a good cleaning, as this is indeed the first pad/rotor change on the front (the rotors were excessively rusty, so went ahead and changed them too).
    On my first go with cleaning the rear drums, I did not remove any parts, just used cleaner to remove the dust. But since that didn’t fix the squeal, I pulled out the star adjusters to better clean them. And yes, upon reinstall, likely didn’t set them tight enough.
    As I mention in my reply to Mendel, I have read the brakes section of the manual. Is there another reference that helps with rear drum theory of operations? And I don’t have a measurement caliper, so was going from observation and testing. From what Tombuk2 commented, sounds like having some high spots is not that unusual and may not be the source of the squeal. Maybe just didn’t have stars set tight enough after cleaning?
    Unfortunately, when I reinstalled the star adjusters after giving them a good cleaning, I pushed the drivers side cylinder too far over and got a little leakage into the dust boot (I discussed this here: Rear drum brake cylinder leak after push through | PriusChat).
    So I’m planning to replace the cylinder next. Then reassemble and do a better job on tightening the star adjusters, do a bleed, then see how it functions.
    Do you have any tips on setting the star adjuster properly?
    The manual says to use the backplate hole, expand the shoe until the drum locks, then back off the adjuster 8 notches. AND, I’m having a hard time using that backplate hole, difficult to get in there and see what I’m doing.
    So instead was tightening the adjuster a few clicks at a time with drum off, then putting the drum back on and seeing how much drag it has. To get the final snugging up, I’ve read elsewhere to press the ebrake 10-20 times. Is this not sufficient?
  7. Lento47
    Lento47 New Member
    Colorado
    Thanks Mendel, I have read that manual, but I don’t have the measurement caliper. I could see some shiny spots on the drum surface, and as I mention, when I rotate by hand can feel the sticky points, so that’s how I concluded there are ‘high spots’.
  8. Lento47
    Lento47 New Member
    Colorado
    Thanks. You mention, “The Prius likes a good drag on the rears it will finish the adjustment two minutes after you head down road.”
    I thought the Prius final adjustment was done by pressing the ebrake several times to engage the self adjuster mechanism. Is that not correct? Does normal braking (also or instead) automatically adjust the star adjuster?
  9. BiomedO1
    4,610
    2,416
    Left Coast
    If assembled properly; the auto adjuster tab will PREVENT reverse rotation of that star adjustment; unless you lift that adjustment tab. Lifting the adjustment tab can't be done with the drums ON. You can't and you shouldn't be able to pull the drum back off - now that the shoes are fully applied against the drum. Something was lost in translation and that technical writer is incorrect; because you noticed that picture is with the drum OFF - so I don't know how you would press the shoes against the drum with it OFF.
    Buy some old retired mechanic lunch and have him check your work, because it doesn't sound like you've got it assembled properly; if you can back-off 8 clicks. BTW; those click are from that one way auto adjuster - again shouldn't allow reverse rotation of that star adjuster when properly assembled. I haven't done a drum brake in more than a decade; but I don't think the mechanism has changed in that time.
    I've seen kids and amateurs mangle those auto adjuster and render them useless and nonfunctional.
