Rear drum brake cylinder leak after push through
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lento47, Aug 7, 2026 at 6:18 PM.
  1. Lento47
    Lento47 New Member
    Colorado
    Finished doing a front brake job (pads and rotors) on my 2009 Prius, then noticed the backs were a little squeaky, so pulled the drums off and did a thorough cleaning (they were very dusty). I also pulled the components (brake pad brackets, star adjuster), particularly to clean the star adjusters. When reassembling the Drivers Rear drum, after finally getting the main spring (around the star adjuster) back on, I saw that I had inadvertently pushed the cylinder/piston all the way forward (though not enough for the end caps to come off). I re-centered the cylinder/piston and then pulled back the cylinder end covers to inspect and found fluid in the rear one. It dripped a tiny bit and I quickly put the end cap back on.
    Note, I pulled the battery (-) and also the relays for all this.
    Could I have permanently damaged the internal cylinder seals?
    I plan to remove the rear end cap again and sop up/ remove any fluid in the cap, dry off, then reinstall. Then reassemble/put the drum back on and try pumping the brakes, then reinspect for fluid leaking.
    I assume that if it leaks after testing, I need to replace the cylinder.
    But if it doesn't continue leaking, am I good to go?
    or perhaps do a bleed on that line to be sure no air got in?
    Or do I need to replace that cylinder now either way?
    It's a 2009, but only 85,000 miles, and as far as I know, these are the original rear drum brake cylinders.
    Any advice would be welcome!
    Thanks!
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Back in the 80's seemed like every old car had a problem like this... So much so that most mechanics wouldn't start working on brakes on an old car unless that part was nearby. But first time I've read about it in a Prius. Sounds like a minor leak was there but made worse when cleaning?
  3. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    When you go to put the spring back on it's easy to make one side of the SHOe to cylinder assy. Can get missligned and this happens. You also have to adjust the rear shoes way out so that they're scraping the drum everything has to be correct or piston will. Pop out enuff to leak .
    PriusCamper and BiomedO1 like this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,598
    2,412
    Left Coast
    I never do a tear-down cleaning of drum brakes; unless I'm replacing the shoes. It gets brake clean spray down and grease on the shoe to back-plate rub points. Drum gets put back on and star adjuster is cranked out until it scrapes the drum during rotation. That's usually all it needs. You'll find your manual parking brakes works much better after making that adjustment.
  5. Lento47
    Lento47 New Member
    Colorado
    I went back in and removed the rear end cap and sopped up the little fluid that was there and wiped off the inside of the dust cap to remove any fluid. Reinstalled the drum. Reconnected relays, battery. Bled a little fluid off that wheel (got a couple of small bubbles).
    Started the car, pumped the brakes several times, and ebrake, to make sure everything was seated and receiving pressure well. Then disconnected the battery, relays, removed the drum.
    There was a tiny bit of fluid in the end dust cap.
    So back to my original question….. do I need to replace that cylinder?
    Or is it normal to have a tiny bit of fluid in there?
    The whole point of cleaning/servicing the rears was they were squeaking really loud when the ebrake was applied from 5mph.
    Would it be safe to put the wheels back on and give it a test drive to see if the squeak is gone now? Or with this little fluid in the end cap, is that a really bad idea?
    If it’s still squeaking I’d be inclined to go ahead and replace the brake pads and drum if I have to remove everything anyway to replace the cylinder.
    Thanks!
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    If the piston traveled "too far" back (and leaks) then the piston seal is likely damaged. I would replace the cylinder.
    I seldom see drum brakes at work (not as popular anymore) but for the past 30 years - any work on drum brakes got new cylinders - period.
    There's usually sediment or corrosion in the cylinder bore. Moving the pistons around forces the seal to ride on rough or "dirty" surfaces & results in leakage. That's unacceptable to have fluid leaking into your brakes a few months after replacing the shoes.
    The problem now is that drums are so rare that the only aftermarket cylinders are (cheap) low quality imports. This is another instance where I only use OE Toyota parts.
  7. Tombukt2
    13,861
    2,519
    Durham NC
    If the Piston pops out you're holding this round piece of green aluminum generally with a rubber seal around it which angled . You will wet with brake fluid and stick it back in the hole make sure spring is in there nothing is damaged in my unit at all it just pops out . It's a wheel cylinder there's two things that can pop out it's just the way it works anyhowwww
  8. Lento47
    Lento47 New Member
    Colorado
    When replacing the cylinders, any tips or tricks for reinstalling the brake pad brackets and finally the star adjuster and main spring? This last part is the hardest, to pull that spring across into the hole is a bear.
    Is there a way to secure the cylinder pistons so they don’t travel when getting the spring in? Maybe put a zip tie across them and the cylinder housing? Other ideas?
