Seeking new screen with Android Auto - 2012 Prius
Discussion in 'Gen 3 Prius Audio and Electronics' started by MattFL, Apr 14, 2026.
  1. MultiPrius
    MultiPrius Junior Member
  2. Tombukt2
    13,875
    2,521
    I've used a few I have not used any that are installed permanently in the car that replaced that big piece of plastic on your dash I'm using dash top under dash etc . They all basically mirror your phone so you need a god phone to use all the features etc . I have a built in in a 2007 it's a soundstream vddr7 or some such number 7 inch in dash no flip etc . It too works very well has a very decent screen no complaints has more audio adjustments than ya want .
  3. MattFL
    MattFL Member
    195
    58
    As best I could tell: the cheap ones all seemed to have caveats. A common theme was sometimes being unresponsive, taking a long time for the backup camera to appear, etc.. basically sounded like you get what you pay for. But oddly, many of the cheap chinese ones seemed to come with everything necessary to work in a Prius, including working with the OEM backup camera.
    On the flip side, the expensive brand names seemed to have excellent reviews, and the prices for the main unit were reasonable ($400-$500-ish), but for whatever reason they don't come with all the necessary parts to work with a Prius. So by the time you buy the parts to make it work with the steering wheel controls, backup camera, etc.. you're in it for $800+, plus it was a PITA trying to figure out what the correct mix of parts were. So in all that ended up being more hassle and more than I wanted to spend. So at the end of the day, I bought a new digitizer from eBay for $20 delivered, and now the OEM screen is back to working fantastic. ;)
    Regarding the wife ultimatum: we ended up getting a camper, completely unrelated to the Prius, but that seems to have satisfied the need for a new car, for now. :D
  4. amarino
    amarino Active Member
    146
    107
    99
    I went the Crutchfield route in 2024 and yes it was pricey for all the extra "stuff" needed, but it was almost 100% plug and play except for 1 connection I had to crimp. Steering wheel controls and backup camera worked out of the box and I have not had any issues in the last 2 years. Link for reference: Radio Upgrade to Pioneer DMH-WT3800NEX | PriusChat
    I think a lot of the extra "stuff" is because of how modern cars are integrated that you need the control box to translate from the radio to the car for steering wheel controls / backup camera / car settings (can still change the lock / unlock / etc settings like you could from the original radio). If it wasn't for all these and just ran wires to each speaker it would be much more simple.
    I also have a 1990 BMW and was doing a radio upgrade in there and in that case all I needed was the radio and a handful of wires for power / standby / ground / illumination / 4x speaker connections.
    ASRDogman likes this.
  5. MattFL
    MattFL Member
    195
    58
    Thank you for the link, this is excellent info!
  6. Patrick Wong
    18,213
    6,530
    Over the past weekend, I installed this unit in my daughter's 2015 Prius:
    Amazon.com: BINIZE Carstereo Android 13 Radio Compatible with Toyota Prius 2010-2015 | Carplay Android Auto, 9 Inch Touchscreen Head Unit Bluetooth GPS SWC RCA Back Camera : Electronics
    It works well, not quite as smooth as the Apple CarPlay which is an original equipment feature in my BMW Z4, but it works well enough considering the $170 price. You would be giving up the CD player and AM radio. This aftermarket unit has a very good FM stereo receiver with 18 station presets.
    If you are interested in this, look at this YouTube video which provides great instructions. Bing Videos
    The vendor does not provide very good installation instructions so you definitely will need help via YouTube.
    Following are photos of the original equipment radio/CD player, then plastic trim removed, then the hole in the dashboard with radio/CD player removed, and finally the new electronics.
    The original rear view camera is supported. Pay attention to the YouTube video as it explains the various wiring harnesses and how to connect them up.
  7. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    The MOST important thing is, does SHE like it??? The rest doesn't matter!
    Patrick Wong likes this.
  8. Patrick Wong
    18,213
    6,530
    She is thrilled with how it works. The only issue is that sometimes she has to turn off Bluetooth on her phone, then turn it back on and connect to the new electronics unit, to get Apple CarPlay to start.
  9. Tombukt2
    13,875
    2,521
    All of them seem to have carplay problems but not Android issues . With similar features .
  10. rjparker
    11,132
    6,982
    I think its because the aftermarket unit operating system is based on Android.
