Replace rear drums and brake pads or not?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lento47, Aug 9, 2026.
  1. Lento47
    Lento47 New Member
    Colorado
    As mentioned in another post, just replaced front pads and rotors on my 2009 Prius.
    After test driving, braking with the brake pedal was mostly fine, except for a squeak from the back as the car came to a stop.
    So I cleaned the drum brakes. Then did another drive test. This time, there was no squeak, but I discovered that if I pulled the ebrake from just 5mph, the rear brakes squealed loudly (only when going forward, they didn’t squeal going in reverse). So I investigated further.
    With rear up on jack stands and tires off, turning the drums by hand I discovered that both have a drag/sticky point or two across the rotation when I had the ebrake clicked in 4-5 clicks (ie there were spots of resistance as I rotated them, then easy turning). When I got to 7 clicks they were solidly locked and couldn’t rotate them, which is expected.
    I sanded the pads lightly to remove any glazing, but sticking points remain when I rotate by hand. I’m guessing I have one or two ‘high’ spots in the drums themselves.
    I thought the rear drums were supposed to be good for ~ 150,000 - 200,000 miles. Is this normal to have high spots in the drums at 85,000 miles (and again, it's an 2009)? And is this ok? There were no squeals during normal braking, just when engaging the ebrake. But clearly they are not perfectly round now. Or are these sticking points and ebrake squeal a solid indicator that the drums must be replaced? (I’ve seen elsewhere that replacement is a better option than machining as it’s not that much more.)
    Thanks!
  2. BiomedO1
    4,641
    2,434
    Left Coast
    Don't take this the wrong way; but it sounds like your don't know what your doing and watching YouTube videos to figure it out.
    As a "rule of thumb", the rear needs to get done on the second set of pads placed on the front. That DOES NOT overrule what you find on an inspection, since people forget to release their parking brakes and wear them out that way. IMHO; 7 clicks is excessive - to me 4-5 clicks should be FULL lock; if those rear shoes was adjusted properly.
    Please read-up on theory of operations of a rear shoe set-up and measure to see if it needs replacement. There are OEM specification for replacement intervals for that. NO guessing involved. Squeaks are merely a symptom, NOT a root cause for replacement. Any tire & brake shop will gladly take your money for a full overhaul; when dumping out the accumulated brake dust and cleaning the mechanism will cure that symptom.
    YMMV
  3. Mendel Leisk
    42,381
    Repair Manual info:
  4. Tombukt2
    13,879
    2,521
    That's how they work they go around hit a high spot go around hit a high spot that's just normal because the pads are two pieces not a perfect circle and so on you want them adjusted tightly. The Prius likes a good drag on the rears it will finish the adjustment two minutes after you head down road. Used to be in the old days you used a fish scale to set drag . It was a thing . Look in a 83 Corolla or Celica manual
  5. BiomedO1
    4,641
    2,434
    Left Coast
    LoL; fish scales would really smell-up the shop. I just adjusted the star wheel until I could hear and feel the shoes intermittently touching. After that adjustment; a test drive would settle everything into place and the parking brakes would actually be useful.:cool:
    I've watched kids adjust parking brake cables without looking at the rear brakes FIRST. A rookie/AI move.:cry::(o_O Garbage in - Garbage out; addressing the symptom NOT the underlying problem. :whistle:
  6. Lento47
    Lento47 New Member
    Colorado
    Yes, thanks Biomed01, this is the first time I’ve worked on drums (no offence taken)! Unfortunately the mechanic I used to use and trust has retired, so was attempting this myself. Was trying to avoid being taken by, as you say, a complete overhaul when all it needed was a good cleaning, as this is indeed the first pad/rotor change on the front (the rotors were excessively rusty, so went ahead and changed them too).
    On my first go with cleaning the rear drums, I did not remove any parts, just used cleaner to remove the dust. But since that didn’t fix the squeal, I pulled out the star adjusters to better clean them. And yes, upon reinstall, likely didn’t set them tight enough.
    As I mention in my reply to Mendel, I have read the brakes section of the manual. Is there another reference that helps with rear drum theory of operations? And I don’t have a measurement caliper, so was going from observation and testing. From what Tombuk2 commented, sounds like having some high spots is not that unusual and may not be the source of the squeal. Maybe just didn’t have stars set tight enough after cleaning?
    Unfortunately, when I reinstalled the star adjusters after giving them a good cleaning, I pushed the drivers side cylinder too far over and got a little leakage into the dust boot (I discussed this here: Rear drum brake cylinder leak after push through | PriusChat).
    So I’m planning to replace the cylinder next. Then reassemble and do a better job on tightening the star adjusters, do a bleed, then see how it functions.
    Do you have any tips on setting the star adjuster properly?
    The manual says to use the backplate hole, expand the shoe until the drum locks, then back off the adjuster 8 notches. AND, I’m having a hard time using that backplate hole, difficult to get in there and see what I’m doing.
    So instead was tightening the adjuster a few clicks at a time with drum off, then putting the drum back on and seeing how much drag it has. To get the final snugging up, I’ve read elsewhere to press the ebrake 10-20 times. Is this not sufficient?
  7. Lento47
    Lento47 New Member
    Colorado
    Thanks Mendel, I have read that manual, but I don’t have the measurement caliper. I could see some shiny spots on the drum surface, and as I mention, when I rotate by hand can feel the sticky points, so that’s how I concluded there are ‘high spots’.
  8. Lento47
    Lento47 New Member
    Colorado
    Thanks. You mention, “The Prius likes a good drag on the rears it will finish the adjustment two minutes after you head down road.”
    I thought the Prius final adjustment was done by pressing the ebrake several times to engage the self adjuster mechanism. Is that not correct? Does normal braking (also or instead) automatically adjust the star adjuster?
  9. BiomedO1
    4,641
    2,434
    Left Coast
    If assembled properly; the auto adjuster tab will PREVENT reverse rotation of that star adjustment; unless you lift that adjustment tab. Lifting the adjustment tab can't be done with the drums ON. You can't and you shouldn't be able to pull the drum back off - now that the shoes are fully applied against the drum. Something was lost in translation and that technical writer is incorrect; because you noticed that picture is with the drum OFF - so I don't know how you would press the shoes against the drum with it OFF.
    Buy some old retired mechanic lunch and have him check your work, because it doesn't sound like you've got it assembled properly; if you can back-off 8 clicks. BTW; those click are from that one way auto adjuster - again shouldn't allow reverse rotation of that star adjuster when properly assembled. I haven't done a drum brake in more than a decade; but I don't think the mechanism has changed in that time.
    I've seen kids and amateurs mangle those auto adjuster and render them useless and nonfunctional.
  10. Lento47
    Lento47 New Member
    Colorado
    sorry for the double post, website keeps cycling on/off line
    #10 Lento47, Aug 22, 2026 at 7:12 PM
  11. Lento47
    Lento47 New Member
    Colorado
    Finally got back to this project (2009 Prius, 85k miles)… replaced both rear drum cylinders (used Advics parts) and bled the bubbles out.
    Would like some help with/ thoughts on setting star adjusters and parking brake operation.
    Star adjusters adjustment: with the drums off, I rotated the star using a screwdriver a few clicks at a time, then slid the drum back on to check for drag. After several rounds of clicking the star and checking fit, I got a faint swoosh noise/drag on the rotor and stopped adjusting. Drums pull off, go on without much effort, so feels like that is set ok.
    Then I reconnected relays and battery, turned car on to Ready mode and pumped brakes several times to make sure everything was seated ok, everything seems to be fine.
    Then was going to press parking brake a few times to trigger the self adjusters for the final tuning, but noticed on the first press that after only one click I could no longer turn the rear drums by hand. I’m getting about 5-6 clicks of total travel on the parking brake (though 6 clicks requires a little effort). The spec in the Manual says it should be 6-9 clicks of travel, so seems like it’s just there. When parking brake is released, both rear drums spin fairly easy by hand, with still that slight swoosh sound and tad bit of resistance.
    The fact that I’m only getting 1 click on the parking brake before the rears can’t be turned by hand seems odd, but can’t find any spec or description of what is expected for this.
    Is this a problem (and if not, leave it alone)?
    Or should I back off the star adjusters some amount of clicks (I know it doesn’t click when you rotate the star to compress the adjuster while holding off the lever/tab, I just mean the equivalent rotation you get from a click when expanding it)? I could always press the parking brake a few times afterwards to fine tune it.
    Or might this indicate something else is off?
    Thanks!
    @ChapmanF
    @hobbit
  12. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    It sounds like they are adjusted perfectly, I would leave it alone. If they are too loose, the brakes will self adjust, just as long as you always set the (foot operated) parking brake as part of the shutdown process. If you don’t use the parking brake, the self adjust does not work.
  13. Mendel Leisk
    42,381
    Drive a bit, then park where you do the maintenance, parking brake off, raise the rear till wheels are clear, and try giving them a spin. If they're difficult to even turn, or rotate less than a revolution, too tight?
  14. ChapmanF
    19,061
    You need both. Applying the parking brake more than one time in a row doesn't do any more than applying it once; normal braking more than once after releasing the parking brake doesn't do any more than normal braking once. It's the alternation of the two that adjusts the brakes, as described in more detail ➡here⬅.
    Just as Biomed01 explains, the self-adjusters are one-way ratchets. They only expand, to move the shoes closer to the drums. If you start with the shoe clearance too tight, the only way anything will "finish the adjustment" is by driving around with dragging brakes for as long as it takes to wear the shoes down to the right clearance. (After that, the adjusters will be able to expand as needed to maintain the right clearance, as long as the heat from all that driving around dragging hasn't baked all the lube.)
    Gen 1 had an oblong hole in the backing plate with a rubber plug in it, so you could pop the plug out and stick a screwdriver through to lift the adjuster tab (if you had a good-enough picture in your mind of how the insides are arranged to know where to point the screwdriver). You could also use a screwdriver on the starwheel teeth to click the adjuster outward. With two screwdrivers, you could lift the adjuster tab and spin the starwheel the other direction. Does gen 2 not still have that?
    BiomedO1 likes this.
  15. BiomedO1
    4,641
    2,434
    Left Coast
    I usually don't mention this; because inexperienced people usually end up mangling the self-adjuster tab. There's a drum/shoe measurement tool that gets the adjustment; "close enough" - so you don't spend all day fussing with it. I've probably used that tool about a half dozen times, about a decade ago. Hey; it came with the drum tool brake set.o_O:rolleyes:
    FWIW; it sounds like it's adjusted correctly. Take the car for a test drive; then pull over and place your hands on/near the center of the rear wheel. Make sure it isn't heating up; more than normal - that would indicate excessive drag. Compare with heat from the front wheels; they should be warmer, since most of your stopping power is there.
    Good Luck....
  16. Lento47
    Lento47 New Member
    Colorado
    Thanks for all the input!
    End of the day, I ended up backing off the star adjusters about 12 clicks, the parking brake was really tense all the way through the pull, so it felt over tight. But then went through several parking brake / brake pedal combos, like ChapmanF describes …. Now I’m getting a solid 6 clicks of travel, and if I really push, can get 7 clicks of travel.
    I tried the test drive that Biomed01 suggested, but the reality is I’m in the middle of the city and can’t drive a block without hitting the brakes. That being said, after 5 minutes I pulled over. Both front disks and rear drums were hot, but maybe the fronts were a little hotter. After it cools off, might take it out again and just a go block or two and check it.
    Took it out for about 45 minutes, gradually increasing the testing speeds…. got in on the highway a little too. No squeaks, squeals anywhere! Yea.
    Also pulled the parking brake from 5 and then 10 mph, no squeal! That’s what got me investigating the rears in the first place. In hindsight, I think the rears were way out of adjustment, so that’s why they were squealing. I got this car used, and it’s been maybe 55-60k since the brakes were serviced.
    As Mendel suggested, when I got home, I jacked up the rear again and both tires spin without drag.
    On a side note…. in the process of all this work, I’ve flushed a bunch of fluid from the front and rear lines and reservoir. However, I’d like to do the full official flush to get all the internal electronic pieces flushed out. I could go the route of getting a Techstream download and use a computer, but I really don’t want to be lugging a laptop around with the car for that. Does anyone know of a handheld/self contained scanner that can do the full official Toyota break flush that Techstream does (I think the term is a two directional scanner), and preferably, doesn’t require you bluetoothing to a second device (ie a phone or tablet. I’ve found several threads on this but the ones I’ve seen are a bit dated now (some devices are now longer around, and there are new ones), and I could never find any consensus on what actually works on the Gen 2 Prius.
    Thanks!
  17. pasadena_commut
    pasadena_commut Senior Member
    3,076
    956
    Southern California
    The Autel Maxi AP200 is said to be able to do that brake procedure to completion. I have not done so myself. Almost all of the MiniVCI cables people use with Techstream CANNOT do that brake procedure to completion. It is probably a bad idea to even try.
  18. Lento47
    Lento47 New Member
    Colorado
    Thanks. Yes, I had picked up on that issue with the MiniVCI cables.... saw several comments about cables not working....haven't identified one yet that will work for sure.
  19. BiomedO1
    4,641
    2,434
    Left Coast
    We're discussing rear manual drum brake assembly. The Autel may help for a brake fluid flush or bleed; but not the manual shoe adjustment.
    FWIW: I used to do manual shoe adjustment every 50K miles; because that star gear never properly adjusts the shoes spacing correctly - so you get excessive hand brake travel. Less noticeable for foot parking brake activation. o_O
  20. pasadena_commut
    3,076
    956
    Southern California
    Lento47 said:
    "However, I’d like to do the full official flush to get all the internal electronic pieces flushed out."
    So it seemed like the appropriate advice for that operation.
