My Method: "Pulse-Cruise / Neutral-Drive-Glide / Resume
Discussion in 'Gen 2 Prius Fuel Economy' started by Mister Swigart, Mar 4, 2007.
  1. livelychick
    livelychick Missin' My Prius
    1,085
    Central Virginia
    <div class='quotetop'>QUOTE(adam1991 @ Mar 7 2007, 02:10 AM) [snapback]401497[/snapback]</div>
    Thank you for clarifying your earlier post.
    Lone Ranger--thanks for the time you took to test out your new process. I appreciate the time you took in describing it to those of use who are interested! :)
  2. Mister Swigart
    Mister Swigart New Member
    37
    I would like to say thanks to those of you who took the time to read the vainglorious ramblings of an old man. (It's either Alzheimers or Mad Cow Disease, I think). The supportive words in spite of my guffaw were kind and human nature at its best. I hate to argue, respect the opinions of others, and like even less to ever make any enemies, but as an American, I don't cotton well to being told what to do or what not to do. The proper ettiquette on a forum is to raise a question, unless, of course one is purposely trying out for the roll of "Forum Troll." But I guess that's the only role left since I so aptly filled the part for the "Village Idiot." :rolleyes:
    Come on big fella" (to his trusty steed),
    The Lone Ranger
    Rides Again.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(The Lone Ranger @ Mar 7 2007, 09:55 PM) [snapback]402055[/snapback]</div>
    No worries, I kinda figured you weren't quite 'getting it' and I don't think anyone took offense. You're in a cool stage of your hybrid learning....it only gets better from here.
  4. Mister Swigart
    37
    Just a little update and a question about our Cruise Control . . .
    Well, since my last post, I have had an interesting week of cross-town drivings (25-45 mph) and at the end of each day I have not yet fallen below 51.0 mpg as a testiment to my little method.
    I agree with several of the commentors here, that the Cruise Control "Resume" calls for a rather aggressive acceleration back up to the preset. So, is there any way to adjust Cruise Control under the hood or anywhere so that it can be tamed a bit and rise a little more calmly. I feel I lose some of the gains I could have if it were more gradual. I have a hunch it is not set for any optimum rate. Anyone know about this?
    Today, my battery symbol with the blue bars and the white spaces, turned completely green. I am hoping that means that it has achieved a full charge. It lasted for about half-an-hour? Has that happened to any of you? Can anyone fill me in on that? I do get pretty good charges during my so called "glide" stage as it always adds charge to the battery (I like those green arrows). I also get quite a stack of green cars on the screen every five minutes.
    Well, that's all for now. I will look forward to your responses.
    The Lone Ranger
    Rides Again!
    Edit: I have been doing my own homework on this Cruise Control question. Apparently this has been discussed before. Frankly, I thought someone would tell me about a set screw somewhere, but here's what I found out: The cruise control can be made less aggressive -- alegedly, as I have yet to try this -- by tapping the the cruise control in the "Set" direction a number of times, and it can be made more agressive by tapping the cruise control lever in the "Resume" direction a number of times. I will give this a checking in the morning. Any further clarification or experience with this is still welcome.
  5. sub3marathonman
    sub3marathonman Active Member
    557
    75
    <div class='quotetop'>QUOTE(hobbit @ Mar 6 2007, 05:53 PM) [snapback]401137[/snapback]</div>
    Somewhere else I believe it was hobbit who said to accelerate at no greater than the rate that gives about 25 mpg instantaneous on the graph. That is a bit aggressive, but not flooring it. The other words of wisdom I remember from hobbit were "Stay out of the batteries," which mean to glide as much as possible without getting the arrows from the battery.
  6. Mister Swigart
    37
    <div class='quotetop'>QUOTE(sub3marathonman @ Mar 11 2007, 09:12 PM) [snapback]404018[/snapback]</div>
    I will take a look at this on the screen. I presume they are going off some performance graph or chart for saying this?
    This method is getting pretty well-rounded now, with most of the earlier criticisms finding solutions.
    "Pulse-Cruise/Cancel-Glide/Resume" is nearly the perfect in-traffic method, now that I can accelerate by pumping up on the Cruise control or decelerate by pumping down on the Cruise Control lever. Resetting Cruise Control is only necessary below 24-25 mph as it can now be adjusted continuously! I am consistently getting 51 mpg runs (avg), now ant that's with cold starts, ungaraged, 40-degree temperatures, a new unbroken-in car, and a newby at the wheel. I have gotten the hang of it, without looking at the screen -- just the speedometer. Hope others will try this and report back. Until then, I'm . . .
    The Lone Ranger
  7. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
  8. orangeblood
    orangeblood Junior Member
    29
    Woodbridge, VA
    <div class='quotetop'>QUOTE(ukr2 @ Mar 14 2007, 12:21 AM) [snapback]405148[/snapback]</div>
    Here's something I don't quite understand. That link shows a proper "pulse" to be one where the ICE sends energy not only to the wheels, but also to the electric motor (and thus into the battery). Since the latter (using gasoline to put energy into the battery for later use) seems inefficient, I'm wondering why a proper pulse wouldn't be either no arrows into the electric motor, or else having some assist from the battery (outflowing arrow).
    Thanks...
  9. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(orangeblood @ Mar 14 2007, 04:23 PM) [snapback]405645[/snapback]</div>
    You have to get energy back to the battery at some point since during your glide energy from the battery is being used (albeit in small amounts, but used none-the-less). The pulses are done with an eye toward keeping the ICE within it's absolute most efficient rpm range...that is b/w 1700-2300 rpm. At that rpm you get enough power to the wheels to accelerate while some of the excess goes to the battery for later use.
    One concept that newbies seem to have a hard time wrapping their head around is that ALL...100%...of the energy in the battery comes from the ICE via burning gasoline....unless you push the car to the top of a hill then regen brake on the way down. Even energy captured through regen comes from slowing down, but to slow down you must first speed up and that burns gas...you're simply recapturing a little of that energy you used to speed up.
  10. orangeblood
    29
    Woodbridge, VA
    <div class='quotetop'>QUOTE(efusco @ Mar 14 2007, 07:04 PM) [snapback]405667[/snapback]</div>
    Hi Evan,
    That's a hard concept for me to get my head around. I do understand that one could not P&G forever without the battery receiving enough charge to keep it at the minimum it requires. But let's say I have a nice long stretch where I can P&G and I'm trying to achieve maximum MPG for that stretch. Would it not be best to avoid having the ICE divert energy into the battery?
    Otherwise, if I understand correctly, it's not so much understanding that it would be more or less efficient having a green arrow into the battery during the pulse, it's understanding that that condition generally tells me I'm in an efficient RMP range? If true, why couldn't I glean that from the instant MPG readout?
    Sorry for the dense questions!
  11. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(orangeblood @ Mar 14 2007, 08:06 PM) [snapback]405782[/snapback]</div>
    Let me try to show by example...
    Let's say that the amount of gas burned during a pulse period contains 100 EUs "energy units"....
    With your method of pulsing w/ no arrows to the battery:
    Lets say that 5 EUs were used during the glide (net loss 5 EU). During the pulse phase you burn your 100 EUs by very slowly pulsing.....b/c your pulse is so slow you're in a less efficient band (33% efficiency) for the ICE and it converts only 33 EUs to usable energy and all that goes to propel the car.
    Now, with my pulse method:
    I still use the 5 EUs to glide. But when I pulse and burn my 100 EUs of gas, but I'm doing it in the most efficient band...faster acceleration in the 38% efficiency range...thus I get 38 EUs of usable energy out of my 100 EUs of gas. So I'll used the same 33 EUs that you used to get up to speed, but I'll send my bonus 5 EUs back to the battery to replace what I used to glide....now, I may lose 1 EU in converting for battery storage, so I may still be net loss 1 EU to the battery, but that's better than your 5 EU for the same amount of gas used.
    Obviously that's not exactly how it works, but it's a decent way to look at the concept.
  12. orangeblood
    29
    Woodbridge, VA
    <div class='quotetop'>QUOTE(efusco @ Mar 14 2007, 11:23 PM) [snapback]405794[/snapback]</div>
    OK, I can understand that example. But here are the complicating factors:
    1. Trying it tonight, I found I could pulse back up quickly (or slowly) without sending a green arrow toward the battery. (The point being that pulsing back up to speed with "my" method does not require doing it slowly.)
    2. The example in the link I originally referred to ( http://www.cleanmpg.com/forums/showthread.php?t=1224 ) shows the car pulsing back up to speed at several different rates of acceleration, also. (The point being that if a green arrow toward the battery indicates being in an "efficient band," there must be plenty of those at various rates of acceleration.)
    If you don't feel like explaining further, I certainly give you a free "out" of this. :lol:
  13. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    This is getting back into the "deadband fallacy". Whether or not
    current is sent to the battery or comes from the battery is largely
    dependent on the state of charge, not what you're doing with your
    foot during a normal pulse. If you pulse *really* hard you might
    draw some from the battery to assist, but you need to get up over
    like 3000 rpm for that and I think you'd know you were leadfooting
    it. For normal pulse situations the currents in and out are quite
    miniscule, but of course those stupid animated arrows don't show
    you how MUCH flow is going on there.
    So as you glide, even with the "zero arrows" thing, you're still
    drawing 5 amps out of the battery. That's about the threshold
    at which the orange arrow comes on or not. That will invariably
    draw the battery down a little on a long glide, and so you'll see
    more green arrow on the next pulse. That's okay, as long as those
    currents remain small and you keep the SoC near or slightly below
    its nominal "seek 60%" level. High currents and pulling it repeatedly
    down into two-pink-bars territory will lead to inefficiency, since
    you're converting more energy into electricity and chemical storage
    and then back out again, incurring loss.
    The only way to achieve zero battery current [and that's still not
    zero, because you're still powering all the 12V stuff via the
    converter] is pop into neutral. That switches off all motor
    control. You'll find that you won't glide nearly as far as a
    result -- that little allowable 5 or 10 amp trickle actually helps
    quite a bit.
    _H*
  14. sub3marathonman
    557
    75
    <div class='quotetop'>QUOTE(hobbit @ Mar 15 2007, 12:59 AM) [snapback]405883[/snapback]</div>
    Yes, but now hobbit is confusing me. On 3/7 hobbit said:
    What's the general speed range of your downhill? If you can start
    it at less than 42 MPH and make sure the engine's off, and then
    pop into neutral, the engine will stay off even if you get *above*
    42 on the way down. That's a serious gas-saving state if you can
    do it; just be prepared to pop back into D if you have to slow down
    so you can at least get the regen.
    I was thinking that I understood hobbit's neutral advice, since you're giving up the regeneration for greater coasting distance, while your battery is at a greater than usual state of charge. I was also wondering if it hurt the CVT to put it back in D after being in N to get the regeneration.
    Obviously the difference is being on level ground vs. downhill, but it is still confusing. It still seems that you could coast further in N even on level ground, give up the battery losses, and still be ahead, although of course in real life it is highly impractical to do. Efusco's example however really was helpful.
  15. Mister Swigart
    37
    I am enjoying this conversation going on here. I realized when I started this article that I was suggesting a way to achieve the same effect of a glide, though it was not -- by definition -- the same as the term used in the articles regarding the 109 mpg record. But my experimentation was to see if what I had been reading in those descriptpion was achievable or even applicable during everyday driving methods (which I do not feel the record represents with its two drivers, repeated stretch of road, in the absence of traffic conditions, and by careful monitoring of the screen.
    I do not feel it is necessary even to have some of the questions cleared up that have been raised by the last several posts. I have avoided the use of "deadbanding" or "no arrow" whatever, as this quickly sets my battery down to the last two bars. I did not feel it was even necessary to avoid sending juice to the battery. Note: I am very colorblind, and even though I can see the different arrow colors, I have difficulty naming their proper colors, so I have asked my wife to identify the colors that I see as different values). When I perform the "glide" that I speak of, the engine is in Drive, the arrows are going to the battery, and they are a pale blue color according to my wife. I see that as a pale gray. In my travels, the battery totally jumps from being in dark blue bands to a "light green." I was not getting this charged battery signal ever from using neutral in my earliest experiments. If the loss of momentum that comes from "gliding" in Drive rather than "coasting" or "freewheeling" in Neutral brings such a benefit in terms of charged battery, I was willing to continue with a method that doesn't "deadband" for very long at any time. I realize that is a departure from the original non-traffic descriptions of Pulse-and-Glide.
    I objected to this article being included here, by the way, under Fuel Econmy, as that was not what I was really trying to write about. I merely used the fuel consumption to bear out whether or not this method I have proposed was working. I am sure that it does work, is safe in traffic, and does charge the battery to a very high (and I will assume healthy) degree.
    Now, almost all of the talk I read about here at the forums suggests that most drivers are using the Energy Monitor screen to see where arrows are coming from, going to, and what is "driving" what and getting what levels of instantaneous mpg usage. I am beginning to believe that in traffic, I would prefer to use the Consumption Screen as I can't afford to watch that closely or take my eyes from the road when closed in by so many others. So, I watch the speedometer, "feel" the engine, use the Cruise Control instead of the accelerator altogether, unless I have come down below 24 or 25 mph and have to bring it back up to Set the next Cruise phase. One of the posters above suggested that I keep the rate of acceleration (how aggressive it is) minimized by watching the fuel consumption and not accelerating so rapidly that I fall below 25 mpg at any moment. This is proving to be pretty good advice. So, using the Consumption Screen with its columns and little green cars (and I get large stacks of cars in my columns), I watch the road, glance at the speedometer, and alternately glance momentarily to the current miles per gallon shown by the column at the far right of the screen. I try to keep my acceleration as close to or above the 50 mpg line as possible. When I kick up the Cruise Control level to accelerate (pumping the handle toward the ceiling), I try not to do that so fast that my column on the right falls. If it does, I come off it by pumping down on the handle toward the floor so that I maximize the amount of time the car is kept at or above the 50 mpg level. This way, I do not have to watch very closely and can just "feel" how close I am to keeping a midline column at any time, or higher to 99.9 mpg.
    I am still right at 51 mpg plus or minus .3 of a gallon. That is an indicator that I'm doing something right. I think that some of the highmilers here are not willing to try something other than what is working for them in fear of losing their great averages touted by their Green Mile Stickers. I can't blame them, of course, but I would like to see some of you experts give this a fair testing to see what it might really be worth. If a newby can get 51, what might a "senior Prius user" get? Tomorrow morning . . .
    The Lone Ranger
    Rides Again!
  16. orangeblood
    29
    Woodbridge, VA
    <div class='quotetop'>QUOTE(The Lone Ranger @ Mar 16 2007, 12:07 AM) [snapback]406515[/snapback]</div>
    Hi Lone,
    Regardless of what all has been discussed in this thread (and it's been a lot), you should know that you will achieve much higher MPG by learning a true glide. I think you still have a misunderstanding of this. (I'm saying this helpfully, of course, and not in a critical way.)
    A real glide is also safer in traffic because it's a much more gradual slowing down. And thus you don't have to start up your pulse as quickly. The very fact you are avoiding "deadbanding" is actually hurting your mileage. But don't worry, you are doing great and you will eventually pick up on this.
    On a related note, these past couple of days I've been employing the pulse method referred to in this thread of trying to keep a green arrow flowing into the battery. I must say, I'm quite amazed with the results. After several 30-minute commutes (both highway and city streets) most every 5-minute bar is over 50 mpg, and my tank average is over 55 mpg. Now, even though I had a 62.3 mpg tank last summer, this winter has been the doldrums, with most coming in below 45 mpg. So this recent 55 mpg tank is quite a signficant improvement.
    I love learning more about this stuff!
  17. Mister Swigart
    37
    <div class='quotetop'>QUOTE(orangeblood @ Mar 15 2007, 10:12 PM) [snapback]406559[/snapback]</div>
    Hello Orangeblood,
    Thanks for giving "Pulse-Cruise/Cancel-Glide/Resume" a try. Believe me, I'm not trying to avoid deadbanding. I'm just not willing to watch the screen and pedal up and down while watching to see if I'm getting it. I don't feel it in the seat of my pants as one put it, so I do it this other way. Note: once in a while when there is no one behind me or just in front of me, I check both screens to verify what I'm learning. I do get deadbanding frequently, especially when on Cruise Control but pumping down on the rate using the handle at those moments I described in the last post where the right column on the consumption screen falls, I pump down, and it rises back up well over 50. The Cruise Control is still on call, but effectively I'm gliding without a call on gasoline and neither from the battery, no colored arrows whatever -- in other words, I'm not doing Cancel-Glide but pumping down to slightly lower Cruise levels, essentially the same as coming off the gas with your foot and apply just a touch of pressure, again. I'm paying attention to this more and more. This is when I'm getting the true glide, only, I'm doing it with my foot off the gas and using the cruise control which is on this car, really, a hand accelerator (as a matter of fact, the symbol is a small dial like a speedometer, appropriately). I have no doubt that many of you can do this with your foot, but I do not have the touch. Perhaps after the long travels I'm planning for this summer will give me the opportunities to study and learn this, better. In the meanwhile, I'm sticking to this game plan, and inviting others to add to my short, and limited knowledge. I look forward to hearing more about your results. You're doing better than I, which is what I thought would happen. I would like to get Evan to try this, as well. I'm not feeling so much like . . .
    The Lone Ranger
    Rides Alone.
  18. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(sub3marathonman @ Mar 12 2007, 01:12 PM) [snapback]404018[/snapback]</div>
    The best shift of the famous 109 mpg 1400 mile marathon run recorded 9.84 km/L (23.1 mpg) for engin on mileage (pulse or acceleration part) and 19% engine on distance, so they glided the rest, 81% distance.
    The result of the shift was 51.25 km/L (120.6 mpg) for 150.78 km (93.7 mile) distance.
    http://www.greenhybrid.com/discuss/showpos...mp;postcount=77
    Ken@Japan
  19. sub3marathonman
    557
    75
    <div class='quotetop'>QUOTE(The Lone Ranger @ Mar 15 2007, 11:07 PM) [snapback]406515[/snapback]</div>
    On the "Obscure Facts" thread I mentioned that the most little green cars you can get are four. If you are seeing that many you may actually be regenerating more than that. Also, while they do look great on the screen, the real goal is to regenerate as few little green cars as possible, since each one represents a deceleration and you then have to accelerate again.
    And also, as ken1784 has pointed out, accelerating at the 50 mpg line is probably a bit too slow. I must give you credit for being that gentle on the acceleration though, which I think is the accepted method of maximum milage for ordinary cars.
  20. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Hi Ranger,
    I applaud you your desire to experiment :)
    As noted by others, foot off the accelerator will slow the car faster (while charging the battery a little) than a 'no arrows' glide which neither uses the battery to power the electric motor nor adds power to the battery via electrical generation. Since you are new to the car, I think you should not give up on the 'feel it in the seat of of pants' detection of glide vs watching the screen. These things are all subtle and take time. You can kind of feel it 'let loose'.
    I think there is some serious calculation going on inside the car's computers when deciding how much engine and how much electric motor to put in the mix at any given point in time. Again, as noted earlier, the state of charge of the battery plays a big part in this. I have been on the interstate where the car might be using ALL electric (according to the arrows) on a slight up hill when the battery is 7 green bars (of 8). At the same point, I have also seen it being all ICE or a combination of ICE and adding excess to the battery when I am at 5 or 6 blue bars.
    One thing you have not said (at least I didn't see it) is how much of the time you are in "electric only" while employing your technique. I would guess that you are charging the battery whether in pulse or regen coast and not likely in 'all electric' much if ever. Or maybe your pulse is getting better MPG because the electric motor is being used more with a high battery SOC? For general 'town' driving, I find that the electric motor has reasonable power, the only thing holding it back from doing all the work most of the time is the relatively small amount of battery capacity.
    You mentioned tapping the CC stalk to raise your speed. If you haven't found it elsewhere, the CC is very nice about increasing speed by exactly 1 MPH for each tap. I think you are providing a manual 'adjustment' to the aggressiveness of the CC. If you had dropped from 40 to 30 then hit resume, it will try to get up to 40 based on some acceleration formula. By tapping the CC stalk, you are asking for a LITTLE increase so it doesn't calculate as high a rate of acceleration. Of course, your orignal premise was a less 'hands/foot on' interaction. Don't have to watch the screens or hold your foot just so on the accelerator.
    One variable I don't think you have stated: How flat/hilly is it where you drive? Also, are you doing these tests with an 'overnight' cold engine? On short trips (1 or 2 miles)? I pretty much never do better than 35 MPG in the first 5 minutes. Thus those short trips will dash any hope of breaking 50+ on a tank.
    I think you have already seen that temperature plays a big part in MPG. We see a serious improvement when the temp goes over about 35F. Of course it is well below that most of Dec through Feb. and we feel that pain! On an specific 8 mile trip with few stops, posted mostly at 30 MPH, I can get half the distance (total, various up and down hills along the route) on 'all electric' when it is 50+ F but NONE when it is 20F.
