parking prius for two weeks in garage
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by [email protected], Jun 30, 2007.
  1. jjones811@hotmail.com
    [email protected] Junior Member
    i am going on vacation for two weeks, and parking the prius at the airport.
    will there be any problems with the battery not maintaining a charge and starting right away on my return?
    thanks- jj
  2. Jim1eye
    Jim1eye Shaklee Ind Distributor
    181
    Connecticut
    2022 Prius Prime
    <div class='quotetop'>QUOTE(speech path @ Jun 30 2007, 11:33 PM) [snapback]470855[/snapback]</div>
    Only thing I did was turn off the SKS Switch at the bottom of the dashboard. No problem starting on return.
  3. jjones811@hotmail.com
    <div class='quotetop'>QUOTE(Jim1eye @ Jun 30 2007, 08:41 PM) [snapback]470858[/snapback]</div>
    yikes.
    sks switch? will the manual explain what that is and where that is?
    many thanks- jj
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    IF you have SKS, the switch for it is under the steering wheel at the bottom of the dash. 'Out' is ON, I believe, though I'd have to go out and check to be sure. Two weeks, even if left on, shouldn't be a problem. DO switch off your headlights and make sure all interior lights are off.
  5. 8AA
    8AA Active Member
    550
    62
    Maryland
    I agree with Bill. I've left my Prius parked (with SKS on) for two weeks many times at the airport with no problems.
  6. fortheanimals
    fortheanimals Junior Member
    87
    portland, or
    i've left my car parked for a month twice. nothing adverse occurred when i got back in it. first time, i made sure everything with an off button was off (mainly the lights). 2nd time i left as is.. but made sure headlights off. i don't have sks. if you do, i 2nd turning that off. 2 weeks is nothin to worry about. have a great trip!
  7. darelldd
    6,057
    389
    Northern CA
    Hell, I only drive the gas car once or twice a month max. I used to be really good at switching off SKS, now I don't even bother with that. No problems yet... knock on wood.
  8. LongRun
    LongRun New Member
    81
  9. LaniLobes
    LaniLobes New Member
    <div class='quotetop'>QUOTE(speech path @ Jun 30 2007, 10:33 PM) [snapback]470855[/snapback]</div>
    I have left it for six weeks and no problems at all - there was heaps of charge in both batteries.
  10. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    <div class='quotetop'>QUOTE(LongRun @ Jul 5 2007, 02:53 AM) [snapback]473363[/snapback]</div>
    Smart Key System.
  11. judymcfarland
    judymcfarland Queen of Moral Indignation
    578
    Glendale, WI
    I'm happy to report that Fiona was just fine after sitting (with SKS off) for 3 weeks, being driven about 10 miles & then sitting another 3 weeks in my garage. I am driving again after my knee surgery & it feels great to be back in a Prius! One tire was low, however. Will have to watch for a slow leak, perhaps? Never had tire pressure issues before this layoff.
