The What is It Game.
Discussion in 'Fred's House of Pancakes' started by Sufferin' Prius Envy, Aug 9, 2007.
  1. echase
    echase New Member
    227
    IS the "not Coal" stuff a clue?
    Also, on location I am thinking hte houses look cheap to be european, but I could be wrong.
    The combination of brick and coal is interesting, but may or may not be a clue. Also, anybody have any theories on the steel bars going across the top? They seem to be attached in a way that allows movement, so that must have some significance.
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Yes, the 'not coal' stuff is a clue, and was part of the whole long-defunct operation, which is really only hinted at by the remaining ruins. This portion used to be made of bricks, or at least many more than it is now. The mystery might be revealed with another picture from another angle...
  3. samiam
    samiam Antipodean Prius Poster
    2,442
    29
    Enn Zed
    Another angle would be helpful...
    The black tailings at the foot of the structure are pretty hard to make out.
    What deposited such a mess?
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Tailings!
    Here's a better shot. Think how it used to look.
    [attachmentid=10862]
    Here's another shot from the same spot, but a much different angle. Any burning thoughts yet?
    [attachmentid=10863]
  5. RinMI
    RinMI New Member
    132
    SW Michigan
    <div class='quotetop'>QUOTE(hyo silver @ Aug 23 2007, 11:21 PM) [snapback]501372[/snapback]</div>
    What about a "smoke stack" or air ventilation tunnel?
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Yes, this is the smoke stack from the Greenwood Smelter, once the largest copper smelter in the British Empire. Some 250,000 bricks were used in the construction of the stack and shaft, and many large concrete footings are still in place amidst all the trees. The 'not coal' black stuff is the slag pile. There are numerous abandoned mines in the area that are very interesting to explore, but also dangerous. We made it out. :)
  7. RinMI
    RinMI New Member
    132
    SW Michigan
    <div class='quotetop'>QUOTE(hyo silver @ Aug 24 2007, 12:46 PM) [snapback]501539[/snapback]</div>
    I figured that was the case since you mentioned burning thoughts. Good hints. I will have to post my pic later today since I am at work right now. If someone else wants to toss one up in the meantime, feel free.
  8. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    Oh darn, my next guess was going to be a midget subay & station......
  9. echase
    echase New Member
    227
    <div class='quotetop'>QUOTE(RinMI @ Aug 24 2007, 12:49 PM) [snapback]501543[/snapback]</div>
    OK, this should be an easy one...
    I've even left the labels on it. What is it for, and why is that special?
    [attachmentid=10891]
  10. Sufferin' Prius Envy
    3,998
  11. echase
    echase New Member
    227
    And they are special because they are meltdown-proof, and generally much safer and simpler than the old style reactors. (Not foolproof, but certainly a big step forward) Also, they are "breeder" style reactors, so the fuel is effective for a much longer period of time reducing waste and the need for disposal/reprocessing, and mining.
    Yours is a map of this Morning's Aurora Borealis activity:
    Which reminds me, what's this (it's not the Aurora)...
    [attachmentid=10921]
  12. airportkid
    airportkid Will Fly For Food
    2,191
    538
    San Francisco Bay Area CA
    Looks like the trail of a heat seeking missile that locked onto a mosquito in heat :p
  13. echase
    echase New Member
    227
    <div class='quotetop'>QUOTE(airportkid @ Aug 26 2007, 02:07 PM) [snapback]502409[/snapback]</div>
    Why would it be all lit up like that :unsure:
  14. tochatihu
    tochatihu Senior Member
    9,950
    3,844
    Kunming Yunnan China
    2001 Prius
    Greenkeeper, many DoD missles are launched over the Pacific from Vandenberg AFB in Calif. We are generally not told what they 'do', but a common result is a trail of solid fuel aerosols in the upper atmosphere.
  15. airportkid
    2,191
    538
    <div class='quotetop'>QUOTE(Greenkeeper @ Aug 26 2007, 05:58 PM) [snapback]502534[/snapback]</div>
    It's so high the sun is still visible, illuminating it. Don't know why the exhaust trail is still compact yet seriously erratic - when the upper atmosphere winds drag those trails all over the sky they usually also disperse them. But perhaps this missile was doing some sort of guidance test, or was tracking something.
    MB
  16. echase
    echase New Member
    227
    <div class='quotetop'>QUOTE(tochatihu @ Aug 26 2007, 11:03 PM) [snapback]502574[/snapback]</div>
    Well, both of you are right. It's a minuteman II from vandenberg, the light shining on it in the upper atmoshpere is known as the "Twilight Effect" (Queue spooky music)
