What Really is Holding Back Plug-In Hybrid Electric Vehicles?
Discussion in 'Environmental Discussion' started by joe1347, Sep 11, 2007.
  1. joe1347
    joe1347 Active Member
    669
    44
    AZ
    The more that I read about plug-in hybrid electric vehicle (PHEV's), the more I wonder what is the real reason holding back their introduction by the mainstream auto manufacturers. Or more simply, why can't I buy an 80mpg car today? My initial preconception was that existing batteries were way 'too heavy' plus dangerous (exploding lithium-ion) and that major advances (in battery technology) were still required. However, after reading about Lithium-Iron-Phosphate Li-Fe-PO4 batteries (A123 Systems, among others), it became apparent that 10 mile range plug-in's will only require about a 100 pound battery pack and even better, Li-Fe-PO4 batteries are safe (don't explode). For reference, I'm assuming a 10 mile range requires a 5Kw-hr battery and a Lithium-Iron-Phosphate battery with 0.1 Kw-Hr/Kg capacity. Hence, surprisingly, weight isn't that big of a problem. So I'm assuming that cost is the major factor holding back a 10 mile plug-in (PHEV10). After some digging, it looks like Li-Fe-PO4 batteries may run about $750 per KW-Hr, while conventional lithium batteries (the ones that explode) seem to be closer to $500 per Kw-Hr.
    http://www.batteryspace.com/index.asp?Page...p;Category=1225
    Hence, a 5Kw-Hr Li-Fe-PO4 battery pack (10 mile range) would cost around $4000. While $4000 doesn't seem that ridiculous - I suspect that asking a $4000 premium (for only 10 miles) over the current cost of a Prius will be a tough sell unless gas lines become the norm. Ok, so if the current high cost of Li-Fe-PO4 batteries is the only thing keeping us from having 80mpg cars, what is the technical reason why Li-Fe-PO4 batteries are expensive to manufacture? I don't think that it's a raw material cost issue - since the lithium metal cost would be less than a few hundred dollars. So I suspect that the high price is somehow related to manufacturing the electrodes or electrolyte solution. Is the issue then simply one of 'economy of scale' and if Li-Fe-PO4 batteries were given a financial 'jump start' and the US Government spent say $10 Billion US Dollars on a massive Li-Fe-PO4 battery manufacturing plant(s), would that solve the problem and affordable 80mpg cars would be possible in the very near future?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    The cost you calculated are based on the cells that last only 500 to 1000 cycles. If you put that in a plug-in car, you will need to change it every two years.
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    First, I believe GM has exclusive OEM right with A123 and Valiance (two of the contractors GM is working with for Volt). A123 claimed that their battery is safe (for which I have seen video on youTube, quite impressive), and can last 15 years of use. However, the cost has not been revealed. However, the fact that GM was talking about leasing Volt not selling them tells me that the battery may be very expensive for 40-mile range (target of Volt). :(
  4. Darwood
    Darwood Senior Member
    5,259
    268
    Cheap small NiMh EV's WOULD be feasable right now if Chevron did not own the patent on large format NiMh batteries. The Prius battery was designed to be as large as possible without infringing on that patent. I believe that patent runs out in 2010.
  5. joe1347
    669
    44
    AZ
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Sep 11 2007, 03:05 PM) [snapback]510725[/snapback]</div>
    I was unable to find any cost info on the A123 Lithium-Iron-Phosphate batteries which I believe are good for more than 1000 cycles (link below) - so the $750/Kw-Hr is only an estimate (guess). Do you have a link to pricing estimates for hte A123 batteries since I'm assuming that you're implying that the A123's are more expensive?
    http://www.a123systems.com/newsite/index.p...s/phev/pchart2/
  6. naterprius
    naterprius Senior Member
    1,843
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Sep 11 2007, 01:05 PM) [snapback]510725[/snapback]</div>
    seawolf, it's important to understand that "soft hits" can extend a battery's lifespan significantly. If you use the middle 70% SOC, a battery may last forever.
    Nilar has an NiMH battery that can tolerate 2000 cycles, or 300,000 soft hits. A plug-in hybrid is ideal because the engine can be used to prevent low SOC on the pack, and Battery Management can be used to preven SOC above 85%. This effectively takes the 10 mile pack mentioned and makes it a 7 mile pack, however. But this problem is not insurmountable. But even using the middle 80% could give you 10,000 cycles, so this would give you 8 miles of electric range on the theoretical 10 mile pack.
    Since I bought my RAV4 EV 6 weeks ago, I've become convinced that nothing is holding back plug-ins other than the status quo and complacency.
    I've been plugging in my car almost every day and it works great, on 11 year old technology.
    Yes, I use the middle of the pack. The middle 70 miles of the 100 mile pack. Pack capacity is well within a plug-in's reach.
    Nate
  7. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    <div class='quotetop'>QUOTE(naterprius @ Sep 11 2007, 05:14 PM) [snapback]510809[/snapback]</div>
    I'm not familiar with plug-ins, so pardon my ignorance.
    Where do you plug this car in?
    And am I understanding correctly that you generally drive about 70 miles between plug-ins, and the max possible is about 100 miles?
    Thanks
  8. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    The title of this thread is:
    Try watching "Who Killed The Electric Car", out on DVD now.
    In lieu of that, check out several YouTube clips available... start with this one, (Dateline produced)
    http://www.youtube.com/watch?v=911huduMpRI
    The subsequent parts will come up when load that one.
  9. naterprius
    1,843
    My friend Darell has such a great website about the Toyota Rav4 EV. I bought mine about 6 weeks ago (used, it's a 2002 with 60,000 miles).
    http://www.evnut.com
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(joe1347 @ Sep 11 2007, 04:48 PM) [snapback]510789[/snapback]</div>
    The cheapest place is on ebay. Try searching "DC9360" for basically a pack of 10 cells. You can get a pack of 10 cells for about $100 shipped. That makes $10 each cell. I believe Hymotion used these M1 cells to make the Plug-in Prius conversions. You can find a very impressive life cycle of the M1 cell here. The claimed 7,000 cycles is achieved when drawing only 5kW (6.7hp) at 1C. A123 cells are capable of delivering "out of this world" 150kW (201hp) at the expense of lower life cycle. MG2 is only capable of 50kW. That means, the pack will not get drawn more than 10C. We should really use the number of cycles at 5C (guessing average rate) to be realistic.
    I remember seeing the spec as 3.3v (instead of 3.6v) with 2.3AH. So you will need about 660 cells to get 5kWh. The pack cost goes up to $6,600 with $10 per cell ebay price. [edit] I found the spec of M1 cell. The life cycle depends greatly on the temperature and the rate of charge/discharge. Hymotion offers 5 years warranty on L5 pack for $10k indicates that M1 cells might not last 10 years on Prius PHEV application.
    M1HD cells can store more energy per weight than M1 but deliver power at slower rate. They are designed for PHEV because PHEV will have more cells than HEV anyway. M1HD cells are prismatic and we don't know how much they will cost.
  11. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
  12. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    5 *usable* kWh would actually get you about 20 miles, not 10.
    _H*
  13. hobbit
    4,089
    470
    Bahstahn
    _H*
  14. joe1347
    669
    44
    AZ
    <div class='quotetop'>QUOTE(hobbit @ Sep 11 2007, 10:15 PM) [snapback]510976[/snapback]</div>
    I was being very conservative with my estimates and based the 10 mile range from the following article.
    http://www.evworld.com/article.cfm?storyid=1184
    More optimistically, the link below summaries fuel efficiency using a 5Kw-Hr supplemental battery pack (to a Prius) from the Li-Fe-PO4 battery maker A123 Systems.
    Commuting Distance/City mpg/Highway mpg
    20 miles /174 mpg/ 117 mpg
    40 miles /153 mpg /103 mpg
    60 miles /124 mpg /90 mpg
    http://www.a123systems.com/newsite/index.p...ns/phev/pchart5
    I suspect that the truth is somewhere in-between as usual. But the bottom line is that about 100 pounds of batteries will give you 100 mpg with an overnight recharge. Just need cheaper batteries.
  15. joe1347
    669
    44
    AZ
  16. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    My guess is that PHEVs in production would open pandora's box, if you will. Once high quality batteries go into production for a PHEV, the price of the cells is going to come down quickly. I would think that after a relatively short time people will be wondering where the full EVs are. Once those appear the cash cow that is dealer service agreements will be gone.
    That and conservatism. No one wants to take the risk now. There's no hugely compelling business reason to do it.
  17. GripperDon
    GripperDon New Member
    52
    You say Chevron has the Paten right on the large format battery pack? Big oil protecting it's right to steal for the citizenry again.
    After reading all the forgoing, It seems to boil down to $ and Guts. I would have thought that Gates or some rich bunch of movie stars would have ponied up the required startup money. Where is Soros in all this?
    The battery technology sounds like it here just needs some kick off money to get them in production and watch the prices drop and they will, the power of large scale production unstoppable. They will replace dollars with dimes. Just look at computers and chips that the way the cost will drop.
    The real problem is most have too much vested interest in the status quo. The car companies sure don't want to change and neither do the oil companies, things are just fine thank you very much.
  18. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    reluctance to spend money on EV's or other technology that enocurages automobiles the rely more on electricity than the current status quo.
    i also had a chance to get a RAV 4 EV... but balked at the $60,000 price tag... i regret decision daily now.
    i have purchased a Zenn. it does not have the range or the speed, but will still cover over 80% of my driving needs and it was only $14,000 after 35 mph upgrade
  19. jk450
    jk450 New Member
    55
    <div class='quotetop'>QUOTE(Darwood @ Sep 11 2007, 03:49 PM) [snapback]510746[/snapback]</div>
    Then why did Toyota reduce the battery pack voltage and cell count on the Gen II, rather than stay with the "large as possible" philosophy?
    And how does Ford get away with a larger 330V battery pack withut infringing on the patent?
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ford uses the smallest cell size.... basically over 200 D cells
