Steering Wheel Lights
Discussion in 'Gen 2 Prius Technical Discussion' started by rochesteruser, Feb 23, 2008.
  1. rochesteruser
    rochesteruser Cruzin' in Rochester MN
    153
    Rochester
    Is it just me, or is the lighted steering wheel on my Prius super dim? Anyone know how to turn up the lights on the steering wheel?
  2. rochesteruser
    153
    Rochester
    I answered my own question. It sounds like it can't be done. :(
  3. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    The general theory is that Toyota made the steering wheel lights dim to give owners one thing to complain about.
  4. rochesteruser
    153
    Rochester
    That seems odd. This car is so great and so annoying all at the same time.
  5. qbee42
    3,079
    Once you get used to them, they are bright enough. I had the same complaint when my Prius was new. The button lights are bright enough to see the buttons when it is dark, otherwise ambient light is bright enough. That said, it would be nice if they were adjustable.
    Another minor brightness complaint that I have involves the relationship of brightness between the speedo display and the MFD button lights. On dark nights I would dim the speedo a bit more, but then the MFD buttons go out completely.
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I don't even look at them anymore. Some have dots, others dips and some bumps.
    I know that the INFO is the second-down on the right. Volume is upper-left. [AUTO A/C] is half the lower-left - under the audio controls - with temp controls underneath and the lower-right is where I control defrosting and recirculation. Since I don't have a bluetooth phone, I mess with those buttons.
    To me, hitting the steering wheel buttons is just as natural as a QWERTY keyboard.
  7. qbee42
    3,079
    I havm the sa,e fee;ing abiut the QWERTY kwybrd.
    Rom
  8. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    ,jay co ',.pyf
  9. Qlara
    Qlara New Member
    488
    Seems true.
    Toyota maybe trying every possible way to save money on Prius production.
    I suspect the steering wheel buttons maybe just lit by a single LED on each side only. Not to mention the power window switches are not lit at all.
  10. BIGGDOGG
    BIGGDOGG New Member
    298
    Morristown,NJ
    Wait a minute, The steering wheel buttons have lights??? lol
  11. eprupis
    eprupis New Member
    Why isn't the AC fan speed control on the steering wheel? I rarely adjust the temperature control, which is on the steering wheel, but I am always adjusting the fan speed which requires a distracting use of the display controls. And since I can't touch type, better lights on the wheel controls would be greatly appreciated.
  12. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    It seems that the design is that you use the Auto AC, which adjusts the fan speed automatically. You can easily adjust the temp from the steering wheel, and then let the system take care of the rest.
    When I'm driving at night, I turn down the speedo display (to reduce the green glare), and I can see the steering wheel lights just fine if I need to glance down.
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    If I can trust my memory cells this morning, the QWERTY layout was designed to slow people down. The mechanical arms on ancient typewriters kept getting stuck because the typists were going too fast. The DVORAK layout puts the most-used letters in the easiest-to-reach places, but people reject it because it 'looks weird' or isn't what they're used to.
  14. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Like Tony, I just feel the buttons. Each one either has a unique location or feature. I don't like taking my eyes off the road for very long so this seems to work out.
    Anyone ever try to mod the steering wheel lights?
  15. Tideland Prius
    16,615
    Because automatic climate control takes care of that? You adjust the temperature to your liking, and let the system do the rest.
  16. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Yeah I think people have tried modding the lights... or at least thought about it. But I think by the time you get close to coming up with a solution, you've gotten used to the feel of the buttons. Making fun of QWERTY is fun, but honestly, if you use the buttons a lot you'll know them by touch pretty quickly. I don't take my eyes off the road to find buttons anymore.
    And re: fan speed, yes, try forcing yourself to use the auto a/c button and temp +- buttons for a while without using the climate screen. I was skeptical but I forced myself to do it, and I literally NEVER use the climate screen anymore because the buttons take care of it all... the a/c controls humidity very well, temp, etc. and if I want higher fan speed, I bump the temp a little.
  17. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    This is how I dress when I drive, so I don't have an issue seeing the steering wheel controls. I do however get that glare that everyone complains about.
    hemingways likes this.
  18. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I think I would find it distracting, or at least annoying, if the steering wheel had brighter lights on it.
  19. Doc Willie
    1,717
    144
    Out there, somewhere
    Adjustable would be cool, and we could all have our pick.
  20. Pinan
    Pinan Member
    173
    Murrieta, CA
    A little off-topic, but does anyone know how to get to the underside of the buttons. I have a squeaky one that needs attention. Does the silver (surrounding) frame simply snap off?
