No manual tranny??
Discussion in 'Gen 2 Prius Main Forum' started by cyberprius, Jun 9, 2008.
  1. cyberprius
    cyberprius Mtn Bikes don't need foglights
    185
    oregon
    I've always driven a manual tranny. So, some friends have mentioned that fact.
    Any reason, and I know it is all guess, why no manual in the Prius. Seems it would offer best MPG as it does in all the other Toyota lines...
  2. Patrick Wong
    18,200
    6,497
    Hi Kristi,
    The Toyota hybrid system totally depends upon its unique transaxle design that combines power produced by the gasoline engine and two motor generators. It is not possible to use a manual transmission with this design.
    I attached an excerpt from the 2004 New Car Features manual which provides an overview of the Toyota hybrid system. If you have questions after reading the excerpt, please ask away.
  3. qbee42
    3,079
    As Patrick states above, it's not possible in the Prius. Another way to look at it is that the Prius transmission is manual, but it only has one gear and no clutch, so there is nothing to operate when it comes to shifting. It's a completely unique system.
  4. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Are you sure its Kristi asking?
    Is it not her husband?
    ZC1
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I'll bet you are right. She won't let him near her car. Maybe the computer will be next.;)
  6. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    I've driven a stick for 35 years, and the CVT gearless makes you forget about wanting to shift, which can be tedious on hills and in traffic. It's so smooth, unlike a regular auto, which has those annoying steps when the gears change. I can imagine future race cars with the CVT (shifting takes time), though I understand full battery-powered vehicles don't need a transmission--just a braking system. You get away from the ICE, and cars change dramatically.
    I've noticed that other non-hybrids also have the CVT transmission, Jeeps, for example. I assume it's also stepless, like the Prius?
  7. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    Other than the name, absolutely nothing is in common. The components are different and they operate different.
    Cone & Belt type CVTs are used for non-hybrid vehicles and some "assist" hybrids.
    Planetary type CVTs are used for "full" hybrid vehicles.
    Refer to the PSD documents on my website for illustrations & descriptions of how the system in Prius works.
  8. Patrick Wong
    18,200
    6,497
    Well - the Prius transaxle might act and "feel" like a CVT installed in a non-hybrid. However the Prius transaxle works much differently than a CVT.
  9. YoungOrganist
    YoungOrganist New Member
    Bahstahn MA
    2002 Prius
    Is it true that the only stick shift hybrid is the Insight?
    I've always wondered: Is a CVT more efficient than a manual transmissions? Of course it picks the gearing ratio whereas you can choose on a stickshift, but does it always pick the most efficient one?
  10. bwilson4web
    16,111
    You can still shift to any of the available gear selections at any speed ... if you need something to do with your other hand. <GRINS>
  11. PriusSport
    1,498
    88
    SE PA
    Thanks. Does the Prius CVT feel smoother than the others? I assume it isn't either Cone & Belt or Planetary.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    I'm not sure what you mean by tranny, this is a tranny
    The Prius has something looks more like this
    under the bonnet.
  13. patsparks
    10,664
    567
    Neither, it is all electric and there fore is as smooth as an electric car.
    There are no variable ratios just 2 electric motor/generators and some fixed ration gears.
    Have a look in the tech section for more.
  14. patsparks
    10,664
    567
    Sorry about this everyone I can't help myself.
    Little redneck humour.
    What is the difference between a transexual man and a Prius?
    One is gay and the other ...
    ... is a transexual man.
    I don't agree with this but I had to post it. and I thought of it myself.
  15. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    One of the great things about John's site, as well as PriusChat, is that there is so much information if you care to learn.
    The Prius Hybrid Synergy Drive uses a planetary gear power-split device to blend the power of the electric motors and gasoline engine. There is only one gear ratio. The gears are always engaged, so there really is no neutral.
    Have you found your Prius to accelerate smoothely? Smoother than any other? Efficiently going from 0 to 65 mph (or over if you don't pay attention)?
  16. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Pat, you gotta get out and dance more! You came up with the picture and jokes waay too quickly!!
    Olivia Newton John would be shocked!
  17. YoungOrganist
    Bahstahn MA
    2002 Prius
    That looks more like a Transaxle...
  18. MagneticGrayIndy
    MagneticGrayIndy 06Prius;94M Miata;65Rambler770
    208
    Indianapolis
    the Civic hybrid was offered in a manual transmission... I just can't go there with the tranny jokes, sorry.. But it is not in the present model.
    er.. Civic... that is
  19. Patrick Wong
    18,200
    6,497
    It is true that the gearing between the ICE, MG1 and MG2 is fixed and in that sense there is only one physical gear ratio. There exist an almost infinite number of "logical" gear ratios, hence the Prius transaxle emulates a conventional CVT.
    MG1 spins clockwise and counterclockwise as needed, based upon hybrid vehicle ECU control, so that the ICE can run at the most efficient speed given the driver's demand for power, while MG2 runs at the speed required to move the car at the desired mph. MG1's ability to be flexible and rotate in either direction enables the variety of logical gear ratios mentioned above.
    The traction battery provides the necessary power to supplement the ICE when the driver demands substantial power. The battery also serves as a reservoir when the ICE produces more power than required to move the car, as well as when regen braking is in effect.
  20. ZC1
    711
    Metro Detroit
    Not so fast. There has been one other vehicle that has had a planetary gearset with a CVT, the Prius is not unique.
    This vehicle has been available since early 1980s and is still selling today.
    I should know, I rode in it, worked with it and was officially trained for its repair.
    Not everyone can afford or purchase it, but it was/is the M1 Abrams Tank.
    The driver sits in a tight, almost claustrophobic, compartment with a shortened pair of motorcycle grips as an accelerator. If I remember correctly, no shifting necessary, except reverse and neutral. I had dissected the CVT transmission which needed an overhead crane to move it around since it weighed as much as an old Volkswagen Beetle (around 2,000 lbs). The planetary gearset was huge.
    ZC1
