08 Prius struck by Lightning!
Discussion in 'Gen 2 Prius Technical Discussion' started by Bear68, Jul 14, 2008.
  1. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    abq sfr, donee, kohnen,
    thank you for the come-backs. That was educational, I learned some things.
    The only downside being the further loss of innocence; another childhood myth
    shattered.
    My apologies to the OP and Coplanddg for this diversion.
    As they used to say in old-time TV and radio;
    "And now, its back to our regular scheduled programming... "
    08 Prius struck by lightning!
  2. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Interesting.... I think helicopters build up such a charge too. I've seen in a movie (Hunt for Red October?) they use an insulated pole with an inside conductor to bleed off the static charge when they are picking up somebody from a submarine where the copter can't actually land. If you're standing on a steel perfectly grounded submarine and touch a hovering helicopter, you'll probably die. Same thing with powerline workers who are dropped onto steel electrical towers. :eek:
  3. qbee42
    3,079
    So do fixed wing aircraft. The first thing you do when refueling is to attach a ground to the aircraft to bleed off any static charge. It's not a good thing to draw an arc to an open fuel tank.
  4. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Yes, helicopters have that static electricity build-up. A grounded pole is used to touch the helicopter and/or its slung cargo. The static electricity can also be discharged by having the pilot key his/her radio mike -- it sends a burst of static on the frequency in use. The timing has to be nearly perfect so the grounded pole is used even if the pilot keys their microphone. I saw someone thrown twenty feet through the air when they didn't wait for the pole to discharge the static charge.
  5. dandeman
    dandeman Junior Member
    61
    Chapel Hill, NC
    I know they do... I've been personally helo'd off a destroyer deck (no helo pad) by a hovering helo to the carrier we were in company with during my Navy service.. I took the photo below of my ship I was helo'd off from the carrier I was helo'd to. As you can see from the photo link below, the helo had to hover quite close to the aft fire control radar, just above the missile launcher on the main deck.. You feel pretty mortal when hanging off a cable from a hovering helo.. :eek:
    http://home.4x4wire.com/deddleman/jpj32.jpg
    As mentioned the helo lowers a steel cable with a padded loop on the end of it that you drop down over your head and under your arm pits and up you go.. You can see the winch stowed inboard above the half door in the pic below..
    http://home.4x4wire.com/deddleman/insightb.jpg
    A steel wand grounded to the ship is touched to the steel cable before anybody touches the loop..
    Have watched planes land at night on the carrier while standing on the catwalk near the cat launch control station. You can see roughly a good 12" long static discharge arc from the tail hook just before it strikes the deck..
    A typical power level aircraft UHF comm radio mike keyed is not going to have any effect on an aircraft's static charge. I was our ship's ELINT officer and well aware of the nitty gritties of every RF radiation device, power, RF effects, including safety. If there were some plausible mechanism for this to work, there are far more higher powered "illuminators" in the vicinity of ship ops, for example, 2.3 megawatt (peak eirp) air search radar.
  6. Jack66
    766
    Stafford, Virginia
    It must be the particular airframes -- keying the microphone worked most of the time on UH-1 Hueys.
  7. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    Gawd I loved Hueys! Best seat of the pants rides I ever had at 50ft or less was in those things! Best wow was in a Canadian F-104 at something like 1300 mph at 150ft! Maple flag was fun for me!
    Sorry about the thread hijack...... Now back to electricity!
  8. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Wow!! Some awesome stories coming out here with no complaints on my part!!
    Anywho.... Here are the pics I have so far... First is the antenna, on the car then both sides on the bench. Next is the locknut. (Note the burn marks) Finally, is the location of the gateway ECU, located next to the passenger dash airbag. (Brown box) Awaiting insurance company to authorize engine ECU, Hybrid ECU, and HV Battery ECU.
    More pics and info will be coming as I continue this winding path of diagnosis.... Hopefully, things will progress quickly and cleanly for the sake of the owner and all involved...
    Also, having spoken with him... This car does indeed belong to Coplanddg.
  9. Bear68
    Bear68 Member
    373
    72
    Success!! After replacing three more ECUs (engine, Hybrid and HV battery) and the radio head unit, the Lightning Prius is up and running perfectly. I am in the midst of an owner approved, extended test drive in order to verify that all systems are go.
    Internal inspection of the ECUs and the radio show no visible signs of damage so I didn't bother with any more pics. I was able to retrieve the customer's CD that was in the radio.
    I won't reveal numbers here (not my place to do so) but I gotta say.... Good advertisement for full insurance coverage!!
  10. ZippyPri
    ZippyPri New Member
    39
    Boston
    WOW, especially in the summer months, where here in Boston we have already had our fair share of thunderstorms, I did wonder, as I was driving through them, if I had an increased chance. Obviously there is a chance of lightning striking anywhere, but what about electric cars, or a hybrid in ev mode. Is there an increased chance, I wonder. From my past experience with physics and weather I believe that the positively charged clouds are often attracted to the negatively charged ground, and things that are closer to these clouds (and usually good conductors) are more likely to attract a bolt. I wonder if the charge emitted by the hybrid battery is carried throughout the vehicle and as a result charges the metal parts. Something to look into for sure...
  11. Patrick Wong
    18,200
    6,500
    Hi Bear68,
    Congratulations on your success. Its great to hear that you were able to restore this vehicle to service at a relatively low cost.
    Since the lightning struck the antenna, there's no surprise that the radio head unit failed. However, how about the four ECUs that you replaced: do you have an opinion regarding why only those four failed while others survived?
  12. Sheepdog
    1,125
    Sanford FLorida
    and... Did you put a shark fin in instead of that derned lightning rod?!!
  13. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I have worked with lightning protection and radio electronic systems for 40 years. There is no reason to expect a Prius to be more or less susceptible to lightning than any other car.
    The "leader" advances in 2-5 metre increments usually, so the small difference in antenna height between vehicles will have little effect. The leader travels from the charge in the cloud to the ground (or from the ground to the charge in the cloud), taking perhaps a few hundred milliseconds to do so, in the short steps. Once completed the full charge travels up or down the path created (a channel of ionized gas), on average 2-3 times (yes, lightning does strike at least twice ;) ). Lightning can be +ve or -ve BTW. From the damage seen the pictures this was probably a -ve strike. They are usually the least powerful. The +ve strikes are the really dangerous ones, usually conducting 20,000 Amps and up. I've witnessed a 150,000 Amp +ve strike near my home, and it rattled the windows and knocked people off their feet with the sound clap. I know it's intensity because I used to operate/maintain the Provincial lightning detection system, and it records the intensity.
    In the "old days" the theory was you were protected by a "cone of protection" under the highest conducting object. This has been proven mostly wrong.
    Don't worry about what you can do to protect yourself. The only thing you can do is get the car under a metal protected structure or just take your chances like everyone else.
    In earlier days I was on a motorcycle trip, returning from the west coast, on highway 11 through Rocky Mountain House. I was "shot at" three times by a monster storm. :) Twice when I stopped to warm up my hands on the engine (each time the strike hit a tree about 100 m beside the highway). The third time was in the town of Rocky Mountain House, at a construction site on the road. I was waiting in line close behind an 18 wheeler (hoping it would protect me). The strike hit the power line at the other end of the construction and I watched three balls of "fire" travel towards me on the three phase power lines at the top of the poles, causing the lines to rise up and fall back down as they traveled (earths magnetic field and moving charges causes a force). The flag girl at the other end immediately tried to get into the foreman's pickup, who had just stopped there to confer with her. He tried to convince her to stay there and direct traffic. Funny! At least now. ;)
    Trying to guess why some computers died while others didn't will drive you crazy! Some that still work may or may not fail in the near future due to partial damage. Just be happy you found the ones that currently don't work! :)
    Oh, and yes, I have lightning protection installed on my house! My experiences over the years have made me "gun-shy". ;)
  14. Sheepdog
    1,125
    Sanford FLorida
    In FL we have a product called 'flashwarden' and can be put on the power input by the power company. I have had toasters die but the TV was fine. go figure.
    FL is the zap capital of the world I believe.
  15. Bear68
    Bear68 Member
    373
    72
    Well, the insurance company authorized a factory replacement for the antenna. I don't think the six inch height differance would change much. Lightning strikes would seem to me to be simply a matter of chance. Same thing goes for the ECUs, although perhaps those four, being in active use at the moment of strike may have had some slightly greater potential for damage.
    As for the HV system having any effect, I really don't think it likely since the actual HV components and the wiring for them is generally well insulated and protected. Within the next few weeks, I will be teaching a class for local Emergency First Responders (police and fire rescue) on safe procedures for handling Prius and other Toyota Hybrids involved in collisions. The training materials provided to me by Toyota show just how well those systems are protected to help prevent high voltage from ever reaching any part of the car body. After all, imagine using the "Jaws of Life" with a 220VDC potential! Or the thought of turning a water hose on a burning Prius!
    Thankfully, Toyota designed them very well! It would take a terrific impact even to breech the HV wiring or components and then the redundant systems would shut down the HV battery thereby protecting anyone coming into contact with the car.
  16. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    whew, i'm sure that was a hell of a bill.
  17. ZippyPri
    ZippyPri New Member
    39
    Boston
    what ever happened to the car is the one of the safest places to be in a thunderstorm? (esp. without a sunroof...right)
  18. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Did it recharge the battery?
  19. Bear68
    Bear68 Member
    373
    72
    Ahhh... but a car is safe in a thunderstorm, for the occupants that is....
    The lightning flows through the body of the car and to the ground, whether it passes through the radial tires or through the rainwater covering the tires. The people inside are not exposed to the electrical charge. A car can be repaired or replaced. So long as no one is hurt, that is the important part.
  20. Bear68
    Bear68 Member
    373
    72
    Just a little side note here... a body shop manager told me a story of a lady who was involved in a severe head on collision in her Camry. She stated she would NEVER buy another Camry as it had been totally destroyed in the accident. He was a little astonished and replied, "You walked away from a major head on collision with minor injuries (bumps and scratches) and you think the car should have survived better? It saved your life!"
    After a moment of thought she amended her statement by saying she didn't want to be reminded of the accident, a concern most can understand. Seeing a car that has been mangled by another vehicle and knowing that the passengers were able to go home to their families that night can give anyone reason to think.
