Anyone use just 3qt oil per change?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SLO Cat Wrangler, Oct 13, 2008.
  1. SLO Cat Wrangler
    SLO Cat Wrangler Junior Member
    96
    San Luis Obispo, CA
    So I was changing my oil at the ~ 15K mark and I was getting to thinking, Why am I putting in 3qts and 3/10 of a quart. Well it dawned on me that this is what you do per the instructions.
    So I also noticed that most people here at prius chat recommend not overfilling which means that you add 3.3qt then adjust as needed.
    So, this is what I normally do, however I note that there is alot of room on the dipstick.
    So could you just add back (after you change the filter) a total of 3 quarts and be safe (Note that this 3 quarts includes any oil that you prime the filter with)?
    This would rid the little left over and make changing oil a little easier.
    Anyone doing this?
    Steve
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I find that 3.5 qts hits the right spot on the dipstick every time. I save the half qt for the next oil change.
    JeffD
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    3.5 quarts is the right amount to use!
  4. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    You can get away with 3 just quarts. 3 quarts will put you exactly halfway between the "safety" marks on the dipstick. I usually stretch 2 (5 quart jugs) from wal-mart into 3 oil changes.
  5. blazer_5154
    blazer_5154 Heh, you said "member"
    106
    Maryland
    I've been doing this since the beginning with no ill effects that I have noticed. Granted, I have only done about 4 oil changes so far, but it seems to work well for me.
  6. richard schumacher
    7,666
    1,047
    United States
    55 months, 33,000 miles, exactly 3 quarts every six months. If the engine explodes someday I will certainly post about it :_>
  7. Priusaurus110
    Priusaurus110 Junior Member
    31
    Monument, CO
    This is exactly what I do at each oil & filter change. 3 qts puts me halfway between the high and low marks which is safe and creates no problems.
  8. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    3.5 quarts + Mobil 1 ("double") oil filter filled with oil at every oil change (now at 35,000).
  9. TucsonPrius
    TucsonPrius Member
    167
    Tucson, AZ
    2020 Prius
    After my third or fourth oil change I realized that it was too much trouble to worry about the extra 0.3-0.5 quart. So from then on 3 qts; oil level ends up right where its supposed to be, not too much, not too little, exactly in the middle.
    Thanks,
    Shawn
  10. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    yup, same here. 3 quarts gets me right in the middle of the high and low marks on the dipstick.
  11. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Thats what I've started doing. No more trying to stop at exactly .5 of a quart. No more guess-n-check with the dipstick + pouring more.
    Saves oil. Less waste.
  12. eagsc7
    eagsc7 Geocacher
    Prescott, AZ
    Its a GOOD thing that I read this board. Yesterday, I changed the oil, and knowing that it was a 1.5L engine(Much smaller than the V6 that our Grand Prix had), I only grabbed 2 qts of oil. Changed the oil, installed the EBH, and didn't even think about checking the dipstick. Come on I only put in 1.5 qts, and it should be good...
    Read the board, and started thinking... Hmm, I guess it dosen't hurt to check the dipstick. After a good long look in the mirror, I realized that 1.5 Qts does NOT equil 1.5L. Of course, I threw in the other 1.5 Qts of oil and then pulled the dipstick out and YEAH... Its Perfectly centered between the dots...
    Thanks for the Wake-up Call.
  13. Bob64
    1,540
    93
    Virginia
    1.5 L = engine displacement inside the cylinder. (oil does not go inside the cylinder).
    Good catch :p
  14. Patrick Wong
    18,210
    6,514
    Since the Prius engine normally does not use any appreciable amount of engine oil, this practice of using 3 quarts is OK. However as the car ages, if your engine develops a gasket leak or is burning oil, then you have less safety margin to work with.
  15. richard schumacher
    7,666
    1,047
    United States
    True, one should check the oil at least monthly in any case, to catch any increase in oil consumption.
