Portable/mini solar panels
Discussion in 'Environmental Discussion' started by djphill, Sep 14, 2008.
  1. djphill
    djphill Master of The World
    100
    los angeles
    I was thinking about getting a solar panel for my laptop. I also want to use my laptop to charge my electronics like ipod and phone. I was wondering if it would actually have a beneficial environmental affect. Also if you would recommend buying one, where could i get one for a reasonable price.
    :hippie:
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Real Goods sells stuff like that.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    If I'm not mistaken you need a pretty large/powerful panel to handle a laptop. Most of the smaller ones are fine for cell phones and iPods, but not adequate for a laptop.
  4. tripp
    4,717
    79
    Denver, CO
    I think there are 20W fold outs that can recharge a laptop pretty well. Most modern laptops draw around 40W so you couldn't power it directly in that fashion, but recharging it for use.
  5. darelldd
    6,059
    389
    Northern CA
    I've been using a 12W panel and a 12V battery to run my laptop for about eight years now. The panel keep the battery charged constantly, and then the laptop's battery also works as a buffer. I have about 10 hours of constant usage per day if I want it... but have never needed it.
  6. qbee42
    3,081
    You can use a smaller panel if you live on the sun. :rolleyes:
  7. tochatihu
    tochatihu Senior Member
    9,854
    3,815
    Kunming Yunnan China
    2001 Prius
    I was suprised to see this roll up (# 140267524574) on eBay w/o a minimum bid, Whenever you can buy in at $5 per watt (or not much more) you are doing pretty well.
    Most notebook computers use about 20 watts (I think this ir right, Tripp), which means either big panels or a battery buffer like Darell's. I am waiting availabilty of the little MSI or Lenovo subnotes with LED screen backlighting. Those can get buy on about 10 watts.
  8. djphill
    100
    los angeles
    well size isn't that big of a problem, because i have a medium sized balcony to put it on. The fact is that it has to be able to be put away somewhat easily (it shouldn't be staionary). And all the ones that i looked at are either 300 dollars or don't really go to laptops. Suggestions?
  9. tripp
    4,717
    79
    Denver, CO
    I kilowatted ours and it comes in just over 40W. It's a typical newer laptop (kinda, not really I guess. It's over a year old).
  10. efusco
    19,891
    1,196
    Nixa, MO
    I've got my Dell Inspiron 6400 (17" screen) on the Kill A Watt as I type this.
    With a 100% battery charge I'm drawing a continuous 38W +/- 3W with occ. peaks to the low 40s on the "High Performance" setting.
    When I switch to the "Power Saver" setting I drop to 32W +/- 2W.
    Charging the battery when it was down to about 60% charge drew closer to 60W +/- 5W.
    So I think you could get away with a 40W panel to give you pretty much indefinate power, a 30W on low power would keep you going for a very long time almost balancing the drain from the battery on a "power saver" setting. Lower wattage panels might extend the battery life, but couldn't sustain for long.
  11. tripp
    4,717
    79
    Denver, CO
    That sounds about right.
  12. icarus
    icarus Senior Member
    4,884
    976
    earth
    We live off grid for much of the year, and I build and install PV systems for a living. My Apples draw ~ 60 watts when fully discharged, ~30 just to run.
    When you do a calc about how many watts of panel you need for any given task, you have to consider charge efficiencies, hours of (good) sun versus how much run time (load), how long you are willing to go without plugging in etc.
    We use ~ 500 watt hours of power per day for all purposes. We generate that with 200 watts of panel, and get about 6 hours of good sun on the panels per day.
    I suggest that you visit the following site if you are really serious about PV solar: Solar Electric Discussion Forum - Powered by vBulletin
    Icarus
    PS The retail cost of panels alone are ~$5/watt. As you get into smaller, portable panel systems, they get pricier. Watch out for cheap e-bay type systems.
  13. Froley1
    Froley1 New Member
    167
    Roswell, New Mexico
    i carry a very small but expensive--and very nicely designed folding panel for my cellphone as possible backup power in my messenger bag---which seems to work well although i've never used it when the phone is completely depleted-----new mexico's sunshine helps---i purchased one of the roll up panels off ebay for my laptops---just in case--------but have never used it as of yet....
    regards
    Froley
  14. ScubaGypsy
    ScubaGypsy Live Free & Leave No Footprint
    95
    Aquidneck Island, RI
    I purchased the 25 W Sun Catcher Expedition 4 years ago. This unit is pricey but nice in that it folds up and is truly portable, has a DC female outlet and features single crystalline solar cells. I'm thinking of wiring my Prius with the 12 Vdc outlet always on so that I can place this on my dashboard and charge my start-up battery when I leave my car at the airport for extended time as I've had problems in the past.
