Vin # and Car thieves
Discussion in 'Gen 2 Prius Main Forum' started by ctbering, Nov 18, 2008.
  1. ctbering
    ctbering Rambling Man
    1,650
    124
    Chicago Illinois
    Just another car stealing scam:
    Thieves can steal cars with a VIN number. A car thief can write down a VIN #
    and call the parts department of a dealership of the car manufacturer. The Dealer's Parts Department will make a duplicate key from the
    VIN #, and collect payment from the thief who will return to your car.
    He doesn't have to break in, do any damage to the vehicle, or draw
    attention to himself. All he has to do is walk up to your car, insert
    the key and drive off to the local Chop Shop with your vehicle.
    It is illegal to remove the VIN tag but it is not illegal cover the numbers, as long as the tag remains.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Not new and not a high risk.
    snopes.com: VIN Car Thieves
    This scam wouldn't work for the Prius as the ECU has to be programmed to recognize the replacement fob.
  3. Tideland Prius
    16,602
    I believe it applies to older cars without an electronic engine immobiliser or coded key. You need an original key or the vehicle to have the key programmed. The dealer won't have the codes for your car. This is the reason why they say keep one as a spare. If you lose both master keys (the valet may or may not work), you'll have to reprogram the both the car's computer and the keys and that's a pricey job.
  4. atikovi
    atikovi Junior Member
    68
    I don't know any parts department around here that would make a key without you first showing them a registration card or title.
  5. lesturner
    lesturner Taming the Dragon - Tennessee
    75
    Bremen, IN, USA
    A valet key is mentioned in this thread... Is there such a key? I only received the two SKS fobs from the dealer. What are the 'limitations' of a valet key and how would I get one? (if available)
  6. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    There are two types of keys, the Smart key enabled one (unlocks the doors and doesn't require insertion into the dash to start the car), and the regular fob.
  7. ctbering
    1,650
    124
    Chicago Illinois
    Car thieves have stolen cars using smart keys by copying the VIN #. I think members are naive not to apply Murphy's Law to the thieves specialty of deceiving honest people in multiple ways. They steal cars using any means possible and we are not always vigilant protecting our cars, even Prius.
    If you work in a job that has strict rules or policies that prohibit mistakes from happening on a particular procedure then find out the employee either 'forgot' the policy or it was ignored because the employee didn't remember signing off that they read the policy.......believe me, in the real world sh_t happens and thieves are there to take advantage of every gap that opens in the proverbial crack in the system.
    Many of us pride ourselves at being good at what we do. Theives are no different than the general population....except, what we do is constructive, and what they do, is treat us like we are only there for their financial benefit,
    regardless of how we are victimized by their actions.
  8. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Okay, but does a new owner get 2 fobs or 3?
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Two fobs are delivered with the car.
  10. richard schumacher
    7,664
    1,046
    United States
    Thanks for your concern, but it's impossible to drive away a Prius without a correct fob (unless it's just towed away on a flatbed, in which case the thief doesn't need any stinking keys). And you can't make a correct fob without access to the car in the first place.
  11. qbee42
    3,079
    It can't be done. The Smart Key System simply doesn't work that way. The car is programmed to the key, not the other way around. So you could, if you wanted to, haul away a Prius on a flatbed truck, and then reprogram the ECU to work with your existing Smart Key.
