Engine Running at Traffic Lights
Discussion in 'Gen 2 Prius Main Forum' started by Marvinh, Dec 23, 2008.
  1. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    As we all know (I assume :rolleyes:) the engine shuts off at traffic lights. However in very cold weather, the engine continues to run to produce heat, even at traffic lights. So here's my question:
    I have noticed even though the engine continues to run, the Energy Monitor screen is not showing this. In other words, the Energy Monitor screen is blank if the engine is running at traffic lights.
    Has anyone else noticed this? I guess its normal?
    Thanks - Marvin
  2. Qlara
    Qlara New Member
    488
    That means the engine is just running to produce waste-heat.
    It's not actively charging to the battery (unless it's low) or doing work to the wheels.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Normal...
  4. qbee42
    3,081
    It's an Energy Monitor screen, not an Engine Status screen. There is no indication that the engine is running, only that it is sending power to the battery and/or wheels.
  5. priusincc
    priusincc Member
    332
    NV
    Mine also runs when stopped, if it's in "Brake".
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    A quick logic chart of when the engine runs, as observed on the Scangauge II. Probably forgot -something- but:
    IF the coolant is below about 63C AND the A/C system is calling for heat, the engine will run. If you shut of the A/C auto on the steering wheel while stopped, the engine will also stop.
    IF the coolant drops below about 63C while stopped AND the A/C system is calling for heat, the engine will start.
    IF the coolant is below about 40C the engine will run no matter what the A/C system is doing.
    IF the coolant has gone above about 63C AND you have exceeded about 62 km/hr AND the coolant is STILL above about 63C the engine will stop when the system considers it unnecessary to keep it running ("stage 4"), whether you are moving or not.
    Whenever the traction battery gets too low the engine will start and/or run until it is charged back up enough, regardless of the above.
  7. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Folks. Thanks for your replies. I was asking because its pretty cold here in New York and my gas mileage is not very good right now. :eek:
    Thanks - Marvin
