Toyota voiding warranty for changing wheels/tires!
Discussion in 'Gen 3 Prius Main Forum' started by AF-Vette, Aug 16, 2009.
  1. AF-Vette
    AF-Vette New Member
    32
    Stafford, VA
    Please help me out here. I purchased 4 Enkei RS-M (17x7.5) wheels, 215/45ZR-17 Michelin Pilot Sport A/S Plus tires, and 315 Mhz TPS from the Tire Rack three days ago for my 2010 Toyota Prius IV. This is the same size wheel and tire combination that is available on the Prius V from the factory. However, the dealer told me that I MUST have their service department install the new wheels/tires (and pay them $60 to do it) because if I installed them on the vehicle myself, THE WARRANTY WOULD BE VOIDED. I do not think Toyota can void my warranty because I install aftermarket wheels/tires, but I need to get advice y'all. What is their real issue? Are they trying to scam me for $60 just to change tires? :mad:
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yes, it's a scam. Print out a copy of the Magnuson-Moss act, and ask them to write down on paper that they'll void your warranty if you change the rims/tires elsewhere. Guarrantee they'll NEVER write it down b/c it's patently illegal.
  3. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Did they elaborate on what part of the warranty? TPS ? Why ? I agree that nondealer wheel/tire replacement could not possibly void warranty but the TPS might be an issue...:confused:
  4. grahamy
    grahamy New Member
    73
    Raleigh,nc
    Since a significant section of the manual is devoted to do-it-yourself maintenance nobody can argue that all work must be done by a dealer. I suppose if you install the wheels yourself inside out or failed to tighten the bolts, you'd lose benefit of the warranty for damage that resulted. That's it.
  5. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    What is their real issue? They want to steal money from you for nothing! Take your business elsewhere! Dealer is trying to screw you over!
  6. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    You have NEW TPS valves? If so, the dealer is right, you need them to install them, the TPS valves need to be configured for the vehicle, they are wrong about voiding your warranty, but they need to do the install or you need to go in to have the TPS configured, either way I bet its still $60.
  7. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I don't plan on even using the TPMS on my snow tires. I don't see any warranty issue.
  8. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    EJFB1029, I stand corrected. There is a very good chance that the TPMS is not paired with your car.
    I thought "AF-Vette" meant that installing aftermarket wheels/tires would void the warranty. Just see if the "TPMS light" comes on if not, you should be good to go.:rockon:
  9. djasonw
    djasonw Active Member
    960
    121
    Coconut Creek, FL
    Do you folks think Toyota would void a warranty relating to a suspension component due to the fact the owner changed the tires/rims to a size other than OEM?
  10. mainliner
    mainliner New Member
    17
    If any component fails on your vehicle and it is deemed by toyota to have been caused by modification of the original wheel size on your vehicle, it can void the warranty for those components.
  11. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    This is the critical statement. Well stated.
    The warranty would be voided, if at all, only as regards repair to a problem that Toyota has determined was caused by, exacerbated by or at least somewhat related to, an act of the owner. If the new wheels are installed and then two years later the battery goes bad, Toyota would have to show the battery failure had some link (in causality) to the new wheels or their installation. Otherwise, the warranty could not be voided.
  12. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    Dealers normally charge around 50 or 60 to reprogram the TPMS to your new sensors, assuming you are getting new sensors and not using the old ones. To me, it is worth having this done.
    Also, how do you like your new setup? I am getting those exact same tires and similar Enkei wheels. Would love to hear your feedback.
  13. grahamy
    grahamy New Member
    73
    Raleigh,nc
    That would apply whether the dealer or anyone else did the mod.
  14. AF-Vette
    AF-Vette New Member
    32
    Stafford, VA
    The Michelin Pilot Sport A/S Plus are fantastic tires! They have MUCH better traction and control (the car doesn't feel like I'm driving Jello) than the originals. The ride quality is a little firmer, but I don't think there is any change in road noise. While this won't make the car an autocross demon, The Enkei wheels look great (see attached jpg) and it does make the Prius a lot more fun to drive.
    As far as the new sensors are concerned, I drove around for about 10 mi this afternoon and there was no TPMS warning light, so I might not have to do anything. If the warning light comes on later, I suppose I will bite the bullet and have the dealer do the reprogram. Changing tires shouldn't be this difficult...
  15. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Why do you go back to the same dealer who gave you trouble. If you are going to give someone money, at least go to someone who deserves it
  16. AF-Vette
    AF-Vette New Member
    32
    Stafford, VA
    You are reading my mind. I plan to go to Merchants Tire outlet, or a different Toyota dealer. The Merchants outlets are Tire Rack "authorized Installers" and I discovered they have the same TPMS computer as the dealer.
  17. pdxrose
    pdxrose New Member
    175
    25
    Which of the 3 tires was your IV delivered with? My Bridgestone don't feel like Jello and handle very well (I forget how tiny the Prius 15s are until I look at them on another vehicle in traffic :eek:). Is it the brand, inflation leval or...
    I was one of the few people on the planet that upped my tires one size on my 03 Avalon tires since the originals handled corners, turn and rain so poorly. The dealership actually suggested it at the time and called in the order to the tire store.
    Back to the P; was happy mine came with Bridgestone since the Duellers I have on my CRV are the best tires I have ever owned. 22,000 miles and only had to put air in them twice (and like the feature that alerts me on the dask when they need it). Guess time will tell how low maint the P tires are. Enjoy your new tires!
  18. TKY
    TKY Member
    232
    25
    Colorado
    I am planning to purchase a second set of wheels and mount winter tires without a second set of TPMS sensors. As long as I buy 15 inch wheels with the correct bolt pattern and offset, I have no warranty concerns. If there is a component failure, Toyota would have to show but for the change in tires and wheels, this failure would not have. I will have an opportunity to show the change I installed had no effect on the failing component. If the TMPS failed (I don't know what this would look like), I would remount the original tires & wheels with the factory sensors to troubleshoot the TMPS system.
    I want to believe Toyota built a better car than one that would suffer any failure just because I put winter tires on. I could have winter tires on the car for five to six months each year, maybe I'll decide the approximately $240 for a second set of sensors plus $120 annually for two sensor programming fees is worth it. Right now, I plan to run winter tires without TPMS sensors and continue checking my tire pressure at least once a month. --TK
  19. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    What efusco said is correct. The Magnuson-Moss Warranty Act is a federal law that protects consumers from such tactics. The burden of proof is on the manufacturer, if Toyota were to claim that using an after market wheel on your vehicle caused problems they would have to prove it actually did so.
    Ask the dealer to put his assertion in writing and if he is foolish enough to do so send it to your state's Attorney General.
  20. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    It's B.S. I'd find another dealer for service work--if they tried to hose you on something as simple as this, imagine what they'll try next.
