Anyone here tip their prius when changing the oil?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ajbdiaz, Oct 24, 2009.
  1. ajbdiaz
    ajbdiaz youtube.com/wyldeslash2003
    31
    Thousand Oaks, Ca
    VIDEO UPDATE: So here is what it looks like when tipping the Prius, when changing its oil. All four tires were on the ground and the oil was already dripping for maybe 15 minutes. In fact, I am now is keeping it open while I rotate the tires so that it can drip from all four angles.
    Original Post:
    When i changed my prius's oil, i tried tipping the left side and a good amount of oil came out...
    that extra oil would have been hanging around if i hadnt done that...
    of course, when i did this, all four tires were on the ground. i wasnt on any stands or anything... i just readjusted the oil pan and then raised the left side of the car with the jack...
    anyone else try this?
  2. SureValla
    SureValla Member
    590
    Shelton, CT
    I jack my car all the way back to the ground during the oil change to get some extra out but never thought of jacking up the other side.
    Sounds like a good idea.
  3. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    I like to pick it up and shake it a couple of times to get those last few drops out.:)
    3 people like this.
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Yes, I raise the driver's side which not only tips the car
    slightly but also raises the entire front end a bit and makes
    it much easier to get under there.
    _H*
    2 people like this.
  5. SureValla
    SureValla Member
    590
    Shelton, CT
    How much extra oil do you think it gets out? I bet its not more then 100 ml.
    Does the 2010 have a similar "problem". I wonder why they would design the gen II like that.
  6. Patrick Wong
    18,210
    6,517
    I think you answered your own question. I agree that the amount is probably around 100 mL.
    3.9 US quarts rated capacity = 3.69 liters or 3690 mL.
    100 / 3690 = 2.7%, not enough to worry about.
  7. ursle
    ursle Gas miser
    1,049
    192
    NH
    I pour the clean 1/2 quart I'm not gonna use thru the system with the plug out, it get's plenty dirty on it's way thru...
    one could always turn the motor over a few times to make sure all the oil is out :wacko:
  8. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    seafoam :thumb:
  9. SureValla
    SureValla Member
    590
    Shelton, CT
    while 2.7% might be liquid it sounds like from ursle's method a large portion of that 2.7% is also dirt which would make it more valuable to get rid of for overall engine health.
    however the question is: Is getting rid of that dirt worth wasting half a quart of motor oil?
    I wonder if a less expensive liquid might do the job just as well...
  10. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Have you tried an oil extraction pump? I've heard the recovery rates are at least as good, if not better, and it sounds like a much easier and cleaner way to change the oil. And if you've got the oil up to temperature before removing it, there shouldn't be any sludge, because all that crap will be suspended in the oil.
  11. northwichita
    481
    102
    29
    Wichita KS
    Yes, and I was looking for the poll to vote, don't see that option. Just to be perfectly clear why this is a good idea, I also wanted to add a point about the oil pan itself (at least in my 04, am looking for pic's ) , it's made with a crease in the mid part that will retain oil if the car is level during the drain .
    Letting it set overnight to drain also helps a bit.
    This picture link somewhat shows the crease.
    http://www.vfaq.net/proj-pics/oil/oil-06a.jpg
  12. patsparks
    10,664
    569
    Adelaide South Australia
    Isn't that a lot of work, undoing the engine mounts and all, just to get a few drops of oil out? Or do you turn the rest of the car over too?
    I just pull the plug out when the engine is hot and let it drain for 10 minutes then put the plug back in. It isn't rocket science.
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Last time when I was draining oil, after the oil stream became drips, I raised the driver side a little bit. I got a very thin stream of oil flowing out which then soon became drips again, didn't seem much at all. Maybe I didn't raise the side high enough. Fill volume was about (3 + 20/32) = 3.6 quarts.
  14. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Maybe I share the same OCD tendencies as the OP. When I recently did the oil change I was under the car looking at that drain location and thinking that there must be more old oil waiting in there. I considered lifting the driver's side but didn't bother. Maybe next time I'll give it a try. Since I was using ramps I could just add a 2x6 or something under the left side ramp.
    - D
  15. philobeddoe
    575
    107
    Los Angeles
    how 'bout using just one ramp :thumb:
  16. don_chuwish
    823
    190
    Southern Oregon
    LOL, I thought of that too but figured it might be a bit too extreme. No harm in trying tho!
  17. patsparks
    10,664
    569
    Please don't do that. For safety sake use the ramps as they were intended. It seriously isn't worth the trouble.
  18. 2009Prius
    2,705
    512
    63
