d#mn aluminum hood!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mgb4tim, Oct 30, 2009.
  1. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Back in the mid/late 60's, some MGBs had aluminum hoods. Sure, they were lightweight, but they didn't like to be taken out of the garage.
    Good for me, since I make fiberglass reproductions, but bad for those who have to buy them.
    Fast forward 40+ years... who's idea was it to put aluminum hoods on the Prius???? Did anyone do their homework?
    I've found my second mini dent/chip on my hood this week. I could understand it if I heard something hit the hood, but I had no reason to suspect a dent! It would be different if it were just a chip, but a dent?!?
    Looks like I might be making a carbon fiber or fiberglass hood after all. But I'll have to fill the dents with clay to make the mold.
    Grrrrrrrr.
  2. PaulHS
    PaulHS Member
    200
    SE PA
    Wow! That takes me back. I owned a couple MGTD's, a 1954 and a 1955. I wish I'd had access to fiberglass hoods and fenders for them. The original fenders were made of heavy gauge steel, like tanks, but when there was a fender-bender, they were almost impossible to reshape.
    Sounds like you may have a winning business idea!
  3. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I have an aluminum hood on my 97 Volvo 960 with 110K miles on the clock and I'm having no problems with it. :confused:
    I keep hearing the Prius has an aluminum hood. It was a real surprise to me since it weighs so much. :rolleyes:
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I think it's the angle of the hood that catches everything. I'm gonna guess that the volvo hood is a bit thicker than the Pruis.
    I'm thinking some sound deadening material on the back, if it's accessible, could help.
    I'm also thinking a carbon fiber hood on my silver car might look sharp.
  5. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Aluminum hood saves 15-20lbs easily, why not? It is also stronger than steel, resist rust. The hood is also higher than the engine, you want as little weight as possible up top
  6. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    there's no was that small hood save 15-20 pounds. A steel MGB hood weighs 27 pounds and it's a good bit bigger.
    How is the aluminum hood stronger?
    I would venture to say they are more costly, as well.
  7. qbee42
    3,079
    I would take an entire aluminum body if the price was right.
  8. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    More malleable than steel seems to be the issue here. A steel hood would probably spring back from hits that the current hood can't...
  9. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    try a land rover defender...LOL
  10. cossie1600
    903
    94
    CT
    Your MGB also came from the 50s, where they haven't figured out how to build a safe or a reliable car. The chassis on that thing is softer than a piece of noodle, jack up one side and try to open the door if you don't believe me.
    RX-7 was one of the few cars I know that came with the option of steel or aluminum hood from the factory, the difference was over 20lbs on that vehicle.
    I don't know the exact grade of aluminum or steel Toyota uses, but I am pretty confident that they would pick a piece of aluminum that is strong enough to be part of the front end of a vehicle......
  11. cossie1600
    903
    94
    CT
    The car would also be 15-20lbs heavier, it would handle even worse. I would admit that aluminum does cost more.
  12. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    Aluminum is mixed with other metals to produce a variety of aluminum alloys, and these alloys are subsequently given a spectrum of heat strengths. So just because the Prius hood is made of an aluminum alloy does not necessarily mean it is more prone to denting than some other material. For decades aircraft structure and aircraft skin have been made from aluminum alloys - quite successfully.
    As for my 2010 Prius - no dents so far.
    Jim
  13. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Softer than a noodle? Check this out - http://www.tgnagy.com/mgb/images/200007/spit1.jpg (from http://www.tgnagy.com/mgb/progressPages/199912.CFM)- mounted on the bumper supports (still there today as I havn'et been able to work on it lately) that are part of the unibody chassis.
    Sure, all the MGB's rusted at the thought of water, but that's imported Russian steel for you.
  14. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I realize that aircraft use aluminum skins. I'm just making the statement that I've not had a car hood dent so easily. I've seen paint chips from. highway rocks, but they've never dented like this. Especially when I didn't even notice the rock hitting. You'd think that a rock that hits like that would startle you, like when they hit a windshield.
    My intent is - if you are on the fence about the clear plastic bumper and hood protection, get it.
  15. cossie1600
    903
    94
    CT
    that's right. so stiff that most of them are totalled. there is a reason why miata are great sports and race cars and why mgs aren't
  16. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    I've actually contacted a few of the import tuners in the Southern Cal area to see if they make a CF hood for the new Prius. I guess my initial reason for it would be lighten the car (although the weight savings would be barely substanital), but then my ulitmate reason would be to have a something that looks different. I have a winter grey metallic with the solar panels, so the look of a black carbon fiber hood might match the blackened glass and solar panels... Too bad none of them have contacted me back.
  17. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    118,185 miles of driving my 2004 makes me wonder about cause. Since all I had was a bunch of tiny pits from all the winter sand & salt, I'd suspect a non-driving event.
    For me, the color of aluminum & silver paint makes the tiny chips pretty much impossible unless you're standing on top of them. No rust bleed or steel flaking to ever wonder about (a big deal here in Minnesota) sure is nice. The reduced weight is obviously a perk too.
  18. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    All Miata's have aluminum hoods. Doesn't seem to be a problem there. I assume the angle of the Prius hood as well as aluminum being softer metal combine to be a problem.
  19. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Are you serious? Nothing like a few decades of technological advance to give the Miata a bit of an advantage? Have you ever ridden in a sport tuned MGB? Have you ever driven a tuned MGB? They are a heck of a good time. Sure a Miata will outrun your average MGB, but it would outrun a Mustang of the vintage same era.
    I didn't think I'd have to defend my second child here, I'm just miffed at the hood of my car that has 2 dents within 3 months of ownership. I had my Caddy with a dent-free steel hood for 146k miles.
    Just trying to grieve a little. Thanks for the shoulder to cry on;).
  20. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    My NSX was all aluminum and never had a problem with dents.
