daylight savings Time change
Discussion in 'Gen 3 Prius Main Forum' started by So Grateful, Nov 3, 2009.
  1. So Grateful
    So Grateful New Member
    Kirkland, Wa. USA
    hello everyone, I have a generation three 2010. When my clock changed from daylight saving time it gained five minutes how can I manually put in the correct time
  2. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    To the right of the Steering Wheel, on the dash to the left of the On/Off Radio knob, there are three little buttons, the leftmost is the hour button, the middle is the minutes and the far right zeros the minutes.
    Pressing These buttons will advance the Hours/Minutes, or will set the Minutes to 00.
    David (aka Blind Guy)
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    David -
    You must be a kinder soul than me - I was just writing...
    Don't mean to be sarcastic - but did you check your owners manual? And surely your Prius dash clock did not change from DST by itself?
    but saw your post before hitting 'submit'. I mean is it quicker to open a thread to ask a simple question as this instead of checking the owners manual. In some areas the manual can be confusing but clock/time changes...
  4. So Grateful
    Kirkland, Wa. USA
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    why wouldnt it?? under clock setup you do have the option to enable or disable it
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It wouldn't because:
    1. Politicians tend to mess with the dates.
    2. Most clocks don't, including my GII.
    3. Most clocks that do check with WWV. WWVB actually. The Prius can't do that (or can it?).
    Nice that the new model has a clock that does. Hope it doesn't get screwed up by some change to DST in the next 10 years. :p
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    it do
      File size:
      82.5 KB
      1,081
  8. creativeguy
    creativeguy Member
    301
    17
    CA
    I seriously doubt that the clock on the dash in any 2010 Prius auto changed for DST. Mine did not, and my parents' new Prius did not, despite setting the option in the clock settings in the nav. I think that those settings are for configuring the internal navigation system clock.
    As far as I can tell, the clock on the dash is just a dumb digital clock controlled by the 3 buttons to the right of the steering wheel. Since that clock is standard on all models of Prius (II - V), whether you have nav or not, it doesn't make sense that it would be connected to the nav options in any way.
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok. i can agree with that
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    If it makes you feel any better, mine gains a minute every couple of months - it's the first digital clock I've ever had that ran FAST.
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well dont really know what it does. i use the "00" function to reset it to time various misc things in my life so it wasnt really set. not sure what it did BACK IN OCTOBER since that is when most computers would have done DST anyway.
    but then again, i use my cellphone as a clock and none of the house clocks had to be reset due to a chore that was not completed from last spring
  12. RodJo
    RodJo Member
    423
    56
    Boston
    Or just read the other threads asking the same question and getting the same answers? And, besides, it's not like Toyota invented the H-M-:00 buttons for setting digital clocks. What else would they be used for? :confused:
  13. Geistemite
    Geistemite Junior Member
    31
    Menifee, CA
    And what about the AM/PM indicator at the clock itself? Does anyone really need this to keep informed? I have not been able to determine when this might be helpful, as usually I can determine if it is day or night by looking out the window. :)
  14. IraS
    IraS Member
    165
    Austin, TX
    This thread got me curious about daylight savings time, since I just adjusted the clock manually.
    After playing with it for a while, I realized there are two completely independent clocks in the Prius (with navigation). The clock on the dash (i.e. at the right of the MID) is a simple digital clock controlled by the H, M, and :00 buttons on the dash. That is the clock I reset.
    The second clock is built into the navigation system. It apparently gets the time from the GPS satellites. The navigation system has a setting page where you can set the time zone and turn daylight savings time on or off. This only affects the clock in the navigation system.
    So, when the time changes, you apparently must set the clock on the dash manually and the navigation clock will change automatically.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok. since the NAV works on knowing time (and very accurately at that) i can "easily" see why it would need us to tell it what time zone we were in etc...after all, why would i expect a NAV system to know where i was??
    the clock setting is just that, clock setting. NAV does have a setting which is completely separate but nevertheless, i agree the clock did not reset to DST, none of them do.
    now, if i were to set my area to Eastern time zone, would i get lost?
  16. boppo
    boppo Active Member
    799
    139
    Owego, NY
    time for some dusting.
  17. creativeguy
    creativeguy Member
    301
    17
    CA
    The AM/PM designation is a sign of Toyota's confidence of how comfortable the new seats are. You can get bombed out drunk and pass out in your car. Once you awaken a few days later, you'll easily be able to tell what time it is.
  18. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Great response for the need for the AM/PM designation. LOL.
  19. Blind Guy
    352
    194
    IraS;
    Where on the Nav screen is that clock located? My wife looked all over that screen, and can find NO clock or digital readout ANYWHERE!
    She's already set the Time Zone and DST, she's even looked in some of the Settings Menus, but unable to find anything that allows you to Show/Display Clock/Time...HELP!!!
  20. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    I held the "HH" (hour) button down until the clock stepped forward 23 hours.
    There was no DST auto-change in the time.
