Recent Activity
Activity stream for all registered members at PriusChat.
bryanpenn liked Serk's post in the thread 4th Gen DIY heat exchanger bypass solution.
Texasdiver, all I can say is thank you a million times. My 2016 Prius 3 started smoking on me and I noticed my coolant levels dropping....
May 8, 2024 at 12:53 PM -
ChapmanF replied to the thread any hack to record the digital rear camera ?.
Part of the fun is just determining what signal standard(s) the car is using. In my gen 3, the analog camera is going straight to an...
May 8, 2024 at 12:48 PM -
Mendel Leisk replied to the thread Manual maintenance California shops.
125k is running into thin ice on the head gasket front; get on EGR cleaning soon. See top two links in my signature; on a phone turn it...
May 8, 2024 at 12:47 PM -
ChapmanF replied to the thread Replaced ABS in 2007 Prius Now THIS....
Person 1 can be replaced with a Brake Rock when necessary. I have a telescoping windshield squeegee I use for the same purpose. Unlike...
May 8, 2024 at 12:42 PM -
reallyreal replied to the thread Thinking of buying a new Prius, but.....
In MPG anything from 38 to 56 may be typical with the 19", as a conservative all-year average I would say around 47
May 8, 2024 at 12:37 PM -
ChapmanF replied to the thread Coolant does not flow through cooler.
This part of the story would suggest to me that the open circuit being reported is not in the water pump itself, and diagnosis of the...
Zeromus liked HacksawMark's post in the thread Traction Battery Discharge in HEV Mode.
Geez, that is steep, more than what some charging stations would charge. Where I live, I pay a flat 6 cents per kWh above the minimum...
May 8, 2024 at 12:15 PM -
Zeromus replied to the thread JBL Premium sound system problem.
They've done sufficient troubleshooting and others have chimed in to point out that its not the phone, and if it is software, it's...
Paul Gregory replied to the thread Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?.
NOCO is a good choice. I use a NOCO 2. It doesn't give you any surprises like other maintainers which can turn themselves off for no...
May 8, 2024 at 12:11 PM -
Anything like that should work. I find it doesn't take much power to start up the system. Once that happens, the DC converter kicks in...
May 8, 2024 at 12:07 PM -
Trollbait replied to the thread Tesla Autopilot recall probed by safety regulator following new crashes.
The others already incidences involving their Level 2. As for the hypotheticals, we'll have to wait until they are required to do a...
May 8, 2024 at 12:05 PM -
Trollbait liked Zeromus's post in the thread Tesla Autopilot recall probed by safety regulator following new crashes.
I think you're taking this a bit too personally. I found an article that was a bit more clear on the issue at hand with key parts...
May 8, 2024 at 12:01 PM -
pjw3 left a message on Mendel Leisk's profile.
You are such a rock star https://priuschat.com/threads/dome-light-wont-come-on-when-i-open-door.156916/
May 8, 2024 at 12:00 PM
