“Check Hybrid System” error
Discussion in 'Gen 3 Prius Main Forum' started by GreenTea&SaltWater, May 28, 2021.
  1. bisco
    52,891
    bill murray would be proud...
    Valiant V and Grit like this.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    looks like you bought the car with an undisclosed underlying hv battery issue. Replaced the cells and the issue still there. After failed start ups, looks like the hv battery SOC is too low to even start ICE. Surprised # of hv bars on the dash wasn’t mentioned. Replace the hv battery pack or charge the pack back up and gear up for wack o mole level 2.
    Samuel Williams Jr likes this.
  3. ChapmanF
    19,055
    ... and by reading the trouble codes we could even find out whether that has anything to do with the OP's car ... or could just keep pulling ideas out of the air.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    when you removed the orange safety plug from the HV battery, did you reinstall it with all three steps to ensure the safety interlock contatcts were seated? If not, the battery display normally drops to one or zero bars.
    It will also prevent the car from going to ready mode, even with a good 12v battery.
  5. Samuel Williams Jr
    246
    Dayton NV
    Well a viable plan B, mostly to confirm your screwed? Have a friend with an older simple car, with a know good battery and in true MacGyver, style take his battery out of his car. Put it in your trunk, disconnect your battery and connect the two with jumper cables. :)
    Granted it's a bit of effort but, you would know for sure it's not the 12 volt battery. And I think, although I don't know if you boot up the computers you could then read code?
  6. ChapmanF
    19,055
    The computers boot from the 12 volt battery, and do their checks, and it is at their discretion whether to proceed to bring the traction battery online and make the car READY.
    When you give them 13.2 to 13.8 volts and they boot up and decide not to make the car READY, if you ask them why they have decided not to, in most cases they will tell you.
    Could it be because of not sliding the traction battery plug? There's a code for that. They'll tell you. Could it be because of the traction battery condition? Maybe. They'll tell you. Some other reason entirely? They'll tell you.
    Valiant V and Samuel Williams Jr like this.
  7. Samuel Williams Jr
    246
    Dayton NV
    Oh good one! I have heard of folks screwing up reseating the safety plug properly! :)
  8. GreenTea&SaltWater
    199
    58
    Los angeles
    The ready does not show. Must be the hybrid battery
  9. ChapmanF
    19,055
    If the READY does not show, the car's computers have decided not to show the READY. They have a reason for that, and they will tell you the reason if asked. Or you could consider the number of possible codes and play the odds guessing.
  10. bisco
    52,891
    if the 12 volt is low,
    the ready will not show
    Valiant V likes this.
  11. GreenTea&SaltWater
    199
    58
    Los angeles
    The HV battery level on the dashboard is 4 short of being fully charged. How could I charge the hybrid battery? Would I have to discharge and recharge each individual cell multiple times over?
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,135
    6,985
    Texas Hill Country
    In post one and four you said you had an obd2 scanner. In post three you said you read the battery fail code with Techstream. What scanner are you using now? Do you have an obd2 bluetooth device? It would be useful to read the hv battery data and report it to determine if you are spinning your wheels with your current focus.
  13. GreenTea&SaltWater
    199
    58
    Los angeles
    I used TechStream 1.5 years ago but I don’t have access to that at the moment. My OBD scanner shows an old code from 1.5yrs ago and now my car is completely dead so it doesn’t show anything
  14. KevininFl
    KevininFl Junior Member
    62
    16
    Fort Myers Fl.
    Disconnect the 12V battery completely both terminals for 2 plus hours.
    This should fix the problem most of the time.
  15. ChapmanF
    19,055
    Once the 12 volt battery is well charged and reconnected, if the car will power ON but still not show READY, do consider asking the car's computers why not. The difference between asking us and asking them is that they know and we don't.
  16. rjparker
    11,135
    6,985
    Texas Hill Country
    The hybrid battery is not the Master of its Domain. The car's computers are the guys in charge and they run on the 12v battery exclusively when you try to go to Ready.
    If the OBD2 scanner is not working, its likely the 12v is too low (12.0 vdc is enough), the scanner itself is faulty or the car's computers are not getting the 12v power from the battery. The last item is often caused by blown fusible links and fuses, quickly caused by a one second reversed polarity jump.
    So, check the 12v at the car's front fuse box jump point. Then try another scanner just to be sure the port works. Finally check the fusible links and fuses.
    By the way, the hybrid battery has a big relay (contactor) that only allows hv power after a series of computer operations provide the magic Ready. Even then the hv battery is only taking orders from the computer overlords. It is never in charge.
    #36 rjparker, Jun 25, 2021
  17. ChapmanF
    19,055
    Also, even if the car's computers are not making the car READY, that doesn't have to mean they're not getting the right 12 volt power or that they're not doing their job.
    Their job is to run their checklist and decide whether to make the car READY. If they do that and their decision is "nope!", well, that's their job. Ask them why.
  18. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Where's the fun in that? Everyone would much rather use a Ouija board or play darts blindfolded than actually test things. (somewhere someone once fixed a problem by doing "x", so you should first do "x" as well, because you might have "the exact same problem"!!)
  19. rjparker
    11,135
    6,985
    Texas Hill Country
    I am not sure the Op is resisting codes in favor of guesses. Since this is primarily a diy site (almost always suggesting the member hook up, diagnose and then tear into it), combined with a scanner that no longer works, it seems prudent to move in a direction that gets a scanner functional.
    In a diy capacity or at a shop.
  20. silverbackmg
    silverbackmg Junior Member
    Louisiana
    Very similar situation here. Just put new motor in the car. 2010 Prius. Everything powers up. Radio, lights, wipers, flashers, A/C, dash, etc… will not go to ready mode. I’ve checked and changed fuses, new 12v battery, it will not start.
