“Quality Confirmation Activity”
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Dec 19, 2024.
  1. Prodigyplace
    12,712
    11,848
    Central Virginia
    Does this just apply to just the Prius or all Gen 5 Hybrids? I have a 2025 Camry that apparently has a flooded battery located in the trunk area.
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    I don't know, but I would upgrade to an AGM battery when I needed an out-of-warranty replacement. The reason why OEMs use flooded-cell batteries is because they cost much less for them, but for us buying an aftermarket battery, they cost the same; so, there is no point in opting for a far inferior technology.
    Prodigyplace likes this.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    If, as implied, they have differing charge requirements, could that not cause an issue? IIRC my 2017 Prius had a flooded battery under the hood. I replaced it once between October 2016 & September 2024 when the car was totaled.
    Gokhan likes this.
  4. Gokhan
    6,714
    2,661
    Paramount CA
    I and @Roy Peterson both have an AGM battery in my Gen 4 Prius Prime and in his Gen 5 Prius Prime, and we have been observing much better performance with it. In fact, Roy was having problem with his OEM flooded-cell battery, and he is very happy with the AGM battery now. See the thread I linked. Virtually all owners report poor performance with their OEM flooded-cell battery.
    One possibility is that the BMS was originally designed and tested for an AGM battery, but Toyota replaced it with a flooded-cell battery during production to reduce the costs, which is causing problems with the 12-V battery. The even smaller Gen 2 and Gen 3 batteries were AGM, and they lasted for ten years without any problems.
  5. Prodigyplace
    12,712
    11,848
    Central Virginia
    Thank you.
    I had no issues with my 2017 Gen 4 Prius and did replace the flooded cell battery with another one due to aging out.
    Gokhan likes this.
