0-60 time?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SJ PiP, Nov 27, 2012.
  1. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I'm going to necrobump this thread because I've found what seems to be good info on plug-in versus normal 0-60 times. When reading reviews, times are all over the place. From Toyota's 9.8s, which I'm guessing are just copied/pasted from their figure for a normal Prius, to a little less than 11 seconds with no EV range remaining. From what I can tell, with a full battery, the plug-in is about half a second faster to 60 than the normal Prius, which should be at 9.3s using Toyota's number.
    This difference comes from the INEL's testing, which is probably better than any automotive mag. They put the 2010 at 11.8s, the 2012 plug-in at 11.3s, and for good measure, the Volt at 10.2s. Their times are higher (likely more accurate too) across the board compared to the manufacturer ratings/auto mags, probably because they aren't trying to sell cars ;)
    http://avt.inel.gov/pdf/hev/fact2010toyotaprius.pdf
    http://avt.inel.gov/pdf/phev/fact2013toyotapriusphev.pdf
    http://avt.inl.gov/pdf/EREV/fact2013chevroletvolt.pdf
    It's a bit ridiculous to be honest. Motortrend's ~20% difference between the 0-60 of the Volt (8.5s) and the PIP (10.6s) is literally double the difference that INEL measured (10.2s versus 11.3s). Granted, that shouldn't be surprising given that even manufacturer's seem to be inflating the numbers, but it's no quite as bad when the numbers are uniformly inflated.
  2. lensovet
    2,615
    496
    Burlington, NJ
    But all those numbers are still in blended mode :-(
    52,880
    isn't that what the o/p is looking for?
  4. lensovet
    2,615
    496
    Burlington, NJ
    Who cares about the OP, he's probably stopped watching this thread lol
  5. bisco
    52,880
    you think?:p
  6. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Haha, yeah. Most of the published 0-60 times are blended too though, and being off by that much is kind of annoying.
