02 air conditioning fans
Discussion in 'Generation 1 Prius Discussion' started by bigblock67, Jul 31, 2021.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    Do both fans kick on when pushing AC button. How do they operate . 2002
    Thanks
  2. ChapmanF
    15,510
    Wiring diagram's definitely worth 1000 words for Gen 1.
    It's the usual Prius arrangement, three relays, two fans, series for low speed, parallel for high speed.
    The ECM gets a vote (if it thinks the engine needs more cooling). The A/C Amplifier gets a vote, if it thinks more cooling is needed for A/C. There's a separate single contact on the refrigerant pressure switch that gets its own separate vote. The water temperature switch in the inverter cooling loop gets a vote.
    If no votes, the fans don't run. If the inverter temp is the only vote, both fans run low speed. Add any other vote and they both run high speed. If anybody else votes and the inverter temperature doesn't, looks like one fan runs high speed and the other is off.
    Weird.
    I think Gen 2 had a similar-but-not-the-same Rube Goldberg control arrangement mixing real switches and ECU outputs. It wasn't until Gen 3 they finally said "you know, we'll just drive all three relays from the ECM and use software to decide when to run the silly fans."
    #2 ChapmanF, Jul 31, 2021
  3. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    I would have mentioned that this was a Gen 2 forum and you own only Gen 1 and Gen 3 but after I saw the list of classic cars that you own, I was too awestruck. Amazing collection.
  4. bigblock67
    171
    35
    Indiana
    2002 Prius
    I am having a problem finding Gen 1 forum. Very little patience and very little time. These cars keep me very busy as I like to fix stuff myself. It’s getting tougher at my age. probably give up on chasing this AC issue. Over my head
    Thanks for note
    Don
  5. ChapmanF
    15,510
    It's a subforum under Gen 2. Lots of people have trouble finding it.
