'02 with P0171 code getting better mileage?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by atikovi, Apr 1, 2008.
  1. atikovi
    atikovi Junior Member
    68
    Soon after refueling, the check engine light came on and after getting home I scanned it and found the P0171 code for lean operation. The car runs like before but oddly the gas mileage is way up. Ususally I get in the upper 40's but for the last 100 miles it has been over 56 mpg. I'm not complaining but what can I check for this code. After erasing it, it comes back after 10-15 miles. Coincidance that it happened after refueling? Bad fuel? Gas cap problem?
  2. Patrick Wong
    18,200
    6,479
    You might have one or more of the following problems:
     Air induction system
     Injector blockage
     Mass air flow meter
     Engine coolant temperature sensor
     Fuel pressure
     Gas leakage in exhaust system
     Open or short in A/F sensor (bank 1, sensor 1) circuit
     A/F sensor heater (bank 1, sensor 1)
     PCV valve and hose
     PCV hose connection
     ECM
    When the engine is running so lean that you actually see an mpg improvement, this may mean that smog emissions are up, with more NOx being formed. Also engine longevity may be impacted when operating under higher combustion chamber temperatures.​
    Regarding the air induction system, check for a loose oil dipstick or oil filler cap. If not loose, inspect the rubber seals on those two parts.​
  3. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    Check if your gas cap is on tight. Since it happened after you refueled...I always undo the last thing I did, unless I liked the new MPG.. which I do.:eek:
  4. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    i have same prob, same code.. and better mpg also..
  5. runlikehell
    runlikehell New Member
    Milpitas, CA
    2001 Prius
    Anyone manage to resolve this? I've been seeing it for a few months now on my 2001 Prius, but otherwise no other symptoms or issues.
  6. atikovi
    68
    Yes. Removed the CHECK ENGINE light bulb.
  7. tf4624
    tf4624 Active Member
    526
    51
    LOL you have an issue
    • The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filter may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
    • There could be a vacuum leak downstream of the MAF sensor.
    ossible solutions include:
    • In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
    • Inspect all vacuum and PCV hoses, replace if necessary
    • Check for a dirty fuel filter and proper Fuel Pressure
  8. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Most likely cause is bad MAF sensor, common on older 1nz engines. Try a new one.
  9. Ian Viney
    Ian Viney New Member
    Christchurch, NZ
    I had these symptoms too. I had an oil change done and a new air filter on my 2008 Prius, which had been operating fine. Within 20 km the engine light came on, caused by a P0171 code. The car seemed to be going fine, and fuel consumption had improved by about 5%. If the code was reset, it re-appeared in 10-20 km. Of course, I was concerned about the engine light being on, so I took the car to a mechanic They checked for vacuum leaks (including simple things like the oil filler cap seal), cleaned the MAF sensor, replaced the spark plugs (which were due) and cleaned and reset the throttle body. The engine light is now off and the fuel consumption has improved by another 5%.
    I am 99% convinced that the only thing wrong was that the old air filter was quite dirty, and the new air filter let a bunch more air into the engine and the difference was so great that the system perceived it as a problem. So I think it was resetting the throttle body that fixed it, which I could probably have done myself it I had understood it a bit more! It may even have come right by itself given enough time (though 100 km wasn't enough).
    Interestingly, I haven't seen 'throttle body needs to be reset/calibrated/relearnt' in the lists of possible reasons for a P0171 code.
  10. dolj
    dolj Senior Member
    7,791
    3,943
    Wellington, New Zealand
    Most probably because for a trained mechanic it goes without saying. For others, they don't know what they don't know.
