04-09 Corollas vs 04-09 Priuses
Discussion in 'Gen 2 Prius Main Forum' started by Tewie, Aug 28, 2016.
  1. Tewie
    Tewie New Member
    Earth
    When it really comes down to it, is it safe to say that the 04-09 Corollas are simply better (more reliable) vehicles than the 04-09 Priuses? There's nothing worse than having a car that when you put the key in the ignition, you're crossing your fingers in hopes that it turns over.
    I'm looking for a car where I can reasonably expect to not have any major problems and only have to perform basic maintenance for the next three or four years. With that in mind, is it best that I call it a day and just go with the Corolla?
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Tewie, I'm sorry we scared and confused you in the other thread.
    You're not going to go wrong with either one. Neither one is really more reliable than the other. Around here in southern California, though, the Corolla is going to cost $1,000 - 2000 less out the door.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Right now, I suspect the Prius is a better more reliable vehicle. In 5 years, i suspect the Prius will need a battery, so the Corolla will look better.
    If you get a Prius, there are choices you can make to make it more reliable.
    1) never jump start another car, and if you need a jump start, replace your battery immediately. (jump starting wrong, even for a second can cost $4000.
    2) Drain and fill the ATF WS in the transaxle every 90,000 miles. (If new, add 30,000 miles, then 90,000) You are trying to remove suspended metals.
    3) Try not to overheat the battery, use A/C when you are hot, use B mode from the top of down long hill slopes, park in shade.
    (Earth is a horrible location, so I can't give any more detailed advice. If fact, no one can give you good advice on most topics)
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    No, not safe to say.
    But in your other thread you say: "I'm in the market for a new car and my main concern is reliability, fuel economy, cost of insurance, and maintenance costs (in that order). Based on that criteria, which car would you choose between an '08 Prius with 100k miles and a 2014 Mirage with 40k miles (both comparably priced)?"
    It's based on THAT criteria that I recommended in the other thread that you consider other vehicles.
    The truth is no Used Vehicle in the 7 to 12 year old range is going to come with any "guarantees" as far as reliability. That is you could buy a Prius and have it last years without a problem, or one could develop relatively quickly and the same goes for a Corolla.
    But given your original criteria and budget, I recommended considering other vehicles.
    IMO if there is ANY chance owning a Hybrid could exceed your maintenance budget, AND you are not 100% sold on owning a Hybrid?
    Then standard ICE choices I think can be better. If only because you are not dealing with the reality of both ICE components and Hybrid Components. However....
    If you are absolutely sold on owning a Prius? Try to find the best you can within your budget.
    Corollas IMO are nice vehicles.
    They would if in good shape meet most of your original criteria.
  5. Tideland Prius
    16,677
    I assume you mean '03-08? 2009 is a different generation.
    Both will require basic maintenance assuming you've done your homework and have each potential vehicle checked out before purchase. The Gen 2 Prius may have an issue with the 7" LCD (but ours didn't) and it may require a battery replacement if it's a high mileage or older vehicle (ours did at 245,000km). Of course, if you can find a newer version of each, that would be better as it will have lower miles and hopefully all the bugs ironed out of the early model years.
    Here's a used car review I found for each.
    http://www.autos.ca/used-car-reviews/used-vehicle-review-toyota-corolla-2003-2008/?all=1
    http://www.autos.ca/used-car-reviews/used-vehicle-review-toyota-prius-2004-2009/?all=1
  6. Tewie
    Tewie New Member
    Earth
    Thanks, different vehicles such as?
  7. Tewie
    Tewie New Member
    Earth
    '03 to '09 are both 2nd generation in the U.S. Thanks for the links, btw.
  8. The Electric Me
    9,083
    5,801
    Many were suggested in the thread, including Corolla.
    And for some reason you hate Honda.
    What other vehicle you might like, is up to you.
    But there are plenty that would fit the criteria you have chosen.
    I personally have nothing against either Toyota Corolla, Yaris, or Honda Fit or Civic.....
    My previous vehicle was a Honda Fit, and I thought it was a great vehicle.
    If Honda is the devil?
    Then they made a devil of a great compact hatch.
  9. Tewie
    Tewie New Member
    Earth
    I'll look into a Yaris, thanks.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
  11. iamvietdang
    iamvietdang Member
    57
    60
    West Palm Beach
    Four Touring
    The E120 Corollas are nearly bullet proof with the 1ZZ engines. They make the 2009+ seem like they were all made on Fridays.
    iPhone ?
  12. Tideland Prius
    16,677
    I was talking about the Corolla. 9th Gen is 2003 to 2008 model year.
    For the second generation Prius, it's model year 2004-2009.
  13. Tewie
    Tewie New Member
    Earth
    This isn't Canada, it's '03 to '09.
  14. Tideland Prius
    16,677
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I think he is discussing the Gen 9 Corolla:
    In August 2000, the ninth-generation Corolla was introduced in Japan ... The North American release was delayed until March 2002 (for the 2003 model year). Production in Japan ended in January 2007 but production in North America continued until October 2008 - Wikipedia
    This may be the 2003 - 2009 he is talking about, not the Prius.
  16. Tideland Prius
    16,677
    The 9th generation Corolla in the U.S. (and Canada for that matter :rolleyes:) ran from 2003 to 2008 model year. The 10th generation Corolla was launched in March 2008 as a 2009 model.
    "Delayed" isn't quite the right word. Our Corolla has always lagged behind Japan during the late 90s and 2000s. In August 2000, our Corolla (8th generation) would've been only 2-3 years old. The 8th generation Corolla was launched in the fall of 1997 as a 1998 model. It ran from 1998-2002 with the midlife update for the 2000 MY that saw the addition of VVT-i to the 1ZZ-FE engine.
    IOW, the 9th Gen Corolla was introduced in 2006 IIRC while we didn't get it until March 2008 (as a 2009 model).
    The only way he's seeing 2003-2009 is if he's in Europe or Asia where they do not conform to "model year". Therefore, a 2009 Prius could refer to both the 2nd Gen and the 3rd Gen (for example). (And hence why you'll see a number of Gen 3 UK members here with a "2009" year in their profile)
  17. ETC(SS)
    7,523
    6 vs half dozen.
    We're talking about 8-10 year old vehicles here and both the Prius and Corollas have their drawbacks.
    The Prius is a proven workhorse and you have a better chance of finding a one-owner, adult driven Prius than you will for a Corolla BUT you're probably looking at some maintenance and repair costs for either vehicle........because they are going to be 8-10 years old.\
    I'd lean towards a Corolla but ONLY if I could find a one-owner unit with fairly low miles and a fairly clean and verifiable pedigree.
    Good luck with that BTW, because I've just described the perfect college/learner/commuter car, and they're in high demand.
    Always.
    The Corolla will be cheaper to buy, and might be slightly cheaper to insure but will be more expensive to operate.
    Both will be about the same to maintain out to 200,000 miles since the Prius will have the battery to replace (maybe) but the Corolla will chew through brakes a little bit more quickly.
    Me?
    I'd cast a net wide enough to consider either one....
    Good Luck!
    Let us know what you come up with.
