04 Broken auto leveling headlights - fixed!
Discussion in 'Knowledge Base Articles Discussion' started by joules, Nov 18, 2007.
  1. Danders1999
    Danders1999 New Member
    Kansas City MO
    Just want to say thanks to you and the other posters. I have 2005 Prius that developed the headlamp leveling fault couple years ago, then miraculously cured itself...only to return this summer and not go away. So, 11 years in to ownership, and years after the initial helpful posts on this problem, I bought a replacement OEM part, and installed it myself. I would not have been able to diagnose, identify replacemenr part, and install without all your helpful information. My sincere thanks!
    kenmce likes this.
  2. C Wagner
    C Wagner Member
    183
    60
    Boston
    Thanks so much for taking the time to document this. My 04's level sensor just went at 180,000 miles. I'm in Boston, where corrosion is the norm in winter...
  3. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    It's not that bad a fix (unless you are working outside in a Boston winter) :rolleyes:
    C Wagner likes this.
  4. C Wagner
    C Wagner Member
    183
    60
    Boston
    I just posted my workaround fix to this; with the $20 part, the fix involves slipping under the car, disconnecting the harness connector from the bad assembly and attaching a newly purchased sensor, set to the middle of its potentiometer range, and zip-tying the new sensor onto the car securely...
    Automatic headlight leveler Warning | PriusChat
