04 Prius Automatic Headlight Leveling System Warning Light after lift kit
Discussion in 'Gen 2 Prius Main Forum' started by Damian BSO, Aug 11, 2023.
  1. Damian BSO
    Damian BSO New Member
    Burbank
    Hello, I lift my 2004 Prius about an inch a while back, and the automatic headlight leveling system warning light has been on ever since. I haven't been able to find much information about how to fix that, does anyone have any suggestions. Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    That is a pretty good one I get rid of those lights and don't have the light levelers after I switch to the halogen lights with LED bulbs in them because of the halogen housings don't get auto leveling seems to me you could unplug the auto leveling I would think but possibly not or unplug it and put a jumper wire in it something a resistor who knows just to make the light go off should be something fairly simple like that. I would think the guy that sells all the lifting and ground clearance parts. Should have ideas about this.
  3. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    The sensor is located on the LH side at the rear up near the top of the strut. Check that you did not damage the connector, wiring, or the sensor itself.
