04 Prius wont start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TeeTee97, Nov 19, 2020.
  1. TeeTee97
    TeeTee97 Junior Member
    My 04 Prius has been sitting due to me working from home because of the Coronavirus. The doors and lights come on but i cannot start the car. Is it the Hybrid battery and what can i do. Help!!!
    52,878
    try a jump start, jump pack, battery charger or new 12v.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Its the hybrid battery.
  4. TeeTee97
    I had a new 12. Out installed
  5. TeeTee97
  6. TeeTee97
    What are my next steps? Can the hybrid get a charge...or do I have to get another one? Thx
  7. edthefox5
    10,096
    4,840
    Clearwater, Florida
    There’s many different paths for the hybrid battery. Your not alone there all failing because people stopped driving there cars andan old battery will self deplete. I assume it’s the original battery which tells me the car was driven a lot till suddenly it’s not. That’s hard on the battery modules and Some modules have probably failed so I doubt a charge will fix this long term.
    At that age the battery needs to be replaced anyway.
    Like many posters you are asking a global question and not giving any info so we can advise.
    How long have you owned the car
    How many miles
    White state do you live in
    What is your diy level worked on cars all your life and understand and own lots of tools and a good DVM?
    Know what an obd code reader is
    Have strong electronic skills.
    How much money do you want to spend.
    A new battery is $1600 you install.
    Alternatives are much cheaper and much more work and time and not so much a greater degree of long time success.
  8. bisco
    52,878
    your next step is to measure the 12v under the hood. if it and the connections are good, should read above 12.6v.
    after that, you need to have the trouble codes read at a dealer, or qualified hybrid shop with tech stream software.
    TeeTee97 and edthefox5 like this.
  9. TeeTee97
    Thanks for the info. I owned the car about 5 years and it has low milege - under 100,00. It is the original battery and in Feb.20 i had the modules cleaned Im not mechanically inclined. I cannot read the codes. I do believe i need a new battery.
  10. TeeTee97
    Thanks for the info!! Stay safe!
  11. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    If you don't mind sharing, who did that service for you?
  12. TeeTee97
    Prius hybrid repair shop
