05 Ac troubles - Bad compressor?
Discussion in 'Gen 2 Prius Technical Discussion' started by silver_05, May 9, 2013.
  1. silver_05
    silver_05 New Member
    Tucson, AZ
    Hi Folks,
    I have a 2005 Prius, purchased 5 months ago with 100k miles, and it currently has 106,000 miles.
    The air conditioning blows cool, but not cold. When the A/C is turned on, it makes an unpleasant whining noise. I have a recording of it, but can't upload it or post a URL... if anyone wants to hear it, just message me and I'll send you a link.
    It did not make this noise 5 months ago, and the A/C output was colder then. I haven't used the A/C that much over the winter, but it's starting to warm up now and I've noticed it's not doing as well as it used to, and it isn't sounding very good either.
    I attached manifold gauges this evening, when the ambient temperature was 80 degrees F (27 degrees C) and noted that with the A/C off, both high and low sides read 7 bar (.7 MPa.) I then turned on the A/C on maximum cooling for a couple of minutes and read the following pressures:
    Low side: 4 bar (.4 MPa)
    High side: 10 bar (1 MPa)
    From the Toyota shop manual I see that the desired pressures (apparently at an assumed ambient temperature of 86-95 degrees F) are:
    Low side: 1.5-2.5 bar (.15-.25 MPa)
    High side: 13.7-15.7 bar (1.37-1.57 MPa)
    Even after adjusting for my slightly low ambient air temperature, it seems to me that these numbers are saying that my A/C compressor is:
    1. not lowering the pressure on the low side nearly as much as it should, and
    2. not raising the pressure on the high side as much as it should.
    Given the noise that it's making and the pressure readings I've found, it seems to me like it's time to start shopping for a new compressor... what do you think?
    Thanks,
    Silver_05
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Can you post the sound/video of it on YouTube?
  3. silver_05
    Tucson, AZ
    It's at ghostlodgemusic
    dotcomm
    slash
    Prius
    slash
    Prius_AC.wav
  4. lech auto air conditionin
    830
    606
    261
    san francisco
    #1: ? Did you just hook up a set of Gauges with out vacuuming out the hoses and manifold that are full of air and moisture? the number 1! enemy to your air conditioning system. If you have access to a set of gauges, do you have access to a refrigerant recovery unit to remove all the refrigerant with out dumping it to the atmosphere?. #3: Then start from zero use the vacuum pump to pump it down to below 500 microns, after that use your refrigerant scale to weight the factory SPEC of refrigerant charge in. Then do your diagnostic only on a known full system.
    but other then that if your compressor is a noisy as you say it's not a good thing. If your refrigerant is low you must find the leak first because a Prius running on a low refrigerant charge is death on a compressor.
    ? has your car ever been in a front end hit and had to go to a body shop for repair ?. Body shops recharging air conditioning after replacing the condenser from a accident is the #2 reason Prius compressors burn up. You can go to my photo album and look at some photos of what small leaks look like on the front of your condenser. This is a common place for a Prius to have a leak, but this is all guess work with out seen it my self and using a refrigerant leak tester and refrigerant analyzer and other test equipment to test your A/C system.
  5. silver_05
    Tucson, AZ
    Thanks for your responses!
    1. I have never seen a mention of vacuuming out the hoses before attaching a manifold gauge in the instructions to this or any other manifold gauge or car. Doing so would cause more refrigerant to be lost each time the gauges are hooked up, and since the pressure of the air in the lines (1 bar) is lower than the pressure in the A/C system (7 bar) it is unlikely that any moisture or air present in the manifold would make it back into the A/C system. If I see manufacturer's instructions indicating that vacuuming out the manifold before pressure testing is a good idea, I'll start doing it. For now I'll follow my manufacturer's instructions.
    2. I take cars to a local shop to have the refrigerant removed, then drive home and replace the necessary parts, flush if necessary, vacuum out the system for 45 minutes and recharge it myself.
    3. Given the noise it's making and the apparent ineffectiveness of the compressor based on the pressure readings, it seems to me that if I'm going to take the time to evacuate and re-charge the system, I might as well take it apart, install a different compressor ($100 used / $200 rebuilt / $666 new) and dryer element ($20) and maybe more depending on whether I find any shredded compressor guts in the system. I'll also replace the O-rings and keep an eye out for potential leak sites.
    As far as I know this car has never been involved in an accident or had the A/C worked on.
    Regards,
    Silver_05
  6. lech auto air conditionin
    830
    606
    261
    san francisco
    sounds like you got it covered, Y atmospheric Pressure is 1 bar., but when you hook up a set of hoses the refrigerant goes into the hoses and mixes with the air. As the compressor cycles up and down it also draws in the mixed refrigerant WITH AIR, and as you supposedly close down the high side first then open the low side to remove the refrigerant that is in the hoses and gauge manifold it draws in the air to, a gauge set can easily hold 3 + OZ (90 g) of refrigerant in them under pressure ( I bet your instruction did not tell you that). Do the math, A prius refrigerant charge is only 420 to 490 G if you remove 90 whats the %. 3 oz up or down on a Prius is a large amount.
    That is were you get the air and moisture in a car when someone dose not even know what they don't know, and that is exactly why I have so much A/C work $$$ and a large percentage come from Prius. The instruction that come with air conditioning tools is not complete only a base guide line. They figure they will be used by professionals who have been trained and have a base knowledge of the fundamentals of air conditioning. 80+% of all my Prius work comes from other repair shops, body shops, and DIYs after they fixed it. It worked good for about the first year then after one or two more tries it comes to me. It is vary easy to replace parts and recharge it and get it to blow cold. The trick is to get it to last the LIFE of the car!!!.(y)
    koolingit likes this.
  7. epoch_time
    epoch_time Active Member
    236
    110
    las vegas
    Your high and low side readings look good, Provided electric compressor is running at low to possibly medium speed.
    My prius gen II electric compressor pulls 2 amps at its very lowest setting . But pulls up to 22 amps in highest speed...
    Your high and low side pressures will be directly related to compressor speed which is continously variable..
    Factory spec. would most likely be with compressor running full speed..
    If your compressor is making clanking (metal on metel) sounds then be concerned... other wise possible small leak.
    What do you see in site glass (liquid freeon or bubbles...)
    My site glass shows all liquid after 5 minuts with air on low speed outside air 73 degrees F.
    But turns to half liquid at higher demand with hotter temperatures.
    check/clean cabin filter,
    look for oil stain on condersor coils which is in front of radiator.. oil always indicates freon leak..
    I you suspect leak add smallest amount of freon to attain better cooling.
    Do not an oil.. only freon at first..
    If you do add oil It has to be special electric motor winding compatable oil for hybrids...
    You should not need to add oil for small leak..
  8. silver_05
    Tucson, AZ
    Update: I replaced the compressor, O-rings, and dryer element, and now it sounds like it should and cools like it should.
    I found the replacement compressor, ND-11 compatible hybrid compressor oil (which I didn't end up needing because the compressor came with oil) and dryer element for good prices on EBay. Two cans of R134 and O-rings (pack of 24 HNBR green in various metric sizes for $5) were purchased at my local Autozone. Tools required were 10mm, 12mm, and 14mm socket wrenches, 3" socket wrench extension, 14mm hex driver, manifold gauge, refrigerant can tap, vacuum pump, and blacklight to check for leaks.
    What I did: take car to local shop to have refrigerant recovered, bring it home, lift the front of the car onto jack stands, remove the left and right black plastic pieces that go from the back of the front bumper to below the front of the engine (extending into the wheel wells,) remove the plastic piece that covers the top of the upper radiator support, unplug orange electrical connector from above, free orange cable from retainers, remove one bolt each from high-side and low side connections to compressor, remove three bolts holding compressor to engine, remove upper radiator support (and a bracket that was attached to it) in order to get access to the plastic dryer housing on the driver's side of the condenser mounted to the front of the radiator, unscrew dryer housing cap from below with a 14mm hex driver (the inverse of a 14mm 6-point socket - a 14mm hex key would also work) to replace the dryer element, then measure 4 oz of oil into new compressor, reassemble, vacuum out, and recharge with 16 oz of R134 with UV dye and no other additives.
  9. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    One has to wonder why the compressor is still mounted to the engine? I'm sure the engineers have noticed that it no longer requires a drivebelt. Of course, design is an evolutionary thing. It will eventually be relocated as engine compartments receive total redesigns, I suspect. Does the refrigerant shop charge for removing (and recycling) the gas?
  10. silver_05
    Tucson, AZ
    I was thinking the same thing... why mount the compressor to the engine where it is subject to extra heat, vibration, and movement, when it could be mounted to the frame somewhere out of the way. I'm guessing they just put it on the engine so they could use refrigerant lines similar to those that were used in the previous belt-driven compressor.
    I had the refrigerant recovered at JayBee's in Tucson. They didn't charge me for the service, maybe because I've been a long-time customer of the shop. (They did get to keep the $20 worth of R134, but that doesn't really make it worth their time.) JayBees has a top-notch team of professional mechanics who have always done excellent work for me, and they are one of the few shops in town where I can send non-mechanically-inclined female friends to get work done, knowing that they won't be ripped off. The only other place in Tucson I'd take the Prius is Falconworks. They are a shop that specializes in two things: British cars, and the Prius. So if there were ever a serious problem with my inverter or battery pack, the sort of thing you'd want a Prius specialist for, I'd probably take it to Falconworks.
  11. lech auto air conditionin
    830
    606
    261
    san francisco
    Tesla mounts the compressor on the floor in the front trunk on the frame just about in front to the passengers feet on the other side of the fire wall. I think i posted a photo in my photo album of a striped down Tesla body and showing the DENSO electric compressor same as the Prius has.
  12. r3meyer
    r3meyer New Member
    26
    What compressor did you end up going with? Used, Reman, or New?
  13. Coolride17
    Coolride17 Junior Member
    55
    My advice being in the trade for 25yrs., while your ac is working OK, shoot about an ounce of oil in the system, because in hundreds of system repairs, I found the mfg's just don't put enough oil in from the factory, nor refrigerant.
  14. rods2105
    rods2105 New Member
    denton tx
    Definitely dont use dye-it is not made for the type of oil used in Prius-it is pag based.
