05 brake accuator failure DIY/help
Discussion in 'Gen 2 Prius Main Forum' started by Priusstich, Apr 11, 2018.
  1. Priusstich
    Priusstich Junior Member
    17
    Wisconsin
    bought an 05 Prius, i knew it had a inconsistent brake problem. Well now its consistent...... a consistant beep and vsc abs and brake lights on. No brake pressure.... no leaks... barely stops.... brought into toyota to get scanned they pulled the, well it will be $90 dollars to scan it...... like people have money coming out of there ears lol....
    1. What mini vci is compatible for the actuator bleeding process? (I hear some will shut off halfway through.)
    2. where do i download tech stream? On what series of windows?
    3. Can i get any brake actuator from 04-09?
    Any help is appreciated... thanks again pruis gang...
  2. dolj
    dolj Senior Member
    8,652
    4,401
    Wellington, New Zealand
    1. Mini VCI is pretty much a crap shoot as to whether you will get one that will work reliably. Many work good enough to read codes, which is for what most are using them. Better options are Tactrix Openport 2.0 (USA designed and built) or VxDiag Nano for Toyota (Chinese). Be sure that you do not buy a clone or a counterfeit of these products, they are out there.
    2. Techstream can be downloaded from the TIS website as part of the $55 for two business days subscription.
    3. Can't comment on this, you will need to see if the part number is the same across 2004-2005 and 2006-2009. If it is a different part number, what is the difference. May be the 2006-2009 part (if different) superseded the 2004-2005.
    Not sure why people (in general – and this is not specifically directed at the OP) are affronted by having to pay for a diagnostic. Most mechanics would be happy to not charge for it if people then went on to have the repair done in their shop. But the way it has gone is that people started to use mechanics as a free diagnostic service which for some reason a lot of mechanics felt this was taking the p1$$. The resulting push back is charging for the service.
    The reality is that mechanics have to feed their children and provide a roof for their families. Even if it takes 15 - 20 minutes to read a car, followed the 20-30 minutes discussion of what is wrong and the options to fix, right there you have 35-50 minutes in direct labor costs – $70 - $100 right there. Then there is the purchase of multi vehicle brand capable scan tools, and ongoing update costs to accommodate new models. Not to mention licensing costs for brand specific IP.
    Come on people, $100 - $120 for a diagnostic is not robbery.
    Yosarian likes this.
