05 Coolant Pump Operation Questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ggarman, Feb 17, 2008.
  1. sreese01
    sreese01 Junior Member
    Patrick,
    Good evening. My teritary theory is proving to be valid. I compared an unmessed socket with the same relay terminal sockets as the one that seats the CHRS relay. Turns out I've boogered the female terminals. It looks like that part of the box can be removed but distinguishing it from the rest of the illustrations is proving to be bothersome. Is this repairable?
    Thanks,
    Scott
    Referenced Illustration
  2. sreese01
    Following up:
    We are in working order. The relay box's terminal for the CHRS relay was, more or less, dislodged from its proper position. Needle nose pliers and carefully sliding it back in did the trick. No error code this morning. Looks like its a win. I attached a link with a picture that shows the front and back of the relay box for that relay position in a "before" state.
    Link to image
    valde3 likes this.
