05 Engine Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nickbike, Nov 11, 2010.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Great story, congratulations!
  2. nickbike
    nickbike Junior Member
    24
    25
    Colorado
    The transaxle from the same car is listed on Car-Part.com--Used Auto Parts Market for $750. car-part.com is where I found the engine.
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Let us know what caused all this to begin with. Thank you it was interesting, H
  4. nickbike
    24
    25
    Colorado
    From what I could tell it sounded like it was coming from the bottom of the engine. We think a drop of the oil pan will give us our answer. If not, we'll pull the valve cover and then the head if needed.
  5. Hal W
    Hal W New Member
    872
    53
    Maybe worth while to repair and resell? H
  6. nickbike
    24
    25
    Colorado
    Are you guys ready for this? It threw a rod bearing. At $500 for a "new" engine with 23,000 miles on it, this one isn't worth rebuilding.
    Video of the piles of metal shavings in the oil pan/pickup
    Video of cooked rod bearing.
    The water pump on the old engine was leaking too (pictures attached).
    5 people like this.
  7. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    No big surprise on the water pump, but trashing the rod bearing after only 110,000 miles? Makes you wonder if there was a manufacturing defect, assuming that the oil was changed regularly. I suppose it is possible too that regular trips over e.g. Vail Pass with the pedal floored could have shortened the service life. Thank you so much for sharing your story.
  8. Patrick Wong
    18,210
    6,517
    Great work. Amazing how much clearance there was on that bearing.
    I'm wondering whether you will remove the valve cover to see the condition of the valve train?
  9. LoveMyPriusIII
    LoveMyPriusIII New Member
    66
    I'm curious about the condition of the valve train as well.
  10. nickbike
    24
    25
    Colorado
    After the transplanted engine from the 2009 featured in this thread start burning oil and the hybrid battery going out twice, this car is now in a junkyard. More details here
  11. bisco
    52,767
    she's a beauty, how much do they want for her?:p
    but seriously, how many miles did you put on in the last 5 1/2 years?
    #31 bisco, May 10, 2016
