05 lights not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Desiree Vigil, Mar 24, 2020.
  1. Desiree Vigil
    Desiree Vigil Junior Member
    Pacifica
    I was just gifted a 2005 Prius ( I’m very thankful) but today the dash board lights (speed light) went out and when I tried turning off the car and pulling out the key it wouldn’t ?!
    It was sorta like stuck ON , I pushed the break paddle and tried turning it off but nothing happened !
    Anyone else have this happen , what was causing it?
  2. Desiree Vigil
    Pacifica
    Also my car wouldn’t turn off also couldn’t pull key out
    52,391
    generally, you need a new speedo meter, but test the 12v first
    Desiree Vigil likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    @Desiree Vigil
    Yes, the famous combination meter failure. It's caused by some capacitors starting to fail in the combo meter circuit board. Typically, it's an intermittent problem. It happened in one of our 2005s 2x in 6 months and then never again. Some people experience complete failure, others, not so much. Hopefully you're one of the lucky ones.
    When it's in failure mode, you should be able to make the car turn off by holding the power button depressed for about 10-15 seconds.
    If you're able to DIY, it costs about $150 to get one from @Texas Hybrid Batteries. He's a member here and runs a hybrid shop in Texas.
    If you decide to have the job done at a dealership, it's in the $700-800 range IIRC.
  5. Todd Greeneway
    Todd Greeneway New Member
    Appleton
    I have a 2008 Prius and could get dash light on by pushing start button, holding in button, and flickering lights. But when I changed out 12 v battery , that trick doesn’t work any longer ‍♂️
  6. Brian1954
    Brian1954 Senior Member
    2,408
    964
    South Central PA, USA
    See the thread that you created for this problem: https://priuschat.com/index.php?posts/3484175
