05 MFD dark area - like CRT burn
Discussion in 'Gen 2 Prius Audio and Electronics' started by OldManHatch, Aug 7, 2021.
  1. OldManHatch
    OldManHatch New Member
    South carolina
  2. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Looks like the backlighting is failing.
    A replacement MFD installed is $300 from places I’ve seen.
  3. OldManHatch
    South carolina
    I spoke to someone about this.
    It’s sun damage.
    The digitizer definitely has to be replaced and maybe the depending on the damage the lcd.
    now I have another question.
    I haven’t pulled the MFD to verify the model # but according to Toyota the last 4 of the replacement is 7081 yet all the units I see on eBay that are 7080/7081 are the standard units not the nav unit.
    I have the nav unit.
    Is the catalog number incorrect.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    the 7081 is the low-def model. It's actually -47081. Has 4 buttons (not 7 like yours) and is non-nav.
    #4 TMR-JWAP, Aug 8, 2021
  5. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    The picture in post #1 is also of a low-def unit.
  6. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Technically correct, lol. Allow me to fix that...
    the 7081 is the low-def base model.
  7. Another
    1,819
    520
    Naples, Florida
    If it’s only the digitizer, it looks like the replacement part is cheap. Maybe $40
  8. OldManHatch
    South carolina
    I just spent the $180 for a different unit.
    I think there is a company that buys used MFD for $75 so I may ship the old one to them provided the replacement works.
    Did all NAV units have Bluetooth
  9. dolj
    dolj Senior Member
    8,631
    4,385
    No.
  10. OldManHatch
    South carolina
    Well hope the one I got did if not I will send the other one off for repair
  11. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    It's relatively important to replace an MFD with an identical model. I have about 15 mfds in my shop. I have two different test plugs for the different models. This is because different models have different pin-outs for receiving power. If the power supplied on the plug wires in your car-side harness does not match with the required 'power in' pins on the mfd, popping noises and smoke will come out of the mfd. I've accidently learned that lesson a couple times by plugging in the wrong test harness.
  12. OldManHatch
    South carolina
    I understand. I will check prior to hooking up the replacement.
  13. OldManHatch
    South carolina
    The replacement I purchased was the same part #.
    Everything works as it should.
    Setup Bluetooth without any issues.
  14. Another
    1,819
    520
    Naples, Florida
    How long did the whole remove and replace take?
