05 MFD question
Discussion in 'Gen 2 Prius Main Forum' started by Kelsololz, May 21, 2018.
Tags:
  1. Kelsololz
    Kelsololz New Member
    Oregon
    I have and 05 Prius that I recently wrecked. And I was planning to buy another non-running 05 Prius to use parts off of to fix my current car. The non-running Prius has a navigational MFD. Is it possible to swap my non-nav MFD out for the navigational MFD from the other car?
    #1 Kelsololz, May 21, 2018
    52,905
    you might need an antenna, not sure how that works.
  3. Kelsololz
    Oregon
    Still looking for an answer
    52,905
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    If I were in this situation, I’d pay $15 for a 2 day subscription to techinfo.toyota.com and have a look at the wiring diagrams and connectors and see what’s the same or different;).
    I’m sure it an be done, just not sure what else you’d have to adapt to make it work:cool:.
    But the $15 you’d spend would help with that assessment :).
    How many miles on your wrecked Prius?
    Keep us posted (y).
    #5 Raytheeagle, May 24, 2018
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Nav units have a different steering wheel and controllers too. Also, it's old DVD tech with no updates and modern phones/apps are WAY better.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Most likely no. The electrical connectors on the back of the unit are typically different for each model MFD. Many times the differences are subtle. IE...they may both have a 16 pin connector, but the small alignment tab or slot will be located in a different position, preventing the plug from fitting.
    Take a look on ebay for each model. There will probably be plenty of photos that you could compare, but I'm going to stick with "No".
  8. Kelsololz
    Oregon
    Thanks for the answer! My wrecked Prius has about 180,000 miles on it at the moment.
    Raytheeagle likes this.
  9. Kelsololz
    Oregon
  10. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    I only recollect one person recently who was a go-getter type that did this just out of interest, as retrofitting was he was into, and did it just because.
    I can only suggest you use google to search this site, as it does a better job with fewer key words.
    Using this code on the Google search page: ...
    Code:
    site:priuschat.com "gen 2" Install nav in non-nav car
    ... I found this: post #4 | Install of OEM NAV in 2009 Prius w/o NAV | PriusChat
    I don't think you will find anyone to hold your hand on this one, sorry, it is just not something anyone cares to do anymore given modern options available.
