05 MPG down to 35...what's wrong?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ken S, Jul 24, 2010.
  1. Ken S
    Ken S Member
    191
    Pittsfield, MA
    Please delete incorporated into below post to limit forum clutter.
  2. Ken S
    Ken S Member
    191
    Pittsfield, MA
    My trip hasn't changed at all and I change the filter myself...it's clean. The A/C doesn't seem to be working overly hard most of the time. I keep the thermostat at 77 and the car cools down quickly.
    Had my mechanic check the parking brake...it's not dragging. I'm not sure how I can test the HV battery. The dealers just say everything is working properly.
    I'll have the the transaxle pump checked...thanks.
    Cabin air filter is clean.
    I did the brake on and off a few times about a month back when someone else suggested the brake might be dragging.
    I put an Optima in.
    Engine Air filter has 4K miles on it (changed it last oil change).
    I think I'd notice a misfiring plug...but hey..always worth checking.
    The only thing that I've noticed...and it could just be my imagination is a slightly louder growl from the car when I start moving from a stop sign, etc. I'm not sure it's reality or just me searching too hard for something wrong.
    My gut tells me there's something not working properly with the H/V system....now to just get someone from Toyota to really look at it.
  3. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    My SWAG: :rolleyes:
    Could a hole in the exhaust pipe/muffler be causing the MPG drop?
    Two scenarios:
    * between ICE and Calytic Converter
    * between CC and tail pipe.
    In first case, wouldn't there be a code thrown?
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Please do get back to us on the exact make, model and size of the current tires. If possible, let us know that of the previous ones.
    It's odd that they're "mandatory". 2nd gen Priuses came w/15-inch wheels and touring versions had 16-inch. 17-inch wheels will hurt fuel economy vs. smaller ones. If those Toyos are high rolling resistance, that'll make things even worse.
    Did you ever tell us details about your trips as in distance, time, how much stopping or stop and go? Also, did you ever actually get your alignment checked? It "feeling good" isn't a check.
    There's a reason why I put up http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html. I think you should answer at least these:
    - How are you determining fuel economy? (trip computer or manual calculations)
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
  5. derkraut
    derkraut Member
    299
    28
    SAN
    17 inch wheels on a Prius? There goes your mpg, IMO. For optimum mpg, you should have std size wheels, and 40-45lbs psi.
  6. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I think it's more than just an opinion about lost mileage due to larger wheels. When CR tested base (has 15-inch wheels) vs. touring Prius (has 16-inch wheels), the latter got worse mileage. See http://web.archive.org/web/20080618...-advice/most-fuelefficient-cars-206/index.htm.
    On the 3rd gen, we were told by the chief engineer that 17-inch wheels would knock off ~1 mpg vs. the 15s (http://priuschat.com/forums/gen-iii...m/57380-what-did-we-learn-chief-engineer.html). http://priuschat.com/forums/gen-iii...ill-wider-tires-decrease-mpg.html#post1096974 also mentions a mileage hit for 3rd gen 17s.
    When the OP responds w/his make, model and size of tires, he should also tell us the max sidewall pressure listed.
  7. Bob64
    1,540
    93
    Virginia
    Whats the recommended tire pressure for 17' wheels? Usually low profile tires require a higher pressure i think.
  8. Patrick Wong
    18,210
    6,515
    There have been repeated suggestions that the OP should have the wheel alignment checked. I would not minimize the adverse impact that excessive toe-in can have. I recommend that the OP should have front toe set precisely at 0 and the rear toe set to be slightly positive (need to use shims to adjust the rear wheel alignment, a specialty wheel alignment shop can do this) for the sake of vehicle high-speed stability, consistent with the alignment specs.
    Further, one item that has not been previously suggested is that engine coolant temp needs to be checked, after the engine has warmed up - drive 10 miles or more at freeway speeds. Scan Gauge can report engine temp.
    Another way to check this is using a handheld IR temperature gauge, pointed at the thermostat housing or the radiator hose attached to that housing. Also check the temp at the engine coolant sensor screwed into the engine head. Operating temp should be around 185 degrees F.
    If the temp is much lower then the thermostat is probably stuck open. This will not log an engine ECU DTC. However the engine will run inefficiently if below the correct operating temp and this will have a huge mpg impact.
    2 people like this.
  9. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Great suggestions Patrick. Several others related to the gas engine (that we often forget or take for granted) are also wise.
    :D
  10. ursle
    ursle Gas miser
    1,049
    192
    NH
    I agree for optimum mileage, I run 45 series 17" rubber, this summer my daughter used the car during august, my mileage was down in the 51.5ish range (about 10 tankfuls since a reset) but am now at 54.6 just going to .7,
    I'll give up 2 or 3 mpg's for a much more secure ride, ie:great tyres
    err, some people just drive in a manner that is not going to get very good mileage, even in a Prius.
  11. Ken S
    Ken S Member
    191
    Pittsfield, MA
    Thank you for all the suggestions...I'll try to answer the questions here.
    Just to recap the issue:
    2005 Prius with approx 49,000 miles - Purchased new.
    Until about five months ago I noticed my overall MPG dropping significantly.
    Before the problem: Car would average between 43 and 45 MPG it now averages between 33 and 36.
    On the occasion I was driving highway only 65MPH+ for extended periods the car used to lock in at 39.7 MPG almost automatically. Now, if I do a similar drive the MPG won't go over 37.
    Shortly after noticing this problem I was driving on a highway and got warning messages and the large drop in power...the car didn't shut down and I was able to drive it to a nearby dealer who diagnosed the problem as a bad water pump for the HV system. They replaced it (under my extended warranty). Mileage hasn't changed since then.
    At the suggest of some members here and replaced the battery with an Optima yellow. The old battery was close to five years old, but still tested as being good both with the car's diag screen and my mechanic's test equipment.
    So...after going to two dealers and a trusted mechanic who I've known for years no one can seem to find anything on the car that is wrong. This is worrisome to me because cars don't have their fuel efficiency change that dramatically without there being some sort of an issue. Nothing about my driving, drive or changes to the car or environment has been drastic. I live in Florida...the temperature generally is between 75 and 90....the biggest "hill" around here are the speed bumps in parking lots. I don't carry loads other than two small children or groceries.
    I'm at a loss...I guess I need to get someone from Toyota to actually look at the car and tell me why with under 50,000 miles the efficiency has dropped so radically without any error codes.
    Sorry about the long posts...I very much appreciate everyone's help and I'm trying to answer any questions you toss back at me. If I missed one tell me and I'll get the info. I'll try to report back as well, especially if anything changes.
    (Answers below each quote)
    Parking brake is not dragging...I had it checked.
    Not sure how to get Toyota or a dealer to actually check if the HV battery is weak. They keep telling me everything is operating normally (2 different dealers).
    1. It took me two years to get the Toyota dealer to not overfill the oil (4 qts added). They now fill it to the full line and have done so for quite some time.
    2. Cooling system - This is a possibility. I've got to find someone that can/will check this. Toyota dealers keep telling me everything is fine.
    3. I replaced the cabin filter myself several months back and do so on a regular basis.
    4. Had the emergency brake checked and did cycle it...I rarely ever use it.
    5. Haven't changed trans axle fluid...will look into it.
    6. Optima batter (yellow top).
    7. Air filter was changed relatively recently and is clean
    8. According to two dealers and a private mechanic the spark plugs are fine.
    1. Cabin filter is new...and really wasn't very dirty when I changed it.
    2. My commute is exactly the same as it has been since I purchased the car.
    1. There's no evidence of a hole in the exhaust and a visual check while it was on the lift didn't reveal anything.
    Okay...
    1. Tire size is listed above in this post.
    2. Toyotas sold in Florida are sold through SE Toyota which does the import and then sells them through dealers. SE Toyota puts a bunch of options on the car (leather seats for instance) and then the dealer installed the big rims, tinting etc. In 2005 it was very difficult to buy a Prius and you either took what the dealer offered or were in for a wait of over a year. So, basically...you were forced to purchase wheels, tinting, door edge moulding, etc. if you wanted the car.
    3. It's important to note though that I've had these wheels and size tires since purchase so while they may not be the most MPG efficient they have been there since day one and I'm not sure I could consider them in why the fuel mileage would drop from the 43 - 45 range to the 33 - 36 range.
    4. I don't "hypermile" or drag race. I'm generally driving two small boys so I try to use the "glass of water on the dash" system. I'm long past the need to blow people away, screech tires. Most of my drives are in the 35 - 45 MPH range...not a lot of traffic a few traffic lights. I have more details in the OP and the top of this post.
    5. I computer MPG two ways...first with the Toyota display, but I'm old school and my father always taught me to do the math at the gas station (Miles driven/gallons used). Both numbers are always reasonably close.
    I don't disagree...but they're what was on the car when purchased new...and cost $1,800.
    Their website lists max pressure at 50psi
    1. Had the alignment checked by trusted mechanic...he stated it was spot on. In addition, there's no pulling or uneven treadwear.
    2. I will have the coolant temp checked.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    It sounds like a frustrating problem Ken, you seem to have checked everything but still no joy. I agree with you about the tires, they're not optimal but if they've been on the car the whole time then it's not likely to be the cause of the decrease.
    Since you've tried just about everything you can it mightn't hurt to try the following. Could be "clutching at straws" but one user who posted a similar story to yours of declining MPGs said that they restored their MPG with the AMSOIL "PI" fuel additive listed here : Featured Products
    Please note that this story was very anecdotal (at best) and the user never followed up on whether or not the increased FE persisted after using the product. Given all that you've been through it couldn't hurt to give it a try. See reply #35 here : http://priuschat.com/forums/gen-ii-prius-fuel-economy/60794-reduced-gas-mileage-4.html
  13. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Maybe the two kids have being growing fast and adding tons of weight to the car? :D Sorry, couldn't resist.
    Now seriously, I would think twice before using any additives because
    1. There were other users having bad experience with additives, and
    2. If there is indeed some mechanical issue as the OP is suspecting, then masking the problem with additives won't help solve the root cause.
    Just my two cents. Good luck! :)
  14. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    I should probably keep my mouth shut ...but... Occam's razor keeps slapping me in the back of the head as I read your problem.
    Since the problem started around the time the inverter coolant pump failed I'd be very suspicious of everything about the replacement pump and the inverter cooling circuit:
    Is it possible a peice of the impeller from the old pump broke off and is stuck somewhere in the cooling circuit?
    Is it possible the hoses were put on backwards when the pump was replaced?
    Is it possible there's a kink or twist in one of the hoses?
    All of the above would partially block coolant flow and cause the inverter to operate hotter but maybe not hot enough to register a code.
    Maybe one of the people who know what they're talking about could tell you how to monitor the temperature of the inverter. Good luck -- you've really done your homework and deserve an answer or solution to your problem.
    UKCLASSICPRIUS likes this.
  15. 2009Prius
    2,705
    512
    63
    I think we need to go back to examine what changed before and after the MPG drop. It looks like the pump failure is the only big thing. (It may have failed sometime before the warning messages got triggered.) Was it the inverter coolant pump? If so then here is one possible hypothesis. What if after the pump failure the big power transistors in the inverter were thermally stressed to such a degree that their internal resistances have permanently increased? If so then more fuel will be wasted as ohm heating. Unfortunately it will be very expensive (an inverter replacement) to prove or disprove the hypothesis.
  16. 2009Prius
    2,705
    512
    63
    Getting the inverter temperature from the computer messages is doable but not trivial. I like your hypothesis better in the sense that it is more easily fixable, unlike mine. Good points! :)
  17. Ken S
    Ken S Member
    191
    Pittsfield, MA
    Gas mileage is still down...although I've noticed as the air temperature has dropped from 90 to 82/83 it has improved. I keep the air conditioning set at 77.
    I was able to run a diag scan on the car and saw coolant temperatures stay in the range of 180 - 189. There were no trouble codes.
    I still have yet to see a tank over 37 MPG average in months.
    Anyone got a suggestion on how I can get Toyota to do something about this? Both area dealers just say everything is fine.
  18. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    What you describe sounds like the hybrid system just isn't functioning correctly. I don't think it is related to the inverter, though, since power to the A/C is usually the first thing that gets cut off.
    Possibly the HV battery air duct is blocked? This is located on the passenger side between the back seat and the door. If you can hook up a 1 inch hose to a shop vac and snake it down in there, it might pull out a bunch of crud, and that would be a good indication of the problem. I remember being a kid and stuffing things into all kinds of weird places --- dropping rocks down plumbing vent pipes on the roof was a special favorite because it made a really schwoomp cool noise, and it made the toilet overflow too. Through karma, my own kids regularly turn the back seat into a rolling landfill nowadays.
    Anyway, if that duct is blocked, then there is no way for the fan to cool the batteries. Basically, they are already hot when you start the car due to the weather, then get even hotter due to the preferential use of the HV battery to propel the car as the ICE warms up, then if they don't get cooled off by the fan you will only see limited boost/regen, and thus lower MPG. If the fan itself isn't working, then it should throw a code. But several scan tools can test it, including AutoEnginuity.
    Monitoring the engine temp was a very good idea. If the car was not reaching the full hybrid mode stage post-warm-up (coolant temp = 165F+), then fuel economy would be impaired. This might still be the case, that there is some other temperature sensor (cat. converter?) that is not up to normal operating temperature and is causing the engine to stay in a rich-burn mode. This also means that full hybrid functionality is not available (warp steath, no-arrow glide).
    Finally, there is a possibility that I didn't see anywhere was having your injectors cleaned and tested. This is not entirely consistent with what you have described, which seems like a problem with the hybrid system rather than ICE by itself, but it is always a possibility. DON'T let someone put something in the gas tank or fuel injector rail. Your dealer would love to run a can of BG44K through and charge $150+ for it. Best to take them out and have them cleaned ultrasonically and flow tested. There is probably someone in your area that performs this service, about $80 for 4 injectors plus the labor to remove and install. Try this last since it means money out of pocket.
  19. Patrick Wong
    18,210
    6,515
    I suggest that you reset the MFD mpg indicator, then drive at 40-50 mph for 30 miles or so, on flat roads with minimal traffic and stoplights - then return to the starting point. That should produce close to the best mpg that the car is capable of delivering. What indicated mpg do you see after that test drive?
  20. cigarette1
    cigarette1 New Member
    In Front Of You
    I am having the same problem. 2005, 117k mi
    3-4 months ago I was getting a constant 46-48 mpg averaged over 200-500 miles. Now I can't get it to average more than 38 mpg.
    Apparently, there is no standard fix for this.
    G
