05 prius
Discussion in 'Gen 2 Prius Technical Discussion' started by BrimerShannon, Feb 7, 2022.
  1. BrimerShannon
    BrimerShannon New Member
    Kansas, United States
    not sure whats going on i'm not getting any codes related to the hybird battery but it drains rapidly to one bar on display once i start the car. bought the car it had from end damage replaced everything that needed replaced and then the rapid discharge of the battery happens. i was told the hybird battery is only a few months old. i fixed all the parts that the codes sold and got most the codes fix only a 02 sensor code left because there is no cat on the car and a code saying the throttle is stuck open when i checked the throttle while the cars on its closed not sure why i'm getting the code. i'm to the point of cutting my loses and reselling it because i don't have one to two grand to put out for a hybird battery if that is my issue. doesn't anyone have any ideas?
    52,887
    does the car make ready and run the engine?
  3. BrimerShannon
    yes which is another reason why i'm confused. engine runs fine and idles fine it just won't charge
  4. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Sounds like a hack job of a used/rebuilt hv battery, best to pop it open and look at the serials to see what you're actually dealing with.
    You might consider a DIY grid charger setup, and use that to cycle the HV battery a few times.
    You can get cheap catalytics for like $140 or less.
    alftoy likes this.
  5. BrimerShannon
    i know about the cats prices thanks ill give your idea a try is there diy grid charge setup tutorials? because i never heard of them but i have a 6volt and 12volt battery charger
  6. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    Can I borrow your battery charger/balancer/reconditioner? | Page 7 | PriusChat
    Lots of discussion for $100 grid chargers.
    DIY Grid Reconditioning Charger | PriusChat
    DIY harness for DIY charger/discharger | PriusChat
    Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    edthefox5 and SFO like this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Prius engines don't idle. In PARK or D the engine will only stay on if the hybrid battery is very very low charge or the car is cold.
    So you do not see any arrows on the mfd indicating charge activity? Arrows going from engine to battery?
    If the battery is bad to the point of no charging possibility the dash will instantly be lit up and show a bright red triangle and a little car icon in the top left corner of the mfd. If you do not have that its just the hybrid battery is really really low.
    Force charge the battery:
    Put the car in ready then put the car in D then put your left foot on the brake and then with your right foot press on the gas just hard enough to start the engine. Just sit there like that till you see charging arrows on the mfd. Do this power braking till you see at least one blue bar on the battery indicator. I did this for months when my hybrid battery started to fail.
    If you do see the big red triangle master caution alarm on the dash the RTOD Red Triangle of Death then the hybrid battery has most likely failed and will need some help. It may be the battery has just sat for a long time and very low.
    alftoy likes this.
  8. BrimerShannon
    i do see arrows i let car sit to try charge it i even tried to drive to charge it but it barely moves. they stay for what seems until i put car is drive then i get 3 symbols.
    a battery symbol with a ! in the middle
    a triangle with ! in the middle that says problem but never indicates what the problem is
    and a battery symbol with + and -.
    I have the red triangle with ! in middle and the little car icon showed maybe 4 times within the 2 weeks i been working on giving the car its life back.
    maybe its the battery sat to long the guy i got it from said after he replaced the battery he hit the dear the same day and it sat for like three months.
    and if you mean the greyish blue batter strength looking bar on display i have one bar. i also noticed when its like 60 degrees outside it shows 4 bars then when i start it the bars go down really fast to one bar like maybe in five minutes or less
  9. bisco
    52,887
    how is the 12v health?
    is there movement in the inverter fluid reservoir?
    does the batteryicon stay at one bar when driving, or what is its behavior like?
  10. BrimerShannon
    yes battery stays at one bar.
    the inverter makes noise like its running and with the cap off on the fluid reservoir fluid moves not sure how its suppose to more but it looks like its cycles the fluid.
    can't drive at one bar will be lucky if i can move a few feet in ether drive or reverse like there's not enough power
  11. bisco
    52,887
    there is either fluid movement, or there isn't, so that's fine.
    are you using tech stream?
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Yup sounds like a bad hybrid battery. You have the RTOD and the car icon.
    Covid has killed a lot of old G2 hybrid battery’s you cannot let that old battery just sit. They die. They corrode. Hundreds and hundreds of posts about bad G2 hybrid battery on this site.
    You say you have one blue bar you can drive on that no problem the issue is once the car throws the RTOD it’s very unhappy and the car then goes into limp mode and has no power. Since you have one blue bar the battery probably has a ground fault from leaking electrolyte. very common. Battery is a corroded mess. This can be tested by disconnecting the 12 volt battery let it sit a minute connect it back up see if it clears the RTOD . It should clear the
    RTOD and you may be able to drive it a short distance but don’t go far as
    the RTOD and limp mode will come right back on.
    Your battery is done.
    Alftoy gave you all the links you need. Good luck.
  13. BrimerShannon
    what is tech stream?
  14. BrimerShannon
    there was corrosion on the point but they wasn't bad but i cleaned the anyways it was light corrosion
    edthefox5 likes this.
  15. bisco
    52,887
    tech stream is toyota trubleshooting software. not all readers get all the codes and sub codes
  16. BrimerShannon
    what i don't understand though is after i replaced the radiator and the broken wire connecters it was charging just fine but once i put headlights on and factory radio in and turned car on to check make sure they was working it was no longer charging
  17. BrimerShannon
    oh ok yeah i had a friend come over with a laptop that had a software made for Prius idk if it was tech stream but it gave me all the codes i needed to fix even codes i couldn't get on my obd2 and i fixed them he even checked
  18. bisco
    52,887
    then it is very odd that you're not getting any codes. must be a wiring issue somewhere
  19. BrimerShannon
    thats what i'm thinking but i have yet to find it
  20. bisco
    52,887
    i wish i could be more help, all the best!(y)
