05 toyota prius with many lost comm codes
Discussion in 'Gen 2 Prius Technical Discussion' started by Hambone69, Nov 12, 2024.
  1. Hambone69
    Hambone69 New Member
    Ky
    Hello, I know this is a long shot since I've made my brain hurt doing research and looking for someone with a fix to a similar situation to mine. Anyways my 05 hybrid battery quit on me last month. Instead of replacing the whole pack I just replaced the bad cell which fixed the problem. Now after changing the bad cell, I decided to go ahead and change the oil and spark plugs since they was due for it anyway. After doing so I took the car for a spin and it ran the best since I've owned it. As I was pulling back into my neighborhood my entire dash light back up and threw a bunch of lost comm codes. I have changed my 12v battery, checked all my fuses, and checked all my wires that run under my glove box and checked the plugs that run to the computer module for corrosion. Everything looks fine. I'm on the verge on getting rid of the car because I don't know what else to do and don't want to sink a ton of money into "possible" solutions that might not fix the problem. I'll attach screen shots of the codes.
  2. Hambone69
    Ky
    I will also mention, that when I disconnect the 12v battery to reset everything and hook it back up, I can drive the car with no issues or dash warning lights for about 15-20 min before all the lights come back on.
  3. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    You need to have that 12 volt battery tested by approved testing equipment and have it passed or failed and replaced usually the communication problems in these cars are because you're 12 volt is not 12 volting now you can test this by putting a multimeter in the DC volts mode on the battery with the engine ready in park just sitting there You're looking for 13 and 1/2 to 14 and 1/2 volts Just sitting there then when you turn the car off nothing on the dash doors closed hatch open test leads on the battery It should fall down to 12 volts but if it's dropping into the 11s down to 10 and lower no good it may work it may allow you to drive the car here and there but no good so you need to make sure that's not happening everybody will say that's not happening and this and that and all that and then after 12 posts they find out they're 12 volts bad so there's always these things that's like the number one cause of communication problems in the Prius other than chewed wires by mice cut by people putting stereos in etc so find what meets the closest of the criteria here and see what's happening. The can bus just doesn't go down for no reason usually it's some kind of a voltage problem or a disconnect whether that disconnect has been chewed wires or human beings connecting things incorrectly adding things whatever it is. And good luck because usually you shouldn't be throwing these cars out for this kind of pretty basic problem
