05 Won't Start, dash lights blink once
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Matt Cope, Aug 18, 2017.
  1. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Tell us more about the "new" pack. Source? Tested?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Turn the headlights on...are they nice and bright?
    If not its either a dead battery or the hardwired fuse is blown in the fuse box under the hood. if you have good lights then its the hybrid battery.
    You'll never really know whats wrong until you get a HYBRID code reader and read the multiple codes the car has thrown.
    Check the oil too. Its probably empty.
  3. Matt Cope
    Matt Cope Junior Member
    22
    17
    Columbia MO
    I have indeed thought that the 12V system could be the problem, which is why I have had the 12V battery charged and tested to find ample Cranking Amps and consistently tested the battery at 13 to 14 volts with my multimeter. All of the lights work well and bright before and after trying to start, radio works great, all of the electrics work great, so that makes me believe that the 12V battery is good. I work on cars regularly, so I know some of the basics to check, just learning the intricacies about the hybrid system.
    I bought the 2005 Prius knowing it had issues. 05 has 210xxx miles on it. I bought the 07 totaled from a front end collision, battery had just been rebuilt two weeks before by a local Toyota Tech. I have the spare parts to change over if anything is wrong.
    JC91006-thank you for the suggestion of the AM2 fuse, I will make sure to check that.
    How would I check the hardware fuse under the hood? Where is this fuse and how do I get to it?
  4. JC91006
    16,933
    8,643
    There's a fuse box in the engine compartment, drivers side
  5. fotomoto
    5,639
    3,815
    So. Texas
    Needs to checked.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    And equally important if you are having electrical trouble is: A multi-meter.
  7. Sam Spade
    2,036
    1,024
    2017 Prius c
    Well it sounds like you have a good handle on the basics but I've got to to ask:
    Have you tested the battery voltage WHILE you have tried to "start" it and nothing happens ?
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Third time's a charm? (y)
    Raytheeagle and edthefox5 like this.
  9. Sam Spade
    2,036
    1,024
    2017 Prius c
    However many times it takes before the information sinks in.
  10. Matt Cope
    22
    17
    Columbia MO
    Is there a way to check the hybrid battery outside of taking it apart and testing every cell?
    And yes, Sam Spade, I have a multimeter and have been using it along steps in this process. You have stated how important it is to use said multimeter, but never actually said what specifically to check and what the values should be.
    Raytheeagle and SFO like this.
  11. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    SFO likes this.
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    Others have already provided that information in previous threads on here........MANY times.
    SFO likes this.
  13. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Raytheeagle and dolj like this.
  14. Matt Cope
    22
    17
    Columbia MO
    That sounds like it would be a great way to test the battery, but I do not have a running and driving Prius to test it in.
  15. bisco
    52,785
    the 12v should be at least 12.4 volts, with the car off, after the car has been off overnight.
  16. Matt Cope
    22
    17
    Columbia MO
    Turns out the AM2 fuse was bad, and the inverter pump was completely fried. Transferred the one over from the 07 parts Prius (it had just been replaced) and it runs and drives like a dream, with the original battery!
    Turns out the 12v system was good, and the hybrid system is good as well. I never thought one fuse would cause so many problems.
    SFO, fotomoto and Raytheeagle like this.
  17. JC91006
    16,933
    8,643
    There's a recall on the inverter pumps that get shorted out.
    I helped a PC member today fix his inverter pump, these things are dying regularly.
    #37 JC91006, Aug 27, 2017
    SFO likes this.
  18. Sam Spade
    2,036
    1,024
    2017 Prius c
    Sounds to me like the fuse did exactly what it was supposed to.......and that is to prevent a fire when the pump shorted out.
  19. Oyeleye Amos
    Oyeleye Amos New Member
    Nigeria
    I have this same problem right now. Please do you mean the engine/transmission oil?
    My inverter pump and the AM2 fuse were replaced, the dash lights still blink and shutdown - leaving an orange light on the power button.
    Please, I need help.
    12V battery was also replaced.
    #39 Oyeleye Amos, Sep 12, 2019
  20. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Check the 12 volt battery voltage at the front jump point under the hood in the fuse box. Don't check it in the trunk it only really matters whats hitting the fuse box. There is a 100 amp fuse in the positive battery post assy on the battery. Checking it at the front jump point checks that fuse continuity.
    Skibob likes this.
