06 111k miles dead ev battery. How much is it worth?
Discussion in 'Dealers & Pricing' started by mike1158, May 14, 2013.
  1. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    You DO have the DTCs? Great we have been pleading for them! (Or were they some other first two sentences?)
    cwerdna likes this.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    That sucks. If you have DTCs (they're probably in the format Pxxxx)), that would help confirm.
    The only thing you could try is to see if the dealer (or a good dealer) can take it up w/Toyota to see if they're willing to cover some (or most) of the cost. You aren't that far outside the warranty. This particular amount of time and mileage for HV battery failure is a bit on the early side for a Gen 2.
  3. mike1158
    mike1158 New Member
    i already tried that with toyota and no dice.
  4. RAL
    RAL Member
    66
    34
    RAL
    Bummer if there is any way to work it out I would keep her. A new traction battery in a Prius with those low miles and you likely will have good cheap transportation for another 100000 to 150000. If I was near enough and the car otherwise is in good shape I would trade you a fine F-250 gas guzzling work truck with 110000 miles on her.;)
    RAL
  5. mike1158
    mike1158 New Member
    that would work out nicely for me
  6. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    What did you end up doing with your car? And did you ever find out what the codes were?
