-06 head unit upgrade, disturbance noise over RCA
Discussion in 'Gen 2 Prius Audio and Electronics' started by MiRoXFin, Nov 7, 2021.
  1. MiRoXFin
    MiRoXFin Junior Member
    Finland
    Hi! I installed an aftermarket head unit, ran 6-channel rca lines and speaker wires to the front doors. There is these annoying static distortion noises playing through the speakers when radio is on and amp is also on. Without rcas there isn't any noise. Is this common or is my wiring bad?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,529
    1,611
    NJ-USA
    Sounds like you might have a ground loop problem between the head unit and amp. The "lazy" way to deal with that is to get RCA isolation transformers. People who know more / care more about audio gear probably have better solutions. (That ain't me.)
  3. MiRoXFin
    Finland
    Most of the noise was removed when i grounded the rca "minus" to the body of the car. There still is some but I can live with that. Next is going to be some sound deadening ;)
  4. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    RCA ground loop transformer US$10
    Amazon B077Y5DLBB
  5. MiRoXFin
    Finland
    I've tried a "four connect" branded ground loop isolator and that didn't work..
    #5 MiRoXFin, Nov 16, 2021
  6. Another
    1,802
    511
    Naples, Florida
    Maybe problem is in speaker cable
  7. MiRoXFin
    Finland
    Yeah it must be.. Basicly everything else is done. I'll have to look into that at some point, thanks!
